HEMI Tech- Block, head, porting/polishing, and gaskets
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 5, 2006.
  1. Work In Progress
    Work In Progress
    Just to update this, I have pulled the engine and removed the pistons for a more complete sonic check. I measured 48 points in each cylinder (overkill?) Thinnest was 0.138 on a non-thrust side and 0.177 on a thrust side, most were between 0.235 - 0.314. 2 cylinders were down to the 0.138.
    Really glad I am pulling this apart as I found a couple of issues, plus this thing was packed with assembly lube
    First was a couple of rod bearings didn't look so good.
    And 2 rings chipped off at the ends. Both were the cast second rings.
    That's about it for now, I still have to pull the crank and check the mains but that wouldn't add any value to this section of the Hemi Tech Index. Thanks again for all the help!
  2. George
    George
