Technical Putting a 350 in a 40.
Discussion in 'The Hokey Ass Message Board' started by Matt Miller, Aug 17, 2020.
  1. Matt Miller
    Matt Miller
    What problems should I expect?
  2. 40 Ford?
    Matt Miller likes this.
  3. adam401
    adam401
    First problem will be God bringing his wrath down on you for putting that weird French engine in a Ford. Other than that with an adapter it's almost a bolt in with a Hurst mount and a little wiring. Ive bought quit a few flathead radiators over the years modified for sbc as well. They probably cooled fine given their thickness.
    I owned a 40 sedan that got cut into my friends car that had been running a small block. Was seriously totally stock except the remnants of a torched Hurst mount were in there . otherwise you would have thought it was a flathead car its whole life.
    Matt Miller and warbird1 like this.
  4. 31Apickup
    31Apickup
  5. Bandit Billy
    Bandit Billy
    People snickering but pretending it was something they thought of from earlier, definitely not your car.
  6. I'd guess you will spend more time with wiring and cooling stuff than bolting in a sbc.
    exhaust manifold choice is necessary, front dump or rear dump.
    Matt Miller and lothiandon1940 like this.
  7. ............or, fenderwell headers.:D;)
    OLSKOOL57 likes this.
  8. olscrounger
    olscrounger
    noting to difficult-have done a dozen at least
  9. 40Standard
    40Standard
    from Indy
    drops right in
    lothiandon1940 likes this.
  10. sdluck
    sdluck
    Didn't they all come that way?
  11. Early Cad fits just as well... and it's not just another 40 with just another sbc in it.
    OLSKOOL57, Matt Miller and Moriarity like this.
  12. RmK57
    RmK57
    Been done a million times. Wouldn't exactly call it hot rodding, hell Walmart might even have the swap motor mounts you need in stock.
    57Custom300 and Matt Miller like this.
  13. Matt Miller
    Matt Miller
    Yes, I know I will be going to flathead hell and shunned like a cheap hussy but unless someone has a crack free 8BA shit will get real here pretty soon.
    it might be a head gasket since some monkey too this up to 9:1 with 175 pounds compression. Will take the GD Edlebroke 63 CC’s off next using some nice 8CM to calm bessie down.
    warbird1 likes this.
  14. Matt Miller
    Matt Miller
    Who in the hell builds a lawn mower engine up in sedan? Jesus.
  15. Matt Miller
    Matt Miller
    Does anyone make a 1/4” head gasket? That might work.
  16. adam401
    adam401
    I have some 8cm heads here if you need them
  17. The only tough part to find for the Swap is the adapter to mount the Fan on the end of the Crankshaft. I had to make the last one I used.
    MIKE STEWART likes this.
  18. Matt Miller
    Matt Miller
    That’s a smart and great idea! Thank you!
  19. MIKE STEWART
    MIKE STEWART
    I would love to have a crank mount fan on my 1939 Ford
  20. Weedburner 40
    Weedburner 40
    I used to sell a crank mounted fan kit made by a guy from Portland, Oregon. He quit making them when Drake came out with one.
    Pist-n-Broke and lothiandon1940 like this.
  21. I'm going the other way. Pulling a 350 out of my '40 ford "Woodie" and replacing it with a flathead. I wish you were closer to WV. I'd make you a heck of a deal!
  22. Hnstray
    Hnstray
    from Quincy, IL
    You do realize, don’t you, that @Matt Miller is in NC! That can’t be much over a few hundred miles, if that. Sheesh......:D
    Ray
    i.rant likes this.
  23. I knew that guy and have been trying to come up with his name. For some reason I think Dale Vanderzanden but don't seem like it was him overall. I don't remember Dale being a machinest but big into 40 Ford's. Seen his car with his proto type on it around 1972-or-3. I think my hard drive got full around 1980 and started kicking out seldom used info.
  24. Weedburner 40
    Weedburner 40
    Pist-n-broke, Kenny Jones was the guy that was making the kit. He and Dale were friends and did run together. I haven't heard Dale's name in a long time. He had a really cool red coupe. Nice guy to boot.
  25. Dale, was that a SBC crank mounted fan?
  26. 1-SHOT
    1-SHOT
    from Denton
    If you are going to run cast iron exhaust manifolds try the early Chevelle manifolds they clear the steering box like they were made for the swap. I have a set on my 40 for over 50 years. You may be able to find them at a swap meet cheaper. C06E7216-A53A-446F-9748-FA04D4CFC3EA.png
    scrap metal 48 likes this.
  27. Rusty Heaps
    Rusty Heaps
    Why not go with the 235 six? That’s what I installed in my ‘46. Oh, wait a moment, you have a Ford. Never mind.:eek:
  28. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    On my 40 we used the 69/70 Chevy PU right side manifold that points back at an angle and put it on the left side to shoot the exhaust forward/around and down under the 525 box. worked great.
    Dan Hay and olscrounger like this.
  29. Search for my build thread "the Varmit" and there will be lots of tech info there. It's really easy.
    The 39 guy and Hnstray like this.
  30. Weedburner 40
    Weedburner 40
    Brett, yes it was. Gary, that's what I have in my 40 too.
