Technical Flathead starter weird issue
Discussion in 'The Hokey Ass Message Board' started by olskool34, Apr 26, 2020.
  1. olskool34
    olskool34
    I have a starter bendix that I believe it not returning after starting. It engages just fine but makes a rather nasty sound after until I blip the throttle and that seems to send it back. Any ideas why this could happen? I have broken springs before but that only lead to non engagement of teeth.
  2. brading
    brading
    You need take the starter out, check that the drive is clean and not sticking on return. Always best to bench test it to see what is happening.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    Could be sticking or catching. Happens to alot of starters.
  4. Slight misalignment do to not having the small bracket from oil pan to starter?
  5. olskool34
    olskool34
    I have the small bracket on it. I will take it out and see if it’s gummed up or something.
  6. rusty valley
    rusty valley
    most folks are tempted to oil or grease the shaft, but it should be clean and dry to not attract dirt
    town sedan likes this.
