Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Geez, and I thought I get up early!
    kidcampbell71, Paul and loudbang like this.
  2. Wow! Real hot rod headlights on hot rod headlight stands.
  3. Paul
    Paul
    Editor
    As real as it gets my friend
    loudbang and Stogy like this.
  4. Paul
    Paul
    Editor
    bit the bullet
    chopped the perfectly good bottom off the shell
    locate the radiator, hang the abbreviated shell over it
    and roll it outside for a walk around..
    headers will definitely help pull it together..
    IMG_20200509_145204.jpg IMG_20200509_150148.jpg IMG_20200509_154552.jpg IMG_20200509_154957.jpg IMG_20200509_155037.jpg IMG_20200509_155021.jpg
    RustyBullet, A Boner, 51box and 13 others like this.
  5. Paul
    Paul
    Editor
    seats
    will need to perform a bit of surgery here too..
    J_J2, brEad, loudbang and 4 others like this.
  6. Paul
    Paul
    Editor
    And chopped a grill to fit the shell,
    Moved the lower cross bar up to catch the cut ends and raised the top bar so as to not crowd the lower bar.
    It will need a bit more trimming and add a piece of round to close the bottom off.
    A Boner, 51box, patmanta and 16 others like this.
  7. alchemy
    alchemy
    I’ll send you my address.
    Stogy, kidcampbell71 and Paul like this.
  8. dumprat
    dumprat
    from b.c.
    That is balls! Balls correct that is.
    This is exactly what we need more of!
    No more boo hoo it's rare and collectable.
    No more what is it worth.
    Carry on sir! You have it dialled in.
  9. 64 DODGE 440
    64 DODGE 440
    from so cal
    The shell looks perfect on the car...that's what matters.
  10. Nice work Paul. Coming together and looking perfect. What are those seats from?
  11. butch27
    butch27
    Great work there..
    loudbang and Paul like this.
  12. Paul
    Paul
    Editor
    Thanks,
    I don't know what they came out of originally, they are a bit new for the build style but maybe they can be reworked to fit what I have in mind.
    Stogy and loudbang like this.
  13. 31Apickup
    31Apickup
    loudbang and kidcampbell71 like this.
  14. Somebody knows how to build hot rods, bitchen car.
    Maybe hairpins in front too.
  15. Paul
    Paul
    Editor
    In front of what?
    I know it's been far too long since I've been to the barber but hairpins? It's damn near long enough for a pony tail for christ sake
    Speedy Canuck and loudbang like this.
  16. Paul
    Paul
    Editor
    I'll try to get it out in the next day or two
  17. We're all getting pretty shaggy for sure, I'm thinking something similar to what you have locating the rear.
    Straight top.
  18. Paul
    Paul
    Editor
    'got way too much time and money invested in this setup, it's very similar to the Kookie Kar's four bar setup and exactly what I had in mind.
    Of course you know that from reading this thread ;)
  19. Paul
    Paul
    Editor
    Not what I had in mind, but thanks just the same
  20. Old-Soul
    Old-Soul
    Your roadster is worried about it's competition.
  21. Tim
    Tim
    from KCMO
    Man this things just fantastic
    Stogy, loudbang and Paul like this.
  22. Paul
    Paul
    Editor
    Curious to see how the pecking order plays out,
    the old gal did get a little attention yesterday, drove around long enough to blow the dust off anyway.
  23. I like this one a LOT
  24. Still love the look and proportions of that roadster.
  25. Old-Soul
    Old-Soul
    What ever happened to your previous RPU? The 26/7 T.
  26. Paul
    Paul
    Editor
    Sold it to a guy in Las Vegas who sold it to a collector in Ohio, last I heard.
    That was a fun car
  27. Old-Soul
    Old-Soul
    Love that T.
    If you don't mind my asking, how tall are you? Your T's are always so proportionally correct and if I were ever to attempt assembling my pile of odds and ends I would basically be using your cars as my inspiration but at 6'3" it's sort of a worry if I'd fit or not haha.
    loudbang, kidcampbell71 and RodStRace like this.
  28. Paul
    Paul
    Editor
    I'm 5'-10"
    current car is almost 7" longer than regular roadster
    T's are small no matter who is in them.
  29. Paul
    Paul
    Editor
    Kind of a lateral move today
    Early on I chose to not use the original back section and use another I had in the parts pile.
    Reason was it had less rust through and one or two fewer dents.
    But it had zero paint on it and minor pitting top to bottom.
    The original needs the bottom six inches replaced and a few dents that will need to be worked out.
    But from that six inches up is nice and solid, shiny metal under ancient paint.
    I took all the panels apart and wiped them down with lacquer thinner and pop riveted (poor man's clecos) the old section back in place.
    The whole thing is about ready to be blown apart and the frame put back on the frame table for welding.
    This is what it looks like tonight.
    IMG_20200513_171221.jpg IMG_20200513_171039.jpg IMG_20200513_171233.jpg IMG_20200513_171126.jpg
    Stogy, lurker mick, 51box and 8 others like this.
  30. bchctybob
    bchctybob
    Holy smoke Paul, I haven't checked in in a while and it's done! First time I've ever seen someone make a stock style thermostat housing, very cool. I particularly like the Olds steering wheel on the modified Ford steering box and the use of the good old aftermarket light stands. Those seats won't look out of place with new skins on them. The car just looks great!
    Stogy, OFT, loudbang and 2 others like this.
