Technical How Do I Make a Bumper Like This?
Discussion in 'Traditional Customs' started by rockable, May 31, 2020.
  1. rockable
    rockable
    I don’t know ,
    But here’s the image
    Dave Mc and rockable like this.
  3. oldolds
    oldolds
    You would need a couple bumpers and start piecing it together.
    rockable likes this.
  4. junkers72
    junkers72
    Found this image of an original looking riviera without the flat center
  5. 19Fordy
    19Fordy
    It requires cutting and welding at least 2 Buick bumpers together.
    Take a look at 1949-51 Buick front bumpers for sale on Ebay.
  6. rockable
    rockable
    Im trying to buy the one on eBay. Thanks.
  7. lippy
    lippy
    from Ks
    I'll take the Buick for $115 lol.
    junkers72 and rockable like this.
  8. rockable
    rockable
    Bought the 2 sections of the bumper that I need for 95 bucks delivered!
    Hnstray likes this.
  9. stuart in mn
    stuart in mn
    Here's a video of the car, the owner says he used three bumpers spliced together.
    Dave Mc and dutch deuce like this.
  10. redo32
    redo32
    He stated on the video that Ogden Plating chromed the bumper. I wonder what it cost to have the fabrication and chroming done.
  11. rockable
    rockable
    Thanks, Stuart. Darn, it's going to be hard to find another bumper but I will keep looking. I'm not sure it can't be made from 2.
  12. rockable
    rockable
    You don't want to know. That car is a multi hundred thousand dollar build, maybe a million. When you pay others to do that kind of work for you, it goes stupid expensive quickly.
  13. BJR
    BJR
    I was with him until the dash board.
  14. mario
    mario
    from millbrae
    I have 450 hrs (3 guys, 10 hr days, 15 days) plus 10 coppers at the chrome shop and $1500.00 later and this is what I have on the rear of my 49 sedannette.
    Ciao,
    Gangrene, Blade58, 2OLD2FAST and 5 others like this.
  15. rockable
    rockable
    There are several things he did that are not to my taste but the instruments, especially. I think the original instruments and art deco designs of this car are beautiful. I'm having my original instruments cleaned and calibrated and will be going for an original look on the dash and steering wheel (cut down wheel).
    j hansen likes this.
  16. rockable
    rockable
    Looks great. Good isn't cheap and cheap isn't good. Nowhere is that more apparent than in chrome.
  17. williebill
    williebill
  18. Fortunateson
    Fortunateson
    Three bumpers? I would think you could weld the three sections together or if you had to get one more bumper to slice and dice...
    Sometimes I think some of these pro builds are a little hyperbole. Next we'll be seeing that it took fifteen valve stems to make one good one! LOL
  19. rockable
    rockable
    I'm going to try with two. There is enough material. I measured before I bought. :)
  20. Mr48chev
    You don't begin to understand how much work went into that bumper until you see the original version.
    Dave Mc likes this.
  21. mario
    mario
    from millbrae
    Ciao
    Mario
  22. ^^^^That arse looks stunning!
  23. Fortunateson
    Fortunateson
    Well I see the bumper guards pulled, all bolt holes welded up and the three pieces welded together. Then the grinding, polishing, and plating. I suppose you might need to fill small gaps with pieces from a second bumper.
    On the other hand perhaps the first bumper was trash and that created the need for an additional two...
  24. Warpspeed
    Warpspeed
    Its not like you can just stick weld it together, fill it full of bog, and then paint it.
    It has to be absolutely mirror perfect.
  25. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Similar job right here...49 Plymouth bumpers on a 50 Chevy. The car never had the filler pieces, but I offered to do the job for the owner, a good friend. He supplied half a bumper, and there was enough for front and rear. Curves are slightly off, but since they are hidden by the license plates, it doesn't matter. But it could be made perfect, if he wants (I offered to fill the unused bolts, and "hide" the mounting bolts, too, if he decides to get them plated.)
    I just shot some cold galvanize on them to prevent rusting. Including grinding down to 180 finish, welding backside, took about 3 hours per bumper. Much more needed to prep for plating, though.
  26. rockable
    rockable
    I will take 3 bumper to make this. I need one more. If anyone has a line on a 49 Buick front bumper, please PM me.
