Technical First attempt at filling the roof on my 35 5W. Advice needed.
Discussion in 'The Hokey Ass Message Board' started by Do it Over, Apr 17, 2020.
  1. JOHN H EDGE
    JOHN H EDGE
    80BF6FF2-E05C-404C-AAC0-C4A6F423620E.jpeg F1C2C6BE-955A-4D73-AF4E-256CE279FD61.jpeg Great determination and fine job
    Maybe some inspiration
  2. Do it Over
    Do it Over
    from NYC, NY
    Very nice. If NYC had decent roads I could go for that stance but I'd be sure to leave pieces on the road if I did. Sweet ride. Black is awsome.
  3. flamedabone
    flamedabone
    I think you have it licked. That poor little car suffered at the hands of someone who never should have touched it, but you have her back on track.
    Nice work, -Abone.
    Tman, Do it Over and brEad like this.
  4. JOHN H EDGE
    JOHN H EDGE
    Love seeing work like this being done and the lessons learned
    Went to one of Ron’s metal working classes at Cecil Taylor’s
    Shop and both are metal masters and it was amazing how different they would attack the same problem and end with beautiful pieces that looked the same. One used the most basic tools and the other all the newest tools. Wish I was 20 years younger to master some of their skills. Please keep the post going
    I love setting in our shop and studying our 36 3 Window and how it looks in motion when setting still
    TagMan and Do it Over like this.
  5. Do it Over
    Do it Over
    from NYC, NY
    I think I've got enough tacks I'm place now. Gonna get to sleep early so I can be fresh when I lay down the lead tomorrow. Got a very slight oil can at the angry face area. I'll lay a bar or three of lead on it to stiffen it up.
    20200626_181949.jpg 20200626_181938.jpg 20200626_181905.jpg 20200626_172646.jpg 20200626_183512.jpg
  6. Do it Over
    Do it Over
    from NYC, NY
    My new neighbors are at it again. Had to get dressed to come out and ask them to be reasonable. So here it is 5am so I figure ill get a super early start. Man I so want to get out of NYC. When the Lord comes to take me I'd like to go in peace and quiet not booming suck ass kid music.
    kidcampbell71 and Hnstray like this.
  7. Do it Over
    Do it Over
    from NYC, NY
    Did a short section of leading. A quick fill and file so I'd know how much lead to put down. This test showed me I put on too much. I used half a stick and wasted 20% of what I used. Now inside to make some spam and eggs and give my dog her meds. 20200627_073841.jpg 20200627_073852.jpg
  8. Do it Over
    Do it Over
    from NYC, NY
    This leading business sure is hard work. A full day at it and I'm still not done. I'll fill the deep depressions with lead but will use filler to smooth out the roof.
    20200628_201132.jpg 20200628_200537.jpg 20200628_200525.jpg 20200628_200032.jpg 20200627_174750.jpg 20200627_171826.jpg 20200627_171822.jpg 20200627_171818.jpg 20200627_145157.jpg 20200627_145152.jpg 20200627_135503.jpg 20200627_135450.jpg
  9. You are leading it without fully welding it up?!
    Blue One and redo32 like this.
  10. Do it Over
    Do it Over
    from NYC, NY
    Got plenty of solid tacks on it less than 1/2" apart.
  11. redo32
    redo32
    I think I know what Tman is thinking and I would agree. Then I remembered this is a traditional site and Do It Over's efforts are better than most traditional cars done 70 years ago. How well will it hold up and what will it look like in 40 years? Pretty sure I won't be around to critic it.
  12. thank you so much for posting this
    Do it Over likes this.
  13. I understand the tack weld concern. I have melted a lot of lead out of spot welded seams. Its gonna out live most of us anyway.
  14. Do it Over
    Do it Over
    from NYC, NY
    OK, I submit. Leading is most definitely a practiced art and one I'm not cut out for. Plan to spray some Phosphorus acid on the rust to deal with the old rust, wipe,, water rinse,, baking soda spray, water spray and wipe again. Going to do a coat of fiberglass filler in the deeper recesses and around over the lead. Should I use All Metal instead of the Eagle Claw ?
  15. mlagusis
    mlagusis
    In my opinion, I would use the all metal to fill the deep spots. Then put a coat over the whole roof of the rage and block it all out.
  16. 48fordnut
    48fordnut
    WoW, what a read. Great work.
  17. Blue One, chopped and Do it Over like this.
  18. DIYGUY
    DIYGUY
    from West, TX
    I’ve used all metal but seems like I had adhesion problems later on. Been using duraglass since.
  19. nor6304
    nor6304
    from Indiana
    I used All Metal & felt like there was adhesion problems also I really like Rage Gold I would use that if it was my choice
    Blue One and Do it Over like this.
  20. Do it Over
    Do it Over
    from NYC, NY
    Back at it. It's prepped and ready for frosting except for to soft spots. I've tried a couple times to tighten these areas up but only managed to turn them into sink holes. I decided to glue these two patches underneath. My thinking is that two layers of steel will be much stiffer than the one. Figure I got nothing to loose.
  21. sometimes an over shrunk area can act like an area that needs shrunk.
    try just hammer and dolly work on that area an see if it changes
  22. Do it Over
    Do it Over
    from NYC, NY
    Understood. I tried that twice but ended up with the same result. I believe if I had put more crown in it with the English wheel I would have avoided this problem. Lesson learned ;)
  23. Do it Over
    Do it Over
    from NYC, NY
    Works like a charm :) . Lots of adhesive. Lots of pushing up. Lots of turning/twisting/pressing. 20200718_143430.jpg 20200718_144320.jpg
  24. Do it Over
    Do it Over
    from NYC, NY
    Let the next level of begin.
    kidcampbell71 likes this.
  25. Do it Over
    Do it Over
    from NYC, NY
  26. Dick Stevens
    Dick Stevens
    You've come a long ways getting to this point, and learned some new skills along the way! Good job, now is when you need a template to get the final shape nailed down with it maintaining a consistent change in the curvature even if it is slightly off from what Henry built.
  27. Do it Over
    Do it Over
    from NYC, NY
    Think I'm just about done now. A little detail work here and there but its smooth enough to move on to the rest of the work.
    20200801_192146.jpg 20200801_192128.jpg 20200801_192100.jpg 20200731_205701.jpg 20200801_192025.jpg 20200731_191845.jpg 20200731_191833.jpg 20200731_191828.jpg 20200727_211500.jpg 20200727_211422.jpg 20200727_205314.jpg 20200727_205305.jpg 20200727_205252.jpg 20200727_153039.jpg 20200727_153033.jpg 20200727_180559.jpg 20200727_180554.jpg 20200727_180617.jpg 20200727_180624.jpg
  28. Happydaze
    Happydaze
    Good to see your progress. Keep it up! You're putting me to shame!
    Chris
  29. Do it Over
    Do it Over
    from NYC, NY
    Its all done but the crying, mostly :) . Parked at moms next to my long time sleeping 429SCJ Mach1. Got to take in a paying job for a bit. Next on the coupe will be figuring out how to remove the beat up tail panel and repair it.
    20200806_184314.jpg 20200806_184325.jpg 20200806_184333.jpg 20200806_184349.jpg 20200801_192251.jpg 20200801_192242.jpg
  30. patterg2003
    patterg2003
    Congratulations on getting the roof done. Your effort and care is the definition of perseverance. The tail pan hopefully will be a little kinder.
    Do it Over and loudbang like this.
