Projects 60's Era Street/Strip Model A Coupe
Discussion in 'Traditional Hot Rods' started by -Brent-, Aug 1, 2019.
  1. Tim
    Tim
    from KCMO
    Looks perfect!
    -Brent- and Stogy like this.
  2. FlatJan
    FlatJan
    Man i never really liked 60s era hot rods... now i do.;)
    Great work great car!
    Stogy and -Brent- like this.
  3. Stogy
    Stogy
    You Artist You...That's truly Awesome...;) Post it in Joeys Sketchy Thread...and Friday Art Show Buddy...Come on Over...;)
    mad mikey and -Brent- like this.
  4. I agree Brent, the axle really flows with the whole look and personality of the car. Excellent call.;)
    31chevymike, -Brent- and Stogy like this.
  5. Tim
    Tim
    from KCMO
    Thanks @Stogy glad you dig it
    Stogy likes this.
  6. -Brent-
    -Brent-
    Awesome guys! Thank you!
  7. dumprat
    dumprat
    from b.c.
    I like the axles quirky old time made at home feel. Doesn't look like a catalog ordered part.
  8. -Brent-
    -Brent-
    Same! I think it was @Tim who said in a text, "It's not cookie cutter."
  9. -Brent-
    -Brent-
    Batwings From 1932 Wishbones - Finished:
    The batwings went from tacked-in-place to finish-welded as we concentrate on finishing the front end.
    31chevymike, catdad49, 51box and 20 others like this.
  10. Tim
    Tim
    from KCMO
    Very nice
    -Brent- likes this.
  11. Thor1
    Thor1
    Brent,
    Based on the color of the batwings in your photo, did you have some sort of heat treatment performed on them to enhance their physical properties? Just curious.
    Steve
  12. -Brent-
    -Brent-
    Steve, it's just the lighting (and being welded on). I tried to lighten up the pic, too, so there might be some unnaturalness.
    31chevymike and mad mikey like this.
  13. -Brent-
    -Brent-
    Not much happening but the @thunderbirdesq dropped 32 axle is in, the chrome A shackles are fancying (?) up the front, the spindle bushing are reamed and the arms are dropped (we had a clearance issue going through the hair pins).
    I was supposed to be on the road to grab it, yesterday, but that plan was shut down by the current madness.
    Hopefully soon.
    31chevymike, catdad49, enloe and 18 others like this.
  14. Stovebolt
    Stovebolt
    @-Brent- That is one sexy drop on the axle, suits the car perfectly.
  15. All the work is very nice. I appreciate the hand made parts that are built from other old parts. Also the whole built not bought styling.
    Sent from dumb operator on a smart phone
  16. SilverJimmy
    SilverJimmy
    I really need a closeup picture of the anvil stump. Please....
    -Brent- and loudbang like this.
  17. @-Brent- Your coupe oozes coolness.:cool:
  18. JUNK ROD
    JUNK ROD
    WoW!!! I just went trough the 16 pages..... Man thats a crazy build up, its gonna be one hell of a hotrod!!!
    Thanks for sharing!!
  19. 3banjos
    3banjos
    from NZ
    And so did I. Very inspirational. Most of us could only dream to weld like that.
  20. -Brent-
    -Brent-
    Front axle and tie rod in - final stance:
    We're at the final push. The car is going to be set aside for a week so Ryan can knock out the Tatra. So, most of the Model A parts that were scattered throughout the shop were put where they belong.
    I had ordered a tie rod from Nostalgia Sid and that got put in. The arms were bent for the tie rod to run under, rather than through the hairpins like originally planned. Other than that, the steering is almost set. The steering hoop does needs to be bent/adjusted a bit and when the car is home, I am going to adjust the pitman arm bend a little more.
    The car is jacked up to adjust/finish the ladder bars.
    One of my favorite angles of the car.
    The front wheels tuck under the fenders nicely.
    Upper shock mounts need to be done, shocks mounted and then steering hoop adjusted to fit so it clears everything.
    I think this angle will look better when I have the steelies and a more streetable rear tire in the back.
    Then I see this view and I forget all about running narrower rear tires.
    You can see the rear frame horns poking out.
    I can't wait for you guys to see the bumpers.
    A closer view of the rear frame horns. This has been in my mind for a decade.
    That's it for an update. I hope you're all well.
  21. dumprat
    dumprat
    from b.c.
  22. druids62
    druids62
    Picture perfect!! Nicely done!!
    Stogy, loudbang, Thor1 and 1 other person like this.
  23. wvenfield
    wvenfield
    I think it looks great with those rear tires.
    mad mikey, Stogy, loudbang and 2 others like this.
  24. -Brent-
    -Brent-
    I love the slicks, too. It's just that one angle, for me.
    Man, I cannot wait to rip this thing around.
    31chevymike, Thor1, mad mikey and 2 others like this.
  25. Ready to pounce!
    Thor1, mad mikey, Stogy and 2 others like this.
  26. OFT
    OFT
    Looking like I remember seeing them in so-cal when I was there in mid 60's.!! thanks for your build to jog the memory bank!
  27. -Brent-
    -Brent-
    So cool! Thanks for the compliment.
  28. loudbang
    In this shot that rear diff is begging for some chrome and or silver paint. That is all any competitors will see when you blast by them. :rolleyes:
  29. -Brent-
    -Brent-
    If it's not black (with some "panel" striping) it will be white.
    31chevymike, AHotRod, Thor1 and 5 others like this.
