Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Love that bead around the shock mount! Great detail & thanks for sharing the tooling to make it!
  2. Marty Strode
    Marty Strode
    Paul, the bead roller tech is pure genius ! That's going to be a great car.
  3. Paul and loudbang like this.
  4. 51box
    51box
    from MA
    Really clever idea for that notch piece!
    kidcampbell71, Paul and loudbang like this.
  5. Perfect work, flawless Paul.
  6. loudbang
    NICE tight radius on that bead. :)
    kidcampbell71 and Paul like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    pure genius......
    loudbang, kidcampbell71 and Paul like this.
  8. Paul
    Paul
    Editor
    E brake handle bracket
    Make cardboard into steel
    hack original bracket
    Weld two together
    Stogy, Tim, Shadow Creek and 8 others like this.
  9. Paul
    Paul
    Editor
    pulled the rear today
    welding the brackets to the housing
    cleaned inside the housing
    straightening the housing
    reassembling the rear swapping the 3.08 posi for the 3.42 posi
    pressed the left hand thread studs from the left axle and pressed some right hand thread studs in their place
    the rear back in the car
    it will have to come out again to go through the pumpkin, axle bearings, seals, brakes etc.
    but it's all welded and straight
    IMG_20200618_094638.jpg IMG_20200618_112918.jpg IMG_20200618_134010.jpg IMG_20200618_141226.jpg IMG_20200618_142732.jpg IMG_20200618_142746.jpg IMG_20200618_145206.jpg IMG_20200618_162231.jpg IMG_20200618_162220.jpg
    Stogy, Dirty Dug, 51box and 14 others like this.
  10. Paul, curious about how far off the rear housing was after the welding and your process for straightening. Could you elaborate a bit. I am going to be visiting this issue with my 9 inch this fall.
  11. Paul
    Paul
    Editor
    The ladder bar and spring brackets get welded all the way around.
    I break the circumference into quarters,
    weld one quarter then the opposite quarter,
    then between the end of the first weld to the start of the second weld ,
    then the end of the second to start of the first. All traveling in the same direction.
    This balances out the heat warp somewhat.
    Most of the heat warp here was caused by the shock mounts having heat concentrated on one side of the tube.
    You can see it in the fourth picture.
    There is about a 1/16" gap at about 10:00.
    I heated the tube in about a dime sized spot opposite the shock mount to cherry red and quenched the spot with a wet rag.
    Checking movement after it was cool enough to rest my hand on the spot.
    Repeated that adjacent to that spot.
    That seemed to square the end up pretty good but it needed to move over more so I heated a spot inboard of the ladder mount,
    Then above and below that one. You can see where I heated the spots in the sixth picture.
    Again moving slowly and checking between each heat/cool cycle.
    Until the end bushing just slips into the axle bearing seat. Seen in the fifth picture.
    Both sides reacted about the same.
    I picked up the kit years ago at a 4x4 swap meet with bushings to fit a 9" Ford rear.
    Later I had bushings made to fit the Olds center.
    I cut a spare carrier with a grinder to make it a little easier to work with.
    All pretty basic hot rod stuff.
  12. Thanks for tutorial Paul. Makes a lot of sense and very helpful. Already feel better about tackling my 9 inch:)
    loudbang and Paul like this.
  13. Paul
    Paul
    Editor
    dang, where does the time go?
    been busy doing non car stuff,
    finally got a couple hours in on the old Hulk
    dug out the last of my Olds/Pontiac brake junk
    picked the best drums and backing plates,
    blasted them and shot them with Zero-Rust non flat,
    because that's what I had..
    Stogy, brEad, AndersF and 4 others like this.
  14. Paul
    Paul
    Editor
    I like the look of the straight up early windshield
    but it's too rough
    thought I'd try some later, '25ish stanchions and lower frame,
    because I have them and they are in a bit better shape.
    the stanchions lean back a few degrees
    but the lower frame is a bit short.
    so I hacked up a spare upper frame to use a donor
    and extended the vertical legs on the original
    to make it about 3-3/4" taller
    and chopped the tops off the stanchions to fit
    IMG_20200702_122501.jpg IMG_20200702_122745.jpg IMG_20200702_123219.jpg IMG_20200702_125747.jpg IMG_20200702_140437.jpg IMG_20200702_140441.jpg IMG_20200702_141807.jpg IMG_20200702_141828.jpg
    Stogy, brEad, AndersF and 2 others like this.
