Technical ***July 2020 Banger Meet Thread - Four Is A Good Number***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2020.
  1. Shutter Speed
    Shutter Speed
    I’m confused by your firing order...am I missing something?
  2. Jet96
    Jet96
    from WY
    Looks oky to me...
  3. Shutter Speed
    Shutter Speed
    3124? Am I just being dumb again?
  4. or 2431??
    He just had the plug wires in the wrong starting point.
    I have been playing with Mallory MG distributors and some marine Mallory's.
    It takes a little machine work but they look promising. Best of all, parts are available for them.
    It really screwed up a friend when he checked the firing order on the 2up/2down. 1,3,2,4 not to mention the cam grinder.........J
  5. Binger
    Binger
    from wyoming
    3124 is the same as 1243 or 2431 or 4312.
    Shutter Speed and winduptoy like this.
  6. Jet96
    Jet96
    from WY
    As long as they get it right at Cape Canaveral....
    Shutter Speed, winduptoy and poshdbs like this.
  7. railcarmover
    railcarmover
    I see what you did there...
  8. winduptoy
    winduptoy
    poshdbs and Shutter Speed like this.
  9. burl
    burl
    from Minnesota
    I was really confused before i want back and checked everything.Understand i am running a modified mallory single point distributor that was made to run in fork lifts.When i made the shaft to connect to the oil pump drive it was not machined relative to the orientation of the rotor in the distributor.For some lucky reason it worked last fall when i started this used motor.I have a dual point Mg with tach drive that i need to modify and i will make sure the orientation is correct.
  10. burl
    burl
    from Minnesota
    Working on your test parts hope to have it done soon.Shop has been very busy with covid stuff.
    akkhotrod likes this.
  11. winduptoy
    winduptoy
    Cool, but take care of business first
  12. Bigcheese327
    Bigcheese327
    Where can we learn more about said chassis? Sounds neat. You don't see enough column shifters in hot rods.
  13. Shutter Speed
    Shutter Speed
    Yep, just bein’ dumb again...can’t help it!
    My distribuiliteracy kickin ino_O!
    Guess it depends on how you look at it.
    Preciate you straightening me out!
    Can I still play? I’ve got plenty more where that came from:rolleyes:.
    Binger and barrnone50 like this.
  14. Gary in MN
    Gary in MN
    So this must be ........... 1 2 4 3 x 2 ....... gee this online learning is great. Gary DSC01711 (1024x576).jpg
  15. Savage Coupe
    Savage Coupe
    from Washington
    B95A1414-EB45-4C1E-8B80-04CCE0E4FD31.jpeg Top pic is my flywheel. Bottom pic is what I took to the machine shop for reference. 65DB3544-B8FE-4B3B-ADC1-19DC6903A52C.png Hello fellas,
    Pretty new to the HAMB, hope I’m posting this correctly. I’ve read some older threads saying there was an error in some instructions on lightening a banger flywheel? It’s got me a little worried on the flywheel I had lightened. I read in the Brierley book that you can take it down to a 11 1/16 diameter and take some material off the back side too. I took the dimensions and some pictures to a local machine shop. I’m concerned about the material he took off the back side, I feel like he took too much close to the crank? What are your thoughts? I’m thinking of building a scatter shield but I also don’t want to risk destroying my engine and tranny. Please let me know what you think thanks.
    Binger and Old Dawg like this.
  16. Yeah too cool, nice dist drive setup.
    Is that a two port rocker arm McDowell head?
    John
  17. Gary in MN
    Gary in MN
    Hi John: not a two port rocker arm McDowell. It's a obscure 8 Valve cross flow Model "T" head on a 1927 "T" block. Gary
    Old Dawg and winduptoy like this.
  18. studebakerjoe
    studebakerjoe
    Gary, any more info on those dual distributors?
  19. Kiwi 4d
    Kiwi 4d
    Still futzing with headers . Getting closer day by day but slow. Hope do get some decent numbers when we are done.B block to go in a 32. The head was part of a deal where we had to take an original cragar along with a new Serr head , sold the original head but kept original rocker cover , kind of want it to look period to match the used look of the 32. Now we have a half price new head, all ported and cleaned up.
