Hello. Welcome to a new video from Mart's Garage. This week I tackle a problem with my radiator. It's been running too high a pressure and has bowed the top tank. Follow along as I not only fix the leaks, but add strengthening ties to better contain the pressure. The problem was caused by a faulty pressure cap, overpressuring the system, but as this rad was not originally built to be pressurised, I still added the ties. Ok, enough yakkin, let's get on with it! If you watch the video directly in youtube the like and subscribe buttons become available. Please click on these as it helps the channel's visibility in youtube's algorithms. And if you like it give this thread a bump as that helps a lot, too. Thanks for watching and taking an interest. Mart.
I had a 4lb cap on my '47 and you could hear the tanks expanding and contracting. I didn't test to see how much pressure it was making (old Speedway improved water pumps), I just went for a zero psi cap and that solved it. BTW, I though you had a pet Chinchilla on your shirt until I realized it was your mic .
Yeah, 1old, That was an option. I don't know, I just wanted to try and make it work. If the vent was still there at the top I might have tried no pressure. That is my pet chinchilla. I enjoyed checking your cars in your link, btw. Quite a mix.
Thanks Mart. I'm going to imploy your fix when I swap Flatheads in the '47, it's going to have the stock Merc fan and I would like the extra boiling room of a 4lb.
It's all about pounds per square inch, typically early Ford top radiator tanks are not designed for 13 or 15lbs of pressure, this is why late model radiators have small tanks, when I had an original type radiator in my coupe with a Cleveland, every couple of years I would get the top tan leaking with a 13lb cap, changed the radiator to have modern small top tank, problem solved. The attempt to stop the tank expanding will more than likely help a lot, it still doesn't solve the issue of the huge pressures involved in these large tanks.
The main problem was that the so-called 4lb cap was made wrong and was pressurising to 10 lbs or more. I ordered a new one and it was exactly the same. I ordered a different brand and that was the opposite. I had to space it out just a bit to seal. Hopefully it will be much closer to 4lbs now and with those mods in place it should be able to cope.
