Evening all. I’m looking for inspiration on the build of my first early Ford. It’s a ‘29 Model A and I would love to see some shots of your traditional rolling frames. I will be running a ‘40 rear end with spring mounted behind and torque tube, dropped model A front axle with unsplit wishbones, 8ba flathead and ‘37 trans. F1 crossmember, pedals and m/cylinder. The plan is currently to run it as a chopped and full fendered car. What cool things have you done with your rolling A frames, please? I’m interested in all the detail I can get to help me on my way. Thanks, LT
39 Ford rear end with shortened torque tube, 39 engine and transmission, split bones, dropped axle with 40 brakes up front, 32 18” wires out back and 33/34 17” wires up front Sent from my iPhone using The H.A.M.B. mobile app
Stock A frame. 8ba flathead/1939 transmission. 1934 unsplit wishbone. 2” drop 33-36 axle. 48-52 f1 trans crossmember and pedals. 48-52 f1 steering box. 1940 brakes front and rear. 1935 rear axle bells with a rodsville quickchange. 26/27 model t rear spring. 42-48 rear radius rods. Shortened 1940 torque tube and driveshaft. 17” 1933/34 wheels up front 5.50-17 firestones. 18” 1932 wheels in rear 7.00-18 firestones