    Definitely not my idea but my engine guys ,after lots of His research to use 348 BBC pistons , not W head But BBC bus and truck pistons to get compression up after we milled the head .080 .
    858A53D9-0564-405E-83E8-FAD316C733C1.jpeg 43660F98-64CE-4147-8FA1-87371A8A8FA6.jpeg 5665C4D4-9F2F-4D44-AC28-A17BF2C96F1D.jpeg
  20. Gary in MN
    Gary in MN
    Bosch China knock offs from ebay $ 37.00 each fits VW, counterclockwise rotation 20 degrees advance at the distributor. I machined them to fit 1920's Dodge 4 cyl. dist mounts. Gary
  21. Gary in MN
    Gary in MN
  22. railcarmover
    railcarmover
    Gary,if you go to the The Samba.com,the big Vw forum and contact a guy named Glenn Ring he rebuilds vintage Bosch cast iron Vw distributors..the real deal,those cheap 009's from China will bite you
    GuyW likes this.
  23. Binger
    Binger
    from wyoming
    I cant help much with the Flywheel issue but Welcome to the HAMB and the banger meet!
  24. Gary,
    hell, I didn't even notice the block or flywheel housing, too interested in the dist drives.
    Does the shaft drive from front run at crank speed or cam speed?
    John
  25. Gary in MN
    Gary in MN
    Crank speed , but there is more going on. Let's say crank ( 25 t )speed is 500 rpm....cam gear ( 50 t) down to 250 rpm ... second crank gear ( 25 t) and back to 500 rpm.... the 90 degree 1920's Dodge dist housing and gears, ( 9 t ) on the shaft and ( 18 t) on dist lowers the dist speed to 250 rpm Gary DSC01629 (1024x576).jpg
    Jet96, winduptoy, burl and 3 others like this.
  26. Gary,
    That is exactly the info I was looking for. The Mod"A/B" governor housing is crank speed and so are most side drive aircraft mags. That is a very nice setup.
    John
  27. The F.A.S.T. Time Trials at the Historic Santa Margarita Ranch scheduled for this weekend (Sat. the 18th) have been cancelled due to "The Gov" re-closing Calif. Though the quarterly F.A.S.T newsletter will no longer be published (The Mosher's couldn't find anyone to takeover the chore); Time Trials will resume after the 'Pandemic" subsides!
    As a postscript (not that it matters to "Four Bangers") here's what politicians do to (in this case Motorsports) to make their fortunes "At the Public Trove",once they get control! An interesting read:
    https://journal.classiccars.com/202...034073f4f5a2e4dfbc39d7283b2cb89d5189540b69330
  28. Crazydaddyo
    Crazydaddyo
    Sad news both for FAST and Laguna Seca. That tracks future has always been teetering on a precarious cliff. Back when I raced motorcycles there in the late 80's there was pressure from local residents to close it down. It would be a shame to lose this asphalt jewel.
    Jet96, winduptoy and Old Dawg like this.
  29. Savage Coupe
    Savage Coupe
    from Washington
    0B3AAFBC-6935-440C-92C9-0D2E407E929A.jpeg F20293B9-7008-4A24-AC82-984835711FCF.jpeg 41EBF2DA-9D80-420C-B2A1-793DAB6CDF05.jpeg 7A6535AB-0B68-4E7A-B74A-04EF60E41D3E.jpeg Hello,
    My name is Hance. I’m new to the HAMB. I like banger powered hot rods.
    camcrusher, GuyW, klawockvet and 14 others like this.
  30. railcarmover
    railcarmover
    Part of being older than dirt is the powers that be allow you to train the youngins.I've got a good one,Adrian is a natural,learns it the first time and does what he's told.Another part of the game is they look the other way when you bring something from home in to work on.So we both do our thing,he has a jeep, a Vw and a dyna harley but he always asks what I'm doing on the A..today he shows me an ad,he 's buying a 29 sport coupe banger project..corrupting the young man ? perhaps..
    burl, Binger, poshdbs and 2 others like this.
