HD powered Reverse Trike
Discussion in 'The Antiquated' started by '52 F-3, Nov 19, 2019.
  1. Cliff Ramsdell
    Cliff Ramsdell
    @'52 F-3 the grill and lamps and grill shell look killer, nice job. While one light each side might suffice as @flatheadpete mentioned, I think that the two lamps per side look killer.
    Don't forget to rotate your bulbs in the housings as they are at a 90 degree angle from the stock mounting locations and will reflect light in a really weird pattern. You might need to slot the buckets to accept the alignment tabs on the bulbs.
    Have you had a chance to drop it down on all three and roll it outside for any "glamour" shots?
    Cliff Ramsdell
    brEad and '52 F-3 like this.
  2. '52 F-3
    '52 F-3
    Finished the chain guard and area between seat backs, (yup, I'm pretty sure the fuel filler will be under the original HD tank chrome/cap) and also mounted 3rd brake light.
    Deuces, brEad, Okie Pete and 2 others like this.
  3. pumpman
    pumpman
    Looking really good man. Talk about a one of kind, you nailed it.
    '52 F-3 likes this.
  4. '52 F-3
    '52 F-3
    Thanks Pumpman; just been working on the slow process of the under dash also....
    Deuces, brEad and Okie Pete like this.
  5. sliceddeuce
    sliceddeuce
    Unique.
    '52 F-3 likes this.
  6. '52 F-3
    '52 F-3
    Started on the fuel tanks, will be using the "guts" out of the factory tank and making 2 small tanks (one behind each seat) It's gonna be a quite a few hours of work...
  7. Cliff Ramsdell
    Cliff Ramsdell
    How much fuel are you looking to hold? Trike is looking good, keep at it.
    Cliff Ramsdell
  8. '52 F-3
    '52 F-3
    Got the fuel tanks tacked up and I'm lucky enough to have great welder as a good friend. (thanks Dave) While he's welding I'm routing fuel and brakes lines etc....
    I was wondering how many brake line/fitting leaks I was going to have, I flared 16 ends. So I quickly found I didn't even tighten 2, then had a leaker that couldn't be tighten/fixed so had to make another line.
    So front was going pretty well, but wasn't getting fluid to the rear bleeder…. I loosened hose at caliper-nothing, I loosed line coming from adjustable proportioning valve-nothing, I loosened line coming out of Master Cylinder-nothing! With master cylinder under dash it's hard to get to, so I hooked up a line to blow/suck and discovered I could blow into Master Cylinder with no resistance or air bubbles????
    then I got a flashlight an noticed the rear reservoir was empty… duh So there is just a small gap to pour fluid into rear section that I can't see, and without flashlight I couldn't see reservoir level like in picture.
  9. '52 F-3
    '52 F-3
    Deuces, Okie Pete and Shadow Creek like this.
  10. '52 F-3
    '52 F-3
  11. shivasdad
    shivasdad
    from Texas
    I'm following, this is cool. Great work and well thought out. I like the headlights!
    '52 F-3 likes this.
  12. Amazing Work!
    '52 F-3 likes this.
  13. '52 F-3
    '52 F-3
    thanks for replies, helps to stay motivated to get through this wiring...
    Got the fuel system finished, tested and leak checked :) . Finished wiring the rear lights and started on the front. (rotating bulbs 1/4 turn) and installed seat bottoms and set backs in place.
    Gonna Google how to bend Lexan, wanna put a bow in windshield.
    Deuces, brEad, Cliff Ramsdell and 3 others like this.
  14. 38bill
    38bill
    from Minnesota
    VERY COOL....I'm getting a kind of steam punk/rat rod feel from it.
    The37Kid and '52 F-3 like this.
  15. Wanderlust
    Wanderlust
    Absolutely fabulous, really like your vision. Been contemplating a trike using an old bug body, may never happen but it keeps the mind working
    '52 F-3 likes this.
  16. pumpman
    pumpman
    Coming together nicely and I bet it will be a gas to drive. Are you going to finish the body or leave as is? Just curious about your plan.
    '52 F-3 likes this.