  15. Paul
    Paul
    Editor
    swapped the dirt tires for street with caps borrowed from the '27
    and rolled it out for a walk around.
    it's very important to stand back and check the overall look
    every step of the way
    before it's all set in stone.
    IMG_20200702_161718.jpg IMG_20200702_161517.jpg IMG_20200702_161909.jpg IMG_20200702_161854.jpg IMG_20200702_161826.jpg IMG_20200702_161736.jpg IMG_20200702_161454.jpg IMG_20200702_161433.jpg
  16. That thing is the business @Paul!
    loudbang, Paul and kidcampbell71 like this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    pure genius!!!
  18. Dick Stevens
    Dick Stevens
    The visual is magnificent!
  19. 31Apickup
    31Apickup
  20. Paul
    Paul
    Editor
    Thanks guys!
  21. Old-Soul
    Old-Soul
    I for one appreciate the "unconventional" use of OEM shocks.
    In a world of guys running off the shelf Monroe shocks, Paul is living in style.
    Atwater Mike, loudbang and Paul like this.
  22. Paul
    Paul
    Editor
    Thanks, I do like the ride quality of hydraulic verses gas charged.
    Atwater Mike, Old-Soul and loudbang like this.
  23. I’d never seen this photo of Gene Chan’s car until it popped up on IG today so I thought I’d post it here! CB73DCDD-11C3-4619-AE43-10A05260A8BF.jpeg
    brEad, loudbang, AndersF and 4 others like this.
  24. Paul
    Paul
    Editor
  25. Paul
    Paul
    Editor
    I have three relatively straight but rusty doors,
    If a better one doesn't turn up soon one of them will have to be fixed.
    loudbang, kidcampbell71 and Stogy like this.
  26. Paul
    Paul
    Editor
    I need a decent door before stitching the body together.
    I need the body panels at least tacked together before the floor gets fabbed.
    But should locate the pedals and battery box before the floor..
    Sounds like it's time to work on brake and clutch pedals..
    RICH B, brEad, El Hueso and 5 others like this.
  27. Paul
    Paul
    Editor
    Nah, I'll work on the pedals later.
    so I started fixing on the door.
    Of the three, I chose the one that came on the Hulk.
    Missed a photo op but cut a piece of 20 gauge steel,
    and used the English wheel to put a slight crown in it.
    Made a paper pattern following the inside of the bead
    and transferred that to the steel and rolled a bead around.
    Bent up an outer door piece.
    Blasted the door where the new will meet the old
    and cut the rusty stuff away.
    Clamped the new behind the old and scribed it to cut for butt joint.
    Tacked it in place.
    Tacked the new outer part to the door.
    Welded all.
    started hammer/dolly/filing...
    It's going to take a bit of work to make it nice
    but it should be ok..
    enough..
    That's it for today..
    IMG_20200706_155628.jpg IMG_20200706_155807.jpg IMG_20200706_160324.jpg IMG_20200706_160512.jpg IMG_20200707_111001.jpg IMG_20200707_122029.jpg IMG_20200707_122036.jpg IMG_20200707_122401.jpg IMG_20200707_123137.jpg IMG_20200707_123920.jpg IMG_20200707_135355.jpg IMG_20200707_135931.jpg IMG_20200707_143334.jpg IMG_20200707_165611.jpg IMG_20200707_165618.jpg IMG_20200707_165624.jpg IMG_20200707_175225.jpg IMG_20200707_181548.jpg
  28. Paul
    Paul
    Editor
    Stole an hour to get out to the shop
    Cleaning up work done on the door
    Still looking for a nice original but
    this one is just about ready for fitting.
  29. Stogy
    Stogy
    :rolleyes:...T-riffic job...;)
  30. alchemy
    alchemy
    I've got a pile of those doors. How many you need?
    Just kidding. Nice work!
