Technical Saginaw 3spd Overdrive need solenoid
Discussion in 'The Hokey Ass Message Board' started by JWDorlac, May 21, 2020.
  1. JWDorlac
    JWDorlac
    Hi folks. Anyone know if replacement solenoids are available for late 60’s Saginaw 3spd overdrive transmission? If not is this a rebuildable part? Any help appreciated.
    JDorlac
  2. squirrel
    Hi, welcome to the Hamb.
    Let me google that for you...
    https://www.fifthaveinternetgarage.com/overdrive_parts.php
    kind of pricey. Measure the length of the shaft, I think the chevys were all 1", but better check. Did I mention, they're expensive?
    If you're into winding coils, you might be able to rebuild an old one. Good luck.
    razoo lew and Boryca like this.
  3. JWDorlac
    JWDorlac
    Thanks for the link but it looks like that site only deals in Borg Warner.
  4. miker98038
    miker98038
    banjeaux bob likes this.
  5. 56sedandelivery
    56sedandelivery
    The overdrive unit themselves were made by Borg-Warner, and attached to vaious manufactureres 3 speed transmissions. You might also try garagemotorsports.com; they rebuild and sell the entire transmissions and parts. for the 3 speed/overdrives. There are also used ones for sale on that auction site we all know and love.
    I am Butch/56sedandelivery.
    banjeaux bob and squirrel like this.
  6. :p:p:p
    Ben
  7. 42merc
    42merc
    Late Saginaw OD's are BW & have a unique solenoid.
    The shaft length is 1-1/4" long as opposed to the common 1" length on most BW overdrives.
    More scarce & pricey.
    squirrel likes this.
  8. JWDorlac
    JWDorlac
    Thanks for the info gentlemen. I will see what I can find.
  9. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, JW;
    Depends on what's wrong w/the sol, mechanical or electrical. Open the sol up, n check the wiring. If coil isn't shorted, or fried, may just be damaged (broken wire) at the soldered joint. A typical(cheap) fix is to unwind a turn or two, resolder to tab. Won't hurt the performance of the coil. Worth checking. Marcus...
    hillbilly likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What's your location? There are some to be had just outside of San Diego, Ca.
