Hot Rods Belly Tank!
Discussion in 'The Hokey Ass Message Board' started by Rehpotsirhcj, Jun 24, 2019.
  1. Thats eye candy right there!!:cool::cool:
    Will see how i go first time and then get wilder after, just need it to be reliable first as its a long way to travel for me. JW
    Stogy and loudbang like this.
  2. A couple of small updates, made a steering wheel for the Tank at work.JW
  3. I tried it out for size. The seat will come forward a bit and the front axle will mount about 20'' back from the front tip. Hope to have more news soon. JW
  4. typo41
    typo41
    By the way, Jeep motors are legal V4 motors,,,,,,or is it V4F?
    Anyway they are legal in SCTA
    loudbang, 26 T Ford RPU and Tman like this.
  5. If this one doe's any good i will rebuild it in a pre 35 Willys block, that will get it into vintage motor, in the meantime i just have to follow my dream and run a ''Willys Motor''.
    I have had Willys cars from '76 when i was 17, hence the thing with them. JW
  6. The37Kid
    The37Kid
    I hope the HAMB family can search and find you a Duvall head for the project. Bob
    GuyW, 41 GMC K-18, Stogy and 2 others like this.
  7. Thanks for posting that, Bob, its very cool indeed but i will stick to the Flathead class..........its cheaper:rolleyes:. It would make my 35 or 37 Willys go better though.:cool: JW
  8. typo41
    typo41
    I think I know where one is hidden,,,,,,
    41 GMC K-18, Stogy, loudbang and 3 others like this.
  9. I could be interested if the price was right as the exchange rate would be a big factor. JW
  10. I'll chip in.
    ratrodrodder, Stogy and loudbang like this.
  11. Thanks, Terry, did i mention i want you on my pit crew? :cool::cool::D JW
  12. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
  13. Made a small amount of progress on mine. The front mount plate that will have the spring, shocks, steering box, clutch and throttle master cylinders, also the termination point of longitudinal chassis/roll cage pipe work. Hope to make more progress over the X-mas break. JW
    41 GMC K-18, loudbang and Stogy like this.
  14. What are you using for front suspension, are you going to use front brakes? what steering box ? give a list of stuff and I'll see what I can dig up.
    Merry Christmas
    Terry aka dirt t
    The37Kid, loudbang and Stogy like this.
  15. Got it all, Terry. Bug steering box, no front brakes and i have all the front end bits. Have the motor and box and rear end.
    Thanks Terry and all the best to you and Jenny.:D JW
  16. Rehpotsirhcj
    Rehpotsirhcj
    Looking good. How tricky was it to get that pipe bent up to fit?
  17. Was easy with the template i made from MDF sheet with the inner line to follow. The lower pipe will be soon.. that will be fun. JW
  18. The37Kid
    The37Kid
    Project is looking good. Bob
    loudbang, 26 T Ford RPU and GuyW like this.
  19. I haven't had it likened to a bath before...boat yes but not a bath. Thanks, Bob. :D JW
    The37Kid and loudbang like this.
  20. Rehpotsirhcj
    Rehpotsirhcj
  21. Rehpotsirhcj
    Rehpotsirhcj
    Another great photo from the AHRF. Tom Beatty Lakester @ Bonneville 1959.
  22. Rehpotsirhcj
    Rehpotsirhcj
    From FB,”Harellson Tank”
    So, always one with a dumb question: where these generally run without any cooling system, or am I missing something?
    loudbang, GuyW and 26 T Ford RPU like this.
  23. Many had a water tank that took a while to heat up, some had radiators and some had both. Mine will be a radiator, Ally Model A type at this stage and may have extra water as.well. JW
    loudbang and Rehpotsirhcj like this.
  24. JW remember water weighs 8 lbs per gallon. On my funny car we ran alcohol with no coolant it would ice up so we would spray the the butterfly to keep it from icing up. Of course it only for a minute or so. Could you run alcohol?
    loudbang and 26 T Ford RPU like this.
  25. It will be only pump gas,Terry. Many of these cars are so light they have trouble getting traction so a bit of useful weight would help hold it down. Plenty of places to loose some weight as long as its not safety related. JW
    Terry, give Jenny a hug from me Bud:D
  26. Rehpotsirhcj
    Rehpotsirhcj
    Milk truck wheels?
  27. typo41
    typo41
    Actually I believe they are called High Clearance wheels, yes used on Milk Trucks and Bread Trucks. They were used because they are 18 inch rims and could run the left over high speed Indy tires for a 'gear" change. I know Frank Oddo ran the tires, but not the wheels on his Redi Strip Special tank up until he stopped racing in the late 2010's.
  28. Rehpotsirhcj
    Rehpotsirhcj
    That’s great to know, thanks!, I expected the ratio advantages, but the used Indy tires is completely new to me. Also new, running different size wheels front and rear. I imagine deep pockets would be needed to find a set of those wheels today. I recall they were a popular find a few years ago.
  29. Finally made a bit of progress on mine. Tacked the spreaders on so i can now bend up the lower section of the space frame. The photo shows the frame upside down so its easy to test fit the pipe as i bend it. More progress ''soon''. JW
  30. looks good. If ya need something from this side of the pond let me know.
    26 T Ford RPU likes this.
