Well, I came across a model T Project I couldn’t pass up.... it was a Covid special Now, best I can tell, a BIG assumption, is if frame and body are original to each other , it started life as a 1927. Obviously the roof is homemade as well as the lower half of the back. But, I’m not sure or what it is, was, could be. It’s possible it started life as a closed Tudor, Fordor, etc. Any help greatly appreciated!
The body is a 26 or 27. If you can measure the length of the door opening maybe a HAMBer can tell us if it was a coupe or tudor or fordor.
Well, the opening is approximately 28” wide, but, I believe the back was added to the cowl so I don’t believe it is a “stock” opening.
