Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. x77matt
    x77matt
    Not sure I quite understood what you were asking, but I used a repro rear floor panel section, and installed it with rivets so it had a stock appearance . Of course I had to cut a hole for a model A rear x member though.
    brEad and loudbang like this.
  2. x77matt
    x77matt
    Did some work on the drivers door bottom to tune up the gaps and then hit it with a few coats of feather fill g2. Going to spend the weekend doing some blocking...
    5B036A1A-8C09-4816-AF4F-4A9FDBCDCFD2.jpeg 763C86BC-BE00-4615-B753-3774250BCC2D.jpeg 7676F0C5-7C24-4857-8A02-49DD6A5BE084.jpeg
  3. fegsta
    fegsta
    Sorry if I wasn't clear, I read early on in the post somebody was selling two original rear floor panels, I wondered if you used them?
    Sent from my KOB-L09 using The H.A.M.B. mobile app
  4. x77matt
    x77matt
    Oh- I ended up not buying them as the shipping was a killer.
  5. RodStRace
    RodStRace
    Check Fastenal and Greyhound for shipping.
    x77matt and loudbang like this.
  6. -Brent-
    -Brent-
    Just started in on this build thread! Glad to have stumbled upon it.
    What a welcomed discovery!
  7. fegsta
    fegsta
    Tell me about it shipping kills and In port duty. But if you want it bad enough you don't have a lot of choice. Your roadster is nicely coming on, I wish I had an original body, I have a brookville and going towards a 60s style.
    x77matt likes this.
  8. fegsta
    fegsta
    Your build thread is very inspiring, all the details. I like your choice of colour.
    x77matt likes this.
  9. fegsta
    fegsta
    Hope to see more of your build do you do paint and electrics?
    x77matt likes this.
  10. x77matt
    x77matt
    thanks for the comments! Yep- I’ll be painting in about a month. For wiring I have cloth covered wire and it will be old school with wax string ties rather than plastic zip ties. Stay tuned!
  11. x77matt
    x77matt
    Been doing more wet sanding and priming. I’m down to 600 and 2k high build. It’s looking pretty straight.
    also got the motor buttoned up. This will be a temporary motor until I can afford to build a full 284 stroker. This is an old rebuild that had good bores and bearings:
    1940 block with 8ba front cover
    Skip Haney water pumps
    3 5/16 x 3.75”
    Potvin 3/8 can
    Oversized valves
    H&H Scot blower
    Old, near NOS SAE heads that I polished
    Converted Mallory yc
    90D3CC84-4DB0-4A17-A5AA-650DC71B3D83.jpeg 16D7D4D8-2A18-45A4-9378-C61112FADE62.jpeg 722C3365-397E-4900-AA7D-8303958B32A5.jpeg 0286B9D8-B61A-4FFA-9748-82BB31B02E2A.jpeg 2FC1FCF7-5EE0-439E-AB18-04CB5A443B31.jpeg 0F617F23-BC1F-4B42-9882-A3B7D55D9022.jpeg 74981192-2FA2-4316-A96D-C2BB2CBF531F.jpeg
    Dirty Dug, brEad, loudbang and 4 others like this.
  12. x77matt
    x77matt
    Can someone with one of these H&H blowers please let me know the belt part number for the 2 drive belts??
  13. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Hot Dam Matt I really like your build. Wish I could afford to step up to a blower like yours for my French FH build. Oh well maybe someday.
    loudbang and x77matt like this.
  14. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    x77matt likes this.
  15. x77matt
    x77matt
    thanks! I got really lucky on the blower deal. It was a pre-owned setup originally sold in 2007 to a guy in Pennsylvania. Sat on a shelf and never was actually ran. It was still a ton of money but significantly less than a new setup. I figured it being a real Henry roadster, I wanted to do something really special and jumped on the deal before I could talk myself out of it.
  16. x77matt
    x77matt
    Thanks a lot- I ground a deep V groove in the bones and did several passes. This was the second to final pass.
    wheeltramp brian and loudbang like this.
  17. fegsta
    fegsta
  18. solidaxle
    solidaxle
    from Upstate,NY
    If H&H can't help you. To save yourself a couple of trips to the auto store. Measure it with a rope and buy a couple sizes longer and shorter. You can always return the unused ones. Belts come in 1/2 in lengths
    Is the little idler for the waterpump belt to clear the dizzy? If so that's a heck of a bend coming off the blower pulley.
  19. solidaxle
    solidaxle
    from Upstate,NY
    Are you driving the waterpumps off the crank or blower pulley? It looks like there maybe third smaller sheeve spot on the crank pulley.
  20. x77matt
    x77matt
    So, the water pumps are driven off the rearward most crank pulley and the outer 2
    Drive the blower. The small idler is only for the water pump circuit. The blower pulley is a 3 sheave setup but the outermost one is not used. I may have a new pulley made that turns the un-used pulley section into a blank to bolt the fan to.
  21. solidaxle
    solidaxle
    from Upstate,NY
    Ok, Looks like a nice setup. With the blower shaft offset from the center of the motor, it maybe problematic with clearances for the fan.
    Are you running a hood?
  22. Fun thread. I like the entire build.
  23. x77matt
    x77matt
    Actually on the Scot - the blower pulley is pretty well centered so I’m going to see what I can get away with.
  24. x77matt
    x77matt
    586B4531-4D5C-42CA-82DB-0E8A1E3D1DD5.jpeg AA2D064E-E22B-4411-982C-004A9908F644.jpeg Hey guys- The good news is it’s finally got some color on it: 1969 Ford Royal Maroon which is close to the 1948 ford Monsoon Maroon I was after. The bad news is that I still have a lot of wet sanding and buffing to do. Here is the post game highlights:
    Runs=2
    Sags=1
    Butt into decklid=1
    Hose into paint=2
    Gnats=hundreds
    Big fat beetle that crawled it’s way down the entire quarter before I ejected him=1
    Orange peel= not an embarrassing amount
    Wet sand and polish ahead of me=yep
    Body=straight!!
    Color=badass!
  25. Way to go Matt! Looks great.
    x77matt, loudbang and fegsta like this.
  26. fegsta
    fegsta
    Looks real good .Have you got lots of nibbler pads there good for the little marks bugs
  27. 51box
    51box
    from MA
    Very nice job, that maroon looks perfect on the roadster! What a great sense of accomplishment it is to see some color after all the hard work.
  28. loudbang
    Great color choice. That is separates a god painter from a mediocre painter ..... how they deal with all the little boo boos. :)
    brady1929 likes this.
  29. Killer color!
  30. is that idler just bolted to the front of the block?
