Technical Bending drip rail
Discussion in 'Traditional Hot Rods' started by cpldale, Mar 10, 2020.
  1. cpldale
    cpldale
    from Naples, FL
    I needed to replace the drip rail on the passenger side of my Model A Vicky. I found replacement drip rail from Speedway. Nice quality and it comes in 2 STRAIGHT six foot sections. Now, the fun begins. I have to bend the rear section of it. I'm sure there are many ways to bend it but this is how I did it.
    1. Remove the old drip rail section without bending it.
    2. Traced the inner curve on plywood to make a buck.
    3. I left an extra 3 inches of drip rail past where the bend ends to be able to screw it to the buck.
    4. I found a pair of parallels from my mill that were a tight fit within the drip rail. Any piece of steel that fits the rail should work. These keep the drip rail from collapsing when bending it.
    5. Gently heat about a 3 inch section of the rail to start the bend. Quickly slide the parallels into the hot section and gently bend the rail to the buck.
    6. Repeat this process until the contoured section is completed.
    7. I wire brushed the charred area and trimmed off the excess rail.
    I hope this may help someone facing the same situation. 20200304_113012_resized.jpg 20200310_123352_resized.jpg 20200310_123419_resized.jpg 20200310_124851_resized.jpg 20200310_125439_resized.jpg 20200310_132806_resized.jpg
  2. Nice, I need to do the same thing on my 32 sedan. Thanks for the how too!
    343w likes this.
  3. continentaljohn
    continentaljohn
    Great job and thanks for sharing
  4. Baumi
    Baumi
    Thanks for sharing, that´s some great info.... Now the only thing left for me to figure out is how to have 2 6 feet long driprails shipped here....
    51 mercules likes this.
  5. Chief 64
    Chief 64
    This is the kinda thread that makes the H.A.M.B great! Thanks for taking the time to post.
    dirt t and 6sally6 like this.
  6. sloppy jalopies
    sloppy jalopies
    Way to go... great tip...
    I bought straight gutters for my 30 coupe.. saved $20. …way too much work…
    your tip would have really helped...
    without your tip I would pay them the extra $20 to get the already bent gutters...
    … go cpldale go !
  7. Thanks for the info. Although I don't need drip rails on my roadster, I appreciate people like you that are so forthcoming to help others.
    Tow Truck Tom and Atwater Mike like this.
  8. cpldale
    cpldale
    from Naples, FL
  9. fabricator john
    fabricator john
    from venice fl.
    nice job!!!!
    fabricator john
    miss you dad
  10. Duke
    Duke
    I have to do the same thing, thank you!
  11. 343w
    343w
    I'm in the same boat with my 32 tudor, thanks for posting the plan of attack!
  12. Now several years I tried this on a coupe. The original gutters had a retainer. You nailed it in place. Then fitted the drip rail to it. These don't snap on to their retainers do they. So I'm wondering how to add the nails. Never figured this out on my coupe. Finally found some real drip rails.
  13. cpldale
    cpldale
    from Naples, FL
    The drip rails on my Model A Vicky were spot welded on. When I removed the original rails I drilled out the spot welds. When I installed the new rail I welded them on thru the holes from the old spot welds.
    Atwater Mike and olscrounger like this.
  14. 40ragtopdown
    40ragtopdown
    Thanks for the tip.
  15. olscrounger
    olscrounger
    Great job. I made a set for a 40 Woody in a similar fashion but they were much shorter and a lesser bend.
  16. Chris Casciato
    Chris Casciato
    Yes thank you for posting this I need to do this same thing on my 32 Plymouth coupe, great job!
  17. Kan Kustom
    Kan Kustom
  18. is that a metal drip rail? All the repo stuff i've ever seen ( & bought) Were aluminum
  19. Great little tech tip
  20. cpldale
    cpldale
    from Naples, FL
    It's a steel drip rail. Speedway carries it and thier price is better than most other vendors.
  21. cpldale
    cpldale
    from Naples, FL
  22. cpldale
    cpldale
    from Naples, FL
  23. Koz
    Koz
    I called Speedway and talked to two different techs. Neither could find the stuff even after at least 20 min. on the phone. Cpldale gave me the part number and they had it on the way instantly. For those interested, 9111932, $81.00 for two six ft. lenghts. I haven't recieved it yet but I believe this is the United Pacific stock or an offshore repop of it.
  24. cpldale
    cpldale
    from Naples, FL
    It is made by United Pacific and Speedway has the best price.
  25. Tim
    Tim
    from KCMO
    Does it have any shape to it? Kinda looks like it’s just C channel?
    fantastic tip on bending it though, I’ve been trying to figure out how to bounce back and forth between sides with a shrinker stretcher with out warping it all to shit this would be way easier
  26. cpldale
    cpldale
    from Naples, FL
  27. khead47
    khead47
    Aluminum IS metal !
    V8-m, Fortunateson and 2OLD2FAST like this.
  28. cpldale
    cpldale
    from Naples, FL
    Up to the top again.....
    Atwater Mike likes this.
  29. Atwater Mike
    Atwater Mike
    @cpldale: Thanks for bringing this thread back. Great info/tech!
  30. cpldale
    cpldale
    from Naples, FL
    Bring her up....
