Hot Rods I may have....................
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Jul 27, 2020.
  1. 34Larry
    34Larry
    I empathize strongly "may have" found and eliminated the miss in my 331 that I decided to chase down and get rid of, way last April. I've posted at least twice before that
    I had found it and got rid of it, only to have to eat my words and slink away into the darkness. I have yet to put it under load on the road and will after tidying up a few loose ends. It starts better, runs quieter, and sounds better and it ran good at 5500 in the drive, all this without the miss, (now I just jinxed myself), but as 31Vivky as reminded me, the proof of the pudding is on the road and under load. I finally smartened up and won't say what I discovered, and how I went about fixing the problem. I'm tired of way Crow tastes.
    This shot give a clue as to what I believe it was if you want to take a guess. may 13-20 3.jpg
    Stogy and scotty t like this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    All the coil wires bundled together ?
    Stogy likes this.
  3. alchemy
    alchemy
    It was the wire wheels and IFS, right? You got rid of those? ;)
    67drake, milwscruffy, bob b. and 2 others like this.
  4. das858
    das858
    I know , its the GM alternator !
    Fitty Toomuch likes this.
  5. winduptoy
    winduptoy
    To much shine to see the spark jumping from the coil high tension wire to one of the primary terminal posts? I always run one with a miss in the dark of the night to watch the light show
    Sent from my XT1585 using The H.A.M.B. mobile app
    belair, Stogy and alanp561 like this.
  6. lostone
    lostone
    from kansas
    The coil wires bundled together creating a magnetic field that was screwing with ya !
  7. brigrat
    brigrat
    from Wa.St.
    Is it HAMB legal to ask for advice (in previous threads) and not disclose the final results?
    Bandit Billy and Just Gary like this.
  8. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Gotta go with the coil wire bundled up with the others.
    Stogy likes this.
  9. 34Larry
    34Larry
    Not the wires.
    Stogy likes this.
  10. gene-koning
    gene-koning
    I don't like guessing games..... Is this a "before" or "after" picture?
    Did you move the coil?
    Stogy likes this.
  11. hoop
    hoop
    Ballast resistor arcing to rear of air cleaner base
    Stogy likes this.
  12. hoop
    hoop
    Stogy likes this.
  13. brigrat
    brigrat
    from Wa.St.
    You just added the ballast resistor or you didn't need the ballast resistor..................
    Stogy likes this.
  14. lippy
    lippy
    from Ks
    Windshield tint was too dark?
    Stogy likes this.
  15. Top radiator hose is off.
    D'you have to pull the intake?
    Was the intake gasket bad, sucking air? Or maybe a head gasket leak?
    Stogy likes this.
  16. inthweedz
    inthweedz
    Radiator hose leak at operating temp, squirting coolant on to the coil???
    Stogy likes this.
  17. Stogy
    Stogy
    :rolleyes:...A few Wild N' Crazy Guess's...Void in Coil Wire dust cover on coil end (see Arrow) exposing possible arcing issues,
    Second guess...
    I'm assuming a Vacuum hose is being used on aft Carb at fwd right side but capped off on front carb creating possible unbalance or...
    Thirdly...
    Possibly a coil wire internal breakage by side pull tension at coil due to existing shear condition induced by an overyanked wire...in the loomage for those with dirty minds...
    Lastly...
    and I think Coil Angle had possible ram...Get That...Ram-ifications time for Viagracoil...
    Coil acting up due to inner coil oil coverage...it was discussed recently in another Thread...
    May there be Burpless days ahead...nothing worse than a Sputtering Hotrod...:D
    winduptoy, VANDENPLAS and wheeldog57 like this.
  18. spanners
    spanners
    Flux capacitor installed incorrectly?
  19. 392
    392
    Like others have said. I’ve never seen a coil wire bundled together with other wires. Mount coil to rear area closer to distributor and don’t wire tie it to anything.
    67L36Driver likes this.
  20. 34Larry
    34Larry
    Answer is yes and replaced it and a "before".
    Stogy likes this.
  21. 34Larry
    34Larry
    Always had the resistor but replaced it with MSD 8 ohm resistor.
    Stogy likes this.
  22. 34Larry
    34Larry
    I did pull the intake but not because of the miss and there was no vacuum leak or head gasket.
    Stogy likes this.
  23. 34Larry
    34Larry
    Nope, but 100 point awarded for originality !
    Stogy likes this.
  24. 34Larry
    34Larry
    Sent ya a PM Stogy.
    Stogy likes this.
  25. 34Larry
    34Larry
    Thanks all for your posts. Today Tuesday the 28th and I still haven't had time to tidy up those loose ends in order to put it on the road. I know this will sound crazy to most of you but it just got to damned hot here in the Seattle area yesterday to spend time under a roof in a shop/garage. I know 94 degrees is pretty common summer temps for a large percentage of you but for us Washington hot weather wimps, coupled with all the humidity in the air here because of all the water around us, for this old man it was way to much. Cooler today, 84, but not enough for me. Oh, and the major portion of folks here do not have AC in their homes including me.
    Okay now back to the problem. All you pointing to the coil is in my opinion, right now at least, is where I have made the change. Originally mounted to the intake caused the coil to go bad because of getting repeatably way to hot ......I think.
    I have now moved a new MSD coil to the firewall and that along with an 8 ohm resistor are living in harmony with the new MSD distributor and wires. All the ideas everyone came up with are new ones to me and maybe anyone of those could also be the culprit, I really have no idea.
    So the loose ends are: cutting all the leads shorter and installing new terminals, cutting the coil wire to length. Draining the water from it and replacing it with antifreeze, changing oil and installing new Wix filter still on the road from Summit, (none of the parts houses here have a 1 qt. spin on for a 55 hemi.) Once that is done, a good road test will tell me if I was right, THIS TIME, or if I need to put on my dunce hat and sit in the corner like any idiot kid......................AGAIN :rolleyes:
    Stogy and Hotrodmyk like this.
  26. lonejacklarry
    lonejacklarry
    I learned this little tip back when I did my first engine rebuild. It is waaaay easier to clean up leaked water all over an engine than it is to clean up anti-freeze.
    Johnny Gee and Stogy like this.
  27. I had a miss and replaced 3 ignition wire sets before miss went away . The wires checked out Ok but they were the cause .
    Stogy likes this.
  28. wheeldog57
    wheeldog57
    Good luck 34, that motor (hehe I know. . . Engine) looks too good to run poorly. I hope your fixins today will make for many trouble free miles!!!
    Stogy likes this.
  29. Mr48chev
    As a comparison 94 in Seattle is 115 in Texas temperatures .
    It's always amazing that the smaller the problem the longer it bites you on the butt though.
    Johnboy34 and Stogy like this.
  30. 34Larry
    34Larry
    48 is that a true comparison or is this because everything bigger, (more) in Texas?
    Stogy likes this.
