Today Vince was doing more media blasting of additional interior pieces as well as some hand painting on the parking brake for the wagon. It had some bare steel still so he got most of that covered. The ratchet/gear was left alone as we thought the epoxy would anchor it permanently.. Mike blocked out the pieces we primed last week, drilled some holes we'll need for the fan shroud, and got pieces hung up for the next round of epoxy primer. ….and please don't tell anyone you've seen her patio table in the paint booth! On another note, our resident shop ghost who likes to hide things has done something with the stainless trim door points. So I had put in a call to Mikey at The Stainless Shoppe. He had some original take offs in stock, and even polished them up for us. Now we have our work cut out for us in matching these!! .
We got some more epoxy sprayed on the core support parts and hood latch... And Brandon sent some pictures of the wagon in final primer.. A little bit closer....
Today I was block sanding some core support parts for one more spray. Making black powder out of black epoxy primer. Not all that exciting, so I didn't take any pictures.. But wait... it gets better! Brandon and Richard have been sanding as well, only they put some color on the roof today: Clear: Can't wait for the green and some sunlight.... .
Very nice milestone, I have been patiently waiting for the day its out in the sun fully painted. Thank you for all the posting that you do, I have learned a great deal from you.
Thanks guys! Some spring cleaning.... Picked up a 12" disc sander quite a few months back, and Mike has been using this on the floor.. So I decided to help the guy out and put it at a more useable height... Added a "bolting framework" to the top of one of the paint tripods, already set up with casters so you can push it in the corner.... Rivnuts installed since I didn't have bolts in stock long enough to go all the way through.. Ready for some sanding... Dana dropped off the new brake cables for the wagon the other day. The single cable that attaches to the pedal has a shouldered ferrule that sits in the bottom of the parking brake bracket. Only this shoulder was much too small for the factory hole, the Hex portion almost pulled through the hole. I considered making an adapter sleeve on the lathe, but the figured resizing the hole would be quicker. Found a nice thick 3/8 flat washer in stock that fit the ferrule shoulder perfectly and matched the thickness of the parking brake bracket. In order to get the weld heat farther from the 3/8 hole, the bracket opening was oversized up to 7/8" (largest step drill that I could find) and the washer slightly downsized to fit.. Some 3/8 standoffs made a quick arbor for the drill, and the die grinder does the rest. we had our correct size in about a minute.. Installed, much better fit... Now Vince needs to do some touch up on the paint!
Never ends Don! We're in the middle of blocking paint today on the core support and happened to notice someone forgot to add the holes in the new vertical uprights for the light wires to go across above the radiator. We have some rotary cutters that would do the trick but they are a bit short to reach from the outside (to keep things perpendicular) so lets make an extension. The set screw for the spring loaded center point is a 5/16-24 and we happened to have some in stock. So we used a piece of stainless fuel line and plug welded a stud in one end and a plug in the other for tightening in the drill chuck.. Holes drilled, deburred, and grommet test fitted.. Now for a test fit of our Parking brake lines to mock up the routing prior to adding rivet nuts and adel clamps... And here's our one cable to two part layout..
Greetings Robert, I installed the same cables on my 56, if you could can you detail how you cut the cables and not have them fray. I'm not happy with my results. Thank you. Greg
Used a cable cutter but I don't think it was up to the task, these are pretty stout cables, left a flaw in my cutters jaws. I was thinking about trying solder, I done a bunch of soldering but not on a cable. Spread flux, " what type of flux? heat with a propane torch? and solder what type of solder? Sorry for hijacking your thread Robert
All good, we're learning something here.. Actually the best cutters I have found for stranded stainless wire are made by Knip-ex specifically for cutting wire rope.. Has a "blunt" cutting edge that stands up to the task at hand, and the internally rounded shape of the jaw helps keep strands together. Typically after cutting its just a re-twist and done. It doesn't deform the strands like a pair of Kleins would.
With our adel clamps arrived, Mike and I worked on the brake cables while Vince was prepping things for paint... I think he's having too much fun... We had to wait for -5 clamps as these were snug enough to hold the cable from moving. This allows us to set the length to the backing plate such that it clears the frame during suspension travel.. The clamps were held in place using rivet nuts installed into the frame. Here is a video showing rivet nuts and the proper installation: Outer sheaths are marked for trimming.. Be sure to pull cables out of the way prior to cutting... Our implement of destruction... Using Gripple cutters to cut the cable... Also made by Knip-ex, both are designed for cutting steel wire rope.. Our parking brake assembly used an integral "return spring" to pull the pedal back upwards when the brake is released, so that part is saved for this installation as well. To keep the end of the spring from rubbing against the cable in one spot, we machine a landing in the adjuster. We will also use some Teflon heat shrink over the cable to help prevent wear. Final trim on the rear cables will come when we drop the body back on the frame for proper fitment to the brake pedal assembly. .
