HD powered Reverse Trike
Discussion in 'The Antiquated' started by '52 F-3, Nov 19, 2019.
  1. '52 F-3
    '52 F-3
    Ace.., those look great...
    I've done some "Reverse trike" internet searching and never seen those before. Craftsmanship looks first class, Initially reminded me of a "Quatro". What is engine/chassis from?
  2. '52 F-3 likes this.
  3. verde742
    verde742
    love yer project.... BUT please explain how this spring can work? as it straightens doesn't it "grow" in length pushing bottom of axle, but held in place by strut rod. thus becoming a four bar suspension?
    Deuces and '52 F-3 like this.
  4. '52 F-3
    '52 F-3
    742; basically it's a triangulated 4-link, which doesn't require a "track bar" to locate axle side to side (the triangulation holds). The lower 2 links are just replaced with leaf springs (without shackles). your correct as the leaf's flatten it will rotate the axles, changing the "caster" a little bit. In a typical 4 link with 2 coil springs, the caster also changes as suspension goes up/down some. With full vehicle weight the leafs are closer to flat, and don't grow/shrink as much as you think. As long as it's not extreme, it will ride and handle acceptable.
    EDIT: after miles of test driving, leaf springs started to "fan out" a little and front end seems to be twitchy (sometime want to go left or right a little bit) I put leaf clamps to keep spring inline and added a trackbar. It correct the driving issues and really made front end handle tight, (like a go cart). I'll be testing it a highway speed next.
    Okie Pete, brEad and kevinrevin like this.
  5. Cliff Ramsdell
    Cliff Ramsdell
    @‘52 F-3 hows the trike coming along? It’s been a bit since I got back here and wanted to see how things are going.
    Cliff Ramsdell
    rbrewer likes this.
  6. '52 F-3
    '52 F-3
    Wow, work/life got busy and then I started enclosing a Carport... bla bla bla. I'm hoping to get back at it soon, just charged battery yesterday.
  7. bobbytnm
    bobbytnm
  8. Glad to hear that you will be working on this soon! Really cool project.
  9. '52 F-3
    '52 F-3
    Had the Trike out a couple weekends ago, got me motivated to get back on it...
    Not sure what this rear view mirror came off, but a couple bends and it fits and will work good. Also made this center console, radio bezel, shifter boot hole thing using a couple little pieces of the hood I used for the body. (had to make out of 2 sections due to size of shifter/clutch lever)
  10. '52 F-3
    '52 F-3
    Gonna make a shifter boot next, then think I'm gonna continue working on the firewall and carpet.
    Deuces, Okie Pete, brEad and 2 others like this.
  11. '52 F-3
    '52 F-3
    Getting very close to Initial inspection and being PA. Registered. Not actual plate I'll be using, but getting ready for it.
  12. That little dog should get the caffeine monkey off its back lol;)
    '52 F-3 likes this.
  13. '52 F-3
    '52 F-3
    Yes, him and myself... lol
    He's a long haired Chihuahua and really doesn't need any caffeine. But if he ever gets a chance, he's all over my coffee cup. I wish I had 1/4 of his energy...
    Okie Pete likes this.
  14. That's the big brother to my Avion. Made by the same guy. Powered by Citroen 2CV 602cc engine and gearbox. Has about 35 bhp at the wheels with the mods I've done to carb, ignition, compression and exhaust. Lightened flywheel helps too. Chassis is custom made for the car.
    I have a later 652cc Citroen Visa engine. Same air cooled flat twin but more modern design with 3 main bearings instead of two, aluminium nikasyl lined barrels and electronic ignition. I will fit that over the winter. Not much more horsepower (although an extra 5 is a big deal when you only have 35 to start with). The Visa engine has more torque and is less prone to over heating.
    Great job on your trike btw
    '52 F-3 and brEad like this.
  15. '52 F-3
    '52 F-3
    Paperwork sent from PA Enhanced Inspection Station to PENN DOT, to get a legal PA title finally.
    Did make a couple changes, the steering has always been a little quirky and the leaf springs stated to fan out slightly. I made some leaf spring clamps to keep leaves inline and also made a trackbar. It made a huge difference, makes it feel much more stable.
    Okie Pete and bobbytnm like this.
  16. '52 F-3
    '52 F-3
  17. '52 F-3
    '52 F-3
    Next going to work on reverse, these are parts I've collected so far. an ATV winch motor for power. thumbnail (3).jpg
  18. '52 F-3
    '52 F-3
    Just to update old thread, it took some work but got titled, registered and insured. 20221001_121802.jpg
    e1956v, Deuces, bobbytnm and 12 others like this.
  19. Carlmac 369
    Carlmac 369
    To quote Ray Wylie Hubbard:
    "Some things under heaven are cooler'n hell."
    That's one of them. The grille and how you used the fenders is absolutely amazing.
    Well done, can't wait to see it finished.
    Okie Pete and '52 F-3 like this.
  20. '52 F-3
    '52 F-3
    Couple interior pictures. Also replaced Lexan with Glass... much better...
  21. '52 F-3
    '52 F-3
    Almost sold at Spring Carlisle this week, but just not ready to let get of. IMG_20230423_164157.jpg
  22. Cliff Ramsdell
    Cliff Ramsdell
    How was the summer with the trike? Did you get much time on the road with it? How’s it running?
    Cliff Ramsdell
  23. AmishMike
    AmishMike
    Just read whole site- neat build. Look for it this coming summer. What are the seats from..
    SS327 likes this.
  24. '52 F-3
    '52 F-3
    The seats are from a Ford Transit van. (and are pretty small, not for X-large folks.)
  25. AmishMike
    AmishMike
    I have pair seats from Ford windstar((?) van middle row but at 50 pounds each a bit heavy for what I want. Trying to build light
