does anyone know what fenders may interchange with a 47lincoln club coupe... years and makes? front clip or rear fenders. i wanta more streamlined look. or i can modify but dont want to cut up originals if i dont have to. the rear body looks like same lines as 40 41 ford lincoln merc.
Clean those up and work them into full fade-aways. But first like always, Get it running, rolling stopping. Then do the cutting. Check out the Darrin Lincoln from the 40's - I know this is aa Continental, but the idea on the fender is fairly close. https://public.fotki.com/Rikster/11...s/40s-50s_built_linco/1942-lincoln-by-darrin/
This is the answer. Ford and Merc are not even close, what you want is a '40 or '41 Lincoln front clip.
The 42-48 body is wider in the cowl than the 40-41 from what I've been told. To use the 40-41 stuff, you'd have to widen the hood. I had the same thoughts when I first got mine, until I learned it wouldn't work as produced.
