Technical Hurst Shifter Body Interchange
Discussion in 'The Hokey Ass Message Board' started by lewk, Sep 11, 2020.
  1. lewk
    lewk
    from Mt
    I'm trying to get my 60 El Camino together quickly for next spring and I have a 3 ring Saginaw 4 speed out of a Monza that I want to use for now until I get a Muncie or a T-10 together. The factory Monza shifter is kinda cheesy and I'm redoing the floors right now anyway so I want to put a Hurst in there. They have gotten expensive so I only want to buy once. When I change to a better transmission, I want to be able to reuse some parts. I've been through the Hurst Catalogue trying to make sense of Competition Plus part numbers. I get that there are different bolt on shifter arms and installation kits.
    I want to know if the shifter body itself is the same between Saginaw, Muncie, and T-10.
    If not, what is the difference?
    Thanks for the help. It's hard to get the details right just looking at picture on the auction site.
  2. DDDenny
  3. saltflats
    saltflats
    from Missouri
    Shifter body will be the same, the linkage, levers and mount bracket will be different.
  4. lewk
    lewk
    from Mt
    Thank you. Unfortunately most of those charts have a shifter "kit" that includes a mechanism, a handle, and a knob. I want to know if the mechanisms are all basically the same. I can use, make, or modify a handle and I already know I'll need a different install kit for different transmissions.
    Thanks, this is what I needed to know before I start buying mismatched parts of the auction site. I was worried the hole pattern on the body would be different or the arms coming out of the bottom of the mechanism might change.
  5. Vic Walter
    Vic Walter
    GM and other's did put Hurst shifters in at the factory. I think it unlikely though with the Saginaw. Hurst is stamped in the driver's side of the body. Along with some US Patent numbers. I recently rebuilt a Hurst shifter that is from a 80's chevy truck with a NP440 trans. Like DDENNY posted, shifterdoc.com is a good source of info and parts for Hurst shifters. The plate between the shifter body and the tail housing will vary application to application, but the one that works for you on the Saginaw should also work on the T-10 / Muncie, all those GM trans have similar form factor dimensions. The mount plate I have is from the chevy pickup (mounts the shifter higher and more forward) Here is a couple of pictures of what I have.
    mgtstumpy and lewk like this.
  6. 5speeds.com has good inf also, especially his youtube vides.
    lewk likes this.
  7. The H-body (Vega, Monza and other GM variants) Saginaw 4 speeds did not have their shifters mounted on the trans extension housing. The casting had the mounting bosses but they were not drilled and tapped for the shifter bolts. The original shifters were mounted to the floor pan or tunnel somehow.
    If this is the only difference between the H-body extension and the one used on the other car lines you could probably drill and tap the mounting bosses and attach any Saginaw 4 speed shifter. Or swap on an extension from a non-H body Saginaw trans, providing that everything else is the same. Check that the speedo drive is in the right place and that you have any other mounting holes in the right places if you need them. And you might want to make sure that the shift levers on the side cover are laid out the same way.
    lewk likes this.
  8. lewk
    lewk
    from Mt
    Here’s the factory shifter, trans, and tunnel bracket. I just don’t want to set my El Camino’s floor up for this thing, especially if I change to a different trans later.
    It looks like the bosses are tapped on the trans. The parts are obviously not sitting in the El Camino.
  9. Looks like you're ahead of the game already then. ;) Maybe not out of a Monza originally? Does it have a crazy-low first gear in it? o_O Maybe like a 3.10 or something close?
    lewk likes this.
  10. jimmy six
    jimmy six
    I’ve got a few Hursts. Only difference is whether they have bolt on handles. All of them needed a plate that bolted to the trans. I’ve bought them at swap meets and e-bay. I’ve made rods with clevises and cold rolled rods from a hardware store. All the Saginaws I’ve used had the bosses for the plates. The Hursts fit any of them, maybe not perfect but were fine. I don’t race or yank them and the work great.
    I just finished one for a new Richmond T-10 out of 30-40 year old parts. Some I bought off e-bay for parts. Good luck
    Bob Lowry and lewk like this.
  11. Vic Walter
    Vic Walter
    Using the parts you have would get the El Camino on the road the soonest.
    Fab up a plate that would bolt to the tail housing of the Saginaw you have. Take a cut off wheel to the shifter you have, whittle it down some and weld it to the plate. Mod the arms to fit. Having it on the road and driving will be it's own reward. Take your time and continue to piece together the Muncie/T10/Hurst. When that is done R&R it into the El is a easy job. The Saginaw will be worth more with a shifter, let the next guy put a Hurst on it.
    lewk likes this.
  12. lewk
    lewk
    from Mt
    Follow ups are nice. It took 3 auctions, but the auction site got me all set for well under the cost of new. I’m short one bolt and a spacer. That’s easy though. I’ll stuff it in the El Camino and do my tunnel soon. Thanks again for all the help.
    Stock Racer, ClayMart and saltflats like this.
  13. Mr48chev
    Cool, it looks like you just about have it covered.
    Back years ago when things were a bit simpler You went in and bought the complete shifter with handle,brackets and shift rods for your vehicle (or the application that fit what you wanted to do) and installed it. I think mine was about 180 around 1980. Now you buy the shifter with or without handle then by the "installation kit" to fit the application and either costs more than my dad paid for it when he surprised me with it for a birthday. I had an old "came in some GM car" shifter on it and he had ridden in the truck with me when I was fighting with the shifter. That unit is hanging in my shed waiting for a project to be used in.
    If you haven't found it there are a lot of Hurst parts here https://www.ebay.com/sch/shifter-dr/m.html?ssPageName=STRK:MEFSXS:MESOI&_trksid=p2053788.m1543.l2654
    lewk likes this.
  14. southcross2631
    southcross2631
    I was going to say if you hadn't found one . Summit actually sells their brand shifter for a Saginaw and it is a Hurst knock off and works really good. I put one in a customers 57 Chevy that he provided me the transmission and shifter.
    davidh73750 and lewk like this.
  15. Just an FYI, but that shifter set-up is higher and further forward than the Muncie will be. If you fit the floor for this combo, the Muncie shifter will not fit in the hole.
    lewk likes this.
  16. That shifter your holding is the floor mount for the Monza that was mentioned earlier - and does not bolt to the trannie.....if you didn't figure it out.
    lewk likes this.
  17. 56sedandelivery
    56sedandelivery
    lewk likes this.
  18. davidh73750
    davidh73750
    Question. Would that monza/Vega setup work well in a pickup? Thinking of solution to run bench seat. Of course no speed shifting I wonder how hard it would be to center or set up? Maybe go in a 50 Chevy pu with 283, low gear Saginaw.
  19. mgtstumpy
    mgtstumpy
    That configuration almost replicates a Hurst Super Shifter setup with higher direct rods.
  20. Ericnova72
    Ericnova72
    from Michigan
    I thought the same thing nearly as fast as I viewed the latest picture....not going to fit in the factory trans tunnel on an El Camino, not mounted up that high. It's up there somewhere close to the Super Shifter and Speedway Super Shifter mounting point.
    Does the '60 Elco have a lot more trans tunnel space than the later A-body Elco's from '64-up?.
    I've never been under one, so i don't know..
    mgtstumpy and loudbang like this.
