Technical Engine Skeleton.........pretty slick
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Aug 5, 2020.
  1. ekimneirbo
    ekimneirbo
    I believe the lifters are welded to the cam and the pushrods.
    Deuces likes this.
  2. Truly, a total-loss oiling system :D
    Deuces likes this.
  3. silent rick
    silent rick
    so again, what's holding up the cam?
    Deuces likes this.
  4. rc57
    rc57
    As stated , you can see the welds from lifters to cam lobes, pushrods to lifters, pushrods to rockers and rockers to the steel plate engine stand. Pretty cool idea
    Deuces likes this.
  5. silent rick
    silent rick
    i can see the rockers welder to the bar stock. i couldn't see if the bar stock was attached to anything.
    Deuces likes this.
  6. Weedburner
    Weedburner
    from Wa State
    It would be cool to build one from a blown-up engine. Bent/broken valves, severely damaged piston, bent/broken rod, etc...
    Grant
    Deuces and clem like this.
  7. BJR
    BJR
    That's what happens when you leave an entire engine in a vat of molasses too long! :D
    Deuces, VANDENPLAS and warhorseracing like this.
  8. I would question the numbers matching claims
    Sent from dumb operator on a smart phone
    Deuces and VANDENPLAS like this.
  9. treb11
    treb11
    The timing sprocket and chain are welded as is the oil pump drive
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Deuces likes this.
  10. This image has been floating around for at minimum 2 yrs, so not a pandemic thing, however it is really cool and I set a few of my blown up Henry J engine pieces out when I first seen the photo to possibly build one.
    Deuces likes this.
  11. ekimneirbo
    ekimneirbo
    My guess is the timing chain in front and maybe a small rod from the rear of the cam to the flywheel.
    Edit: New guess.....given the close proximity of some cam lobes to the crank throws, maybe he oriented the crank/cam where the rear throw is near enough to a lobe that he could put a tack weld there.
    Deuces likes this.
  12. Budget36
    Budget36
    A giant valve would have been a cool stand to hold it up!
  13. goldmountain
    goldmountain
    It would be neat to see it taken to the next level where the valve springs are compressed when it comes up on the cam.
    Deuces likes this.
  14. BamaMav
    BamaMav
    from Berry, AL
    If you look close, you can see some of the rocker arms look like they are at different heights. Springs don't look compressed though.
    Deuces likes this.
  15. ekimneirbo
    ekimneirbo
    He could simply heat the springs red and compress them different amounts till they cool...........
    Deuces likes this.
  16. Slopok
    Slopok
    So they do make clear engine paint after all!;)
    Deuces likes this.
  17. j hansen
    j hansen
    I like it.
    A friend had a straight 6 from a Jeep that I got for free.
    Deuces likes this.
  18. WB69
    WB69
    from Kansas
    Wow, hadn't seen this before. I like it. Awesome work and thought process.
    Deuces likes this.
  19. J. A. Miller
    J. A. Miller
    from Central NY
    Trust me, some guys still couldn't do it! :oops:
    Deuces likes this.
  20. It's been rebuilt........ looks like .030 over. o_O
    Deuces likes this.
  21. papajohn
    papajohn
    Pretty neat, but it's not going to last long if he runs it that low on oil.
    Deuces likes this.
  22. spanners
    spanners
    I've seen engines like that at the drags. The difference is the officials had to collect the parts from all over the track.
    Deuces likes this.
  23. harpo1313
    harpo1313
    from wareham,ma
    Its what happens when your machinist is slow and your very impatient.
    Deuces likes this.
