I'm hoping that some one might be able to take some diagonal measurements of their 29 tudor sedan for me. I need measurements between the back of the door area "B" pillar to the A pillar on the opposite side, and possibly the distances between the A pillars and the between the B pillars side to side. I know my body is out of square some but I'm not sure where or if one side is correct and the other is wrong or the other way around. Thanks for any help you can give.
If it's a stock Model A frame, you should be able to compare the frame bolt holes from this drawing with your frame. Line up your body with the correct frame holes. http://www.wescottsauto.com/WebCatalog/Tech/FrameDiagram1928-31.pdf