It's about an eight hour drive to restock, and I'm down to 10 of the 20 12 packs I picked up a few months ago... So I need to try product placement and see if I can get sponsorship.. You know, the truck backing up to the door, nothing but throwback..
Wow! what a great idea for a return spring, I have to decide if I want to change out the cable that is frayed on my truck. Nothing wrong with its function for now but it looks and I don't think it could be removed and re-installed again.
Time to play catch up here.. Vince got two of the milk cans media blasted and worked on the third while I sprayed some SPI epoxy primer on the first two. Also got some epoxy on the 52 F7 hood brace... Ends are quite a bit better than before.. I received a state of the art drawing the other day, and was asked if we could duplicate the 1/16 offset shown... Of course this meant we needed some new tooling.. Our first sample, with the proper 3/4 flange... We had another panel that would require the offset on two adjacent edges, so one more sample... video action: That'll do pig, that'll do. Some of the upholstery parts have been trickling in... so let's add some bling factor.... ….and we made a hand punch for setting the trim tag rivets on the cowl... video version: And finally, we also had some 3/8 stainless fuel line to straighten out of it's coil for a big block mopar… Video parts 1, 2, and 3: .
That wagon is going to be sooooo sweet. Can't wait to see it assembled and out in the sunlight somewhere.
Thanks Don! More progress in the shop, another upholstered piece getting assembled... this one the driver's side rear kick panel. Our polished stainless seat belt escutcheons are installed, one in the front for the lap belt and up top for the shoulder belt. Midrange and tweeter installed.... Vince has the hood just about ready for epoxy... And we got a new "radius" fixture for the Tommasini wheeling machine, allows you to use it to form radius on flat bar and other shapes.. action shot....
Tomorrow the Baileigh MH19 gets picked up for its journey to Pittsburgh... Next week we pick up the replacement, a Powell Hammer..
Overdue for another update... So with all three milk cans delivered, why not a dinner bell? Indeed. This one was missing the clapper, so that's the latest fabrication... A used 2" hitch ball was reworked in the lathe, and looks like this will be a good start... Hammer/bench head stand is used as a welding fixture.. Hey, whatever works.. root pass Finished product in action: We had some dings in the F7 hood to remove that were located in the radius along the sides.. Didn't really have a hammer that fit the exact requirement, so I use a "KIT" that my buddy Will Cronkrite had given me, a piece cut out of a Model A leaf spring. I had more than one BF603 in stock, and rarely use the pick end, so it became the likely candidate. TIG welded in place using ER312 rod Some crown added long ways and polished up... Both of the Wagon's rear kick panels are now prepped, ready to go.. Vince has the core support and associated parts blocked and ready for some green... ….and speaking of paint, we got some "new" used light fixtures for the paint booth so we can see a bit better... Old next to new... Now that we can see a bit better, it's clear that the walls need a fresh coat of white... ….And some blocking tips on the F7 hood. We have a nice crease on the inside of the hood from front to back. These scratches show that we would be taking material off the adjacent side if no other steps were taken to stop our sanding block at the center of the crease... By adding a strip of tape along the center, it gives us a positive stop for the sanding block.. Then switching for the other side.... Which leaves us a nice crease in the middle, and panels nice and flat to either side...
So this past Saturday we had another louver job with Cody, this time on a C10 Chevy hood. With the Lennox sitting in the corner like this... ….. there has been a couple of occasions that large panels would run into interference with the shear. Saturday would be no exception. We had to cut the anchors with a Sawzall and slide it toward the paint booth to make room for the hood... Since the Baileigh was picked up early that morning, the spot it was in seemed a better location to eliminate future issues with obstructions to the side.. So we used the 6000 lb capacity engine hoist to move the approx. 4000 lbs of Lennox.. Which left this spot open for the new Powell Hammer. The dies are located higher on this machine, so any larger panels should clear over top... Monday was moving day for the Powell hammer, Mario helped with the loading, unloading, and positioning exactly where it was supposed to go... All that's left to do is drill some holes into the concrete and add some "peg" bolts to keep things from moving around.