  17. '52 F-3
    '52 F-3
    Agree... I've said before, I'm actually going more for the "Ed Roth" than Mad Max look, but it does have a RatRod look.
    I also have some build plans in my head, and enjoy thinking about.
    Original plan was to finish and paint a gloss medium grey. But now I'm using Rustoleum Enamel Clear (gloss) to coat body parts I've finished. Plan has evolved to just get running/inspected/titled/driving like it is, (I'm getting excited to drive) and later go back and bondo/paint. Time will tell, only things for sure are my plans always change and projects never seem to get 100% finished.
    brEad likes this.
  18. I'm watching and looking forward to the "next installment" , this is one cool project!!!!, lot's of different themes/ style's and a cool factor off the charts!!. Thanks for posting!!!
    '52 F-3 and lothiandon1940 like this.
  19. '52 F-3
    '52 F-3
    Not much picture worthy stuff going on, still working on wiring. I did make the huge step of hooking up the battery and started testing minor electrical things. Weekend after next I should have some time to make some real progress....
    I did get this 1947 Studebaker Commander hood ornament (off E-bay) and installed, looks like I planned it.
    Deuces, brEad, Cliff Ramsdell and 4 others like this.
  20. '52 F-3
    '52 F-3
    IT'S ALIVE! Worked on wiring a little more today, and got to the point to test the starter, and it cranked fine. So I couldn't think of anything else not wired that would prevent the engine from starting. Cranked about 2 seconds and fired right up, gotta love fuel injection (when it's working).
    A couple pictures of the lights, cause I like pictures more than reading... notice the adaptors made to lift safely by the 3 wheels (my back can only take so much).
    Starting on exhaust, can barely see left side muffler.
  21. pumpman
    pumpman
    Holy freight that thing is really coming together, really lookin good man!
  22. PhilA
    PhilA
    1. Hydro Tech
    Loving your vision on this. Can't wait to see more (and a wider angle picture of the front, too).
    Had to smile at the British Leyland "drain hole" on the pedal rubber though...
    Phil
    '52 F-3 likes this.
  23. '52 F-3
    '52 F-3
    Haven't been working on much, but did get some time to almost complete the exhaust, I'm going to put these "isolators" in the down tubes off the heads. (see if it keeps from cracking my exhaust welds) it's about 5" at the low spot under the swaybar...
    Deuces, Cliff Ramsdell and Okie Pete like this.
  24. '52 F-3
    '52 F-3
    The Brake Cylinder assemble is from a Triumph, actually going to be cutting off the pedal and weld the Harley Rear brake one in it's place.
    Wider angle pic of front?
    Deuces, brEad, rustednutz and 5 others like this.
  25. pumpman
    pumpman
    Monster for sure.
    '52 F-3 likes this.
  26. PhilA
    PhilA
    1. Hydro Tech
    Thank you for taking that photo.
    I think you finally found the correct use for the Edsel horse-collar!
    Please continue!
    '52 F-3 likes this.
  27. 64 DODGE 440
    64 DODGE 440
    from so cal
    Amazing build. I have some sketches of a Morgan style trike I want to build. All I need is time and money.
    '52 F-3 likes this.
  28. mikebishop37
    mikebishop37
    Great build! I've been dreaming and scheming about a reverse trike build of my own for about 28 years. I've finally collected all of the essential bits that represent the amount of mental "development" the project has gone through in those nearly three decades. It's much different than what it started out, but the search -- for me -- has been almost as much fun as the final build will be.
    I've been absent from the board for quite some time -- ass-kicking health issues and 80-some years nag at me -- but I'm back and ready to pick up the thread and start building!
    I'll be watching you!
    Mike Bishop
    Santa Rosa, California
    low down A and '52 F-3 like this.
  29. JackdaRabbit
    JackdaRabbit
    from WNC
    Welcome back, Mike !
    I sent you a PM
  30. '52 F-3
    '52 F-3
    I also enjoy the "dreaming, scheming and collecting" as much as building, I have way more ideas than can every be accomplished in a lifetime. Glad to hear your building and thanks for the nice comment. I'm hoping to finish a few more key things soon and start the testing...
    Gregg
