Technical Harmonic balancer repair.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, May 26, 2020.
  1. rusty rocket
    rusty rocket
    I had a failure on my 230 dodge flat six balancer yesterday the rubber in between the hub and the grooved pulley outer let go. The pulley is sort of rare so finding another is going to be a chore. I’m thinking about having a machinist make a metal band to replace the rubber. Anyone see why this wouldn’t work? 0D397E31-5CD7-4C14-806C-96E5571A784E.jpeg
    dana barlow likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    The rubber is there for vib's,it helps make the crank last longer by taking some of the shock off the crank keeping cracks from starting over the life of the motor to the crank.
    So now you know what it is,and can think about what you want to do.
    As the part you need maybe real hard to find,sure repair can be done. Some one on here may have a plan to do that,with out the pulley being just solid.
    Something like making the pulley solid now, but adding a damper to inside or out side of pulley,to do same job=needs to be close to same lbs. of damping it had stock.
    But there are many engines that were design an built before dampers were used,an still running,so solid works too,just not as safe.
  3. I wonder if you could carefully center the pulley then mix/pour some urethane in place of the rubber?
    olscrounger likes this.
  4. KenC
    KenC
    Most 230s didn't even have a harmonic dampener. Just a pulley. I have one with, and two without. Several arrangements over the long production of the flathead 6. One piece hub/pulley, two piece ever three piece, which is what my 56 plymouth has. If it were mine, it would get fixed the cheapest , fastest way. Maybe find a solid replacement from a different model.
    I've been looking for a two sheave version for a year and haven't found one at an affordable price.
  5. mark latham
    mark latham
  6. Ericnova72
    Ericnova72
    from Michigan
    Damper Doctors is who i was going to recommend.
    jimmy six likes this.
  7. mark latham
    mark latham
    I had thought about doing it myself but most of the rebuilders use a jig to get them lined up, a vacuum pot to get full contact between the rubber and the pully and weight, and the rubber or elastomeric compound is rather expensive and only becomes reasonably in economy's of scale.
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I would think the hardest part of doing it at home is finding the correct rubber thickness. Put the hub in the freezer, the outer ring in the oven and wrap the rubber around the hub and trim. I have not done this, but would think as the hub warms up and the ring contracts it would be a tight connection.
    I stayed at a Holiday Inn last night, too........
  9. ididntdoit1960
    ididntdoit1960
    from Western MA
    +1 on damper dr.
  10. Mr48chev
    I'd say that this is one of those times you just suck it up, and forget home remedies and send it off to the people who do it and do it right, pay the coin and call it good. Sure beats bandaiding one back together with a home brewed concoction and then having the ring take out the radiator a few miles down the road.
    That or hunt a decent used one down and pay the going price.
    1934coupe likes this.
  11. tubman
    tubman
    I have used "Dale Manufacturing" (http://www.hbrepair.com/) a couple of times in the past and was completely satisfied. It may be just a personal quirk, but I usually shy away from operations with "cutesy-poo" names. There is a thread on "The Ford Barn" now about a place called "Go-Cat Speed Shop" that will curl your toes.
    Cyclone_racer likes this.
  12. That'll teach you for wringing that little motor out to 8000rpm. Just kidding, good luck with the repair.
  13. jimmy six
    jimmy six
    Damperdudes in Anderson Ca turns them around very quickly. Pleased with their service...
    saltracer219 likes this.
  14. rusty rocket
    rusty rocket
    Thanks guys! I’ll look into these sights.
