I want this look for my 49 Buick. I think what i would have to do is have 2 front bumper to piece together. Any other ideas? Anyone seen this done? https://images.app.goo.gl/cBrRJk7fZE9Dr5WL9
Found this image of an original looking riviera without the flat center Sent from my iPhone using H.A.M.B.
It requires cutting and welding at least 2 Buick bumpers together. Take a look at 1949-51 Buick front bumpers for sale on Ebay.
He stated on the video that Ogden Plating chromed the bumper. I wonder what it cost to have the fabrication and chroming done.
Thanks, Stuart. Darn, it's going to be hard to find another bumper but I will keep looking. I'm not sure it can't be made from 2.
You don't want to know. That car is a multi hundred thousand dollar build, maybe a million. When you pay others to do that kind of work for you, it goes stupid expensive quickly.
I have 450 hrs (3 guys, 10 hr days, 15 days) plus 10 coppers at the chrome shop and $1500.00 later and this is what I have on the rear of my 49 sedannette. Ciao, Mario
There are several things he did that are not to my taste but the instruments, especially. I think the original instruments and art deco designs of this car are beautiful. I'm having my original instruments cleaned and calibrated and will be going for an original look on the dash and steering wheel (cut down wheel).
Three bumpers? I would think you could weld the three sections together or if you had to get one more bumper to slice and dice... Sometimes I think some of these pro builds are a little hyperbole. Next we'll be seeing that it took fifteen valve stems to make one good one! LOL
You don't begin to understand how much work went into that bumper until you see the original version.
Well I see the bumper guards pulled, all bolt holes welded up and the three pieces welded together. Then the grinding, polishing, and plating. I suppose you might need to fill small gaps with pieces from a second bumper. On the other hand perhaps the first bumper was trash and that created the need for an additional two...
Its not like you can just stick weld it together, fill it full of bog, and then paint it. It has to be absolutely mirror perfect.
Similar job right here...49 Plymouth bumpers on a 50 Chevy. The car never had the filler pieces, but I offered to do the job for the owner, a good friend. He supplied half a bumper, and there was enough for front and rear. Curves are slightly off, but since they are hidden by the license plates, it doesn't matter. But it could be made perfect, if he wants (I offered to fill the unused bolts, and "hide" the mounting bolts, too, if he decides to get them plated.) I just shot some cold galvanize on them to prevent rusting. Including grinding down to 180 finish, welding backside, took about 3 hours per bumper. Much more needed to prep for plating, though.
I will take 3 bumper to make this. I need one more. If anyone has a line on a 49 Buick front bumper, please PM me.
