Projects A Full-Fendered Side Project
Discussion in 'Traditional Hot Rods' started by Ryan, Feb 15, 2016.
  1. Duke
    Duke
    I have a 29 coupe as well. The repo latch did not fit at all. After many hours of trying to make it fit, I rebuilt the original. I welded up the worn spots. Works good now.
  2. catdad49
    catdad49
    Randy, I think Duke answered your questions. Glad to see you're working on the coupe again, Carp.
  3. 31Apickup
    31Apickup
    You can get replacement springs for the latch, disassemble, replace the springs, build up any worn out areas with welder and it’ll be good.
    catdad49 likes this.
  4. Mattsbidnuz
    Mattsbidnuz
    Is that a closed cab pickup in the back corner? Would love to see it. :cool:
  5. Mattsbidnuz
    Mattsbidnuz
    Wish I would have saw this sooner. Had a similar idea that now seems to be more work, but same concept. Slide50.JPG Slide54.JPG
    Tim likes this.
  6. sodas38
    sodas38
    It doesn't get much better than this for a Model A Coupe. Very nice.
    biggeorge likes this.
  7. Rand Man
    Rand Man
    The other problem we are working on is that the battery drains down all the time and it is often hard to start. It could be several things but we suspect the points. It has a Delco dual point number 1110891.
    I would like to know what this came off of. My son has ordered two different Petronix units that do not fit. Can anybody help me?? IMG_1505.JPG IMG_1506.JPG
  8. Rand Man
    Rand Man
    Also, this distributor does not have vacuum advance. I had thought it must have been an old Corvette unit, but I doubt that now.
  9. the power should be shut off to the points when the key is off. it should not be a drain.
    ct1932ford and Moriarity like this.
  10. Rand Man
    Rand Man
    The old inter-web shows it listed as a 57 thru 61 Corvette distributor.
  11. Rand Man
    Rand Man
    Well, there are two separate issues. The petronix is for starting and consistent running purposes.
  12. Rand Man
    Rand Man
    Turns out the correct Petronix part number for this old dual-point is 1183. My son just completed the conversion and reported the engine now sounds crisp and snappy. Can’t wait for the test drive.
    catdad49, -Brent- and Tim like this.
  13. Tim
    Tim
    from KCMO
    Yeah buddy! Good deal :)
    Rand Man likes this.
  14. Rand Man
    Rand Man
    My son reports the test drive was the tits. Running better now than ever. Starts right up, and you can hear the cam loping with a crisp idle. Great throttle response.
    He is working on the door latch springs kit we got from Snyder’s.
    Tim and -Brent- like this.
  15. Ryan
    Ryan
    ADMINISTRATOR
    I have somehow missed all this progress... So rad to see you guys keeping this thing going. I love that car.
    Sancho, kidcampbell71 and Rand Man like this.
  16. Rand Man
    Rand Man
    I’m glad to have the car Ryan. Next on the list is to find out what is draining the battery.
  17. hook a test light BETWEEN one of the battery cables and the battery post. you will have to take the cable off the post. if the light is lit there is a drain, pull fuses or start disconnecting things till the light goes out. the problem will be on that circuit. reconnect it and disconnect further down the circuit till you get to the problem.
    does it have a vintage looking modern radio?
  18. -Brent-
    -Brent-
    I need to print this and hang it in the shop!!! A+
    383deuce, Rand Man and kidcampbell71 like this.
  19. Rand Man
    Rand Man
    Yeah, that’s a good plan. I haven’t found the fuse panel yet. I bet he hid it in a kick panel. No radio.
  20. Rand Man
    Rand Man
    I got to drive my coupe this evening. Big thanks to my son for fixing the clutch, installing electronic ignition and bigger battery. Starts and runs better than ever!
    I believe that battery has been a problem all along. I’ve only put 3000 miles on the thing because it wouldn’t start most every time I wanted to drive it. It finally fizzled-out. It [​IMG]cranks like crazy now. After a two hour drive, it started right up. Alternator is fine. A small deep-cycle Red-top Optima didn’t work for me. Your results may vary.
    enloe, Bugguts, Shadow Creek and 10 others like this.
  21. -Brent-
    -Brent-
    What battery are you running, now?
    Tim likes this.
  22. Tim
    Tim
    from KCMO
    Man that’s such a great hot rod.
    curious about the new battery as well.
    Rand Man and Baron like this.
  23. Rand Man
    Rand Man
    Just a regular battery from Autozone. I’m not sure of the numbers. I’ll check tomorrow. It went from 475 cranking amps to more like 675. Had to build a new bigger battery box. Not a big deal. Fits fine
    enloe, louisb, Just Gary and 5 others like this.
  24. catdad49
    catdad49
    Glad to see both you and the coupe are out and about!
  25. FOURTYDLX
    FOURTYDLX
  26. trikejunkie
    trikejunkie
    from Scotland
    I have searched through this thread two or three times ( not a chore I must say) can someone tell me what master cylinder that is? A search through google left me dizzy .
  27. @trikejunkie It appears to be a 60-66 Chevrolet Truck master cylinder, for both brake and clutch.
    trikejunkie, -Brent- and Just Gary like this.
  28. -Brent-
    -Brent-
    trikejunkie likes this.
  29. Rand Man
    Rand Man
    Yep, that master was installed back in the 60’s. It uses a hydraulic throw out bearing as the slave. A more elegant solution than the Chevy slave cylinder. That bearing was recently replaced when we went to a new SFI shatter-proof bell housing. I recommend following the installation instructions and get it adjusted right, so those things don’t get ruined.
    Tim and trikejunkie like this.
