Projects Another Deuce Rdstr project.
Discussion in 'Traditional Hot Rods' started by Baron, Feb 5, 2019.
  1. Baron
    Baron
    Our club plate topper. Instead of bolting to the plate, I made a mount on the rear end. Nice, neat place for it. Two friends of mine and I started the club in 1978. Today we have over 90 members.
  2. gary kessler 1932
    gary kessler 1932
    Very Nice!!!
    Baron and loudbang like this.
  3. Baron
    Baron
  4. alchemy
    alchemy
    Why is it covered up? I thought you'd be painting by now.
    Baron likes this.
  5. Baron
    Baron
    Decided to take care of the wiring where the paint is being held up with this COVID-19 outbreak. All stuff that has to be done, so all good. Wiring 1.jpg Wiring 2.jpg Wiring 3.jpg Wiring 6.jpg Wiring 5.jpg Dash wiring  1.jpg Dash wiring.jpg
  6. DDDenny
    Baron, any photos of where you ran the wires after they drop from the fuse panel, also any shots that show if/where they enter/exit the frame both front and rear of frame.
    Baron likes this.
  7. hoop
    hoop
    Very Very Nice .Great job Baron.
  8. Baron
    Baron
    I'll take some better pictures in the next day or two. Here is where the wires will enter the frame for the headlights and cooling fans, gas sending unit and tail lights, along with the positive battery cable to the starter. Deuce frame access hole for wires.jpg Deuce frame rear exit hole for wiring.jpg
  9. Baron
    Baron
    Thanks Hoop. Hope all is well with you and your family. Stay safe and healthy my friend.
  10. hoop
    hoop
    Doing well ,Thanks for asking. Stay safe also.
  11. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Roadster looks great. I'd give my left testicle for a Knetch Auburn panel, your a lucky man.
    Baron, kidcampbell71 and loudbang like this.
  12. Baron
    Baron
    Paints on hold due to COVID-19. Continuing the wiring and finishing other little details. All good.
  13. alchemy
    alchemy
    Primer IS paint. Drive it like that!
    brEad and Baron like this.
  14. Baron
    Baron
    Finished wiring the dash panel and ran all the wires out to the headlights,tail lights, gas gauge ,etc. Tested it all yesterday, and every thing works. My plan was to do this after paint, but this COVID-19 changed things up a bit. All good. Stay safe and healthy. 20200418_132125.jpg 20200425_174142.jpg
  15. loudbang
    WOW what a NICE looking panel. :)
    kidcampbell71, brEad and Baron like this.
  16. Baron
    Baron
    Bolted the tail lights in place to finish the wiring to the back of the car to make sure they work. 20200427_165403.jpg
    V8-m, chryslerfan55, alfin32 and 11 others like this.
  17. rosstom
    rosstom
    Everything looks nice. I like the dash panel.
  18. mohead1
    mohead1
    Looks real good, i have the same car. Can you tell me where you got the trans tunnel? I want to replace the stock type tunnel/firewall and that one you have would work well. Appreciate it
    Sent from my SM-G960U using Tapatalk
    chryslerfan55, Baron and loudbang like this.
  19. Baron
    Baron
    Something I bent up and welded together in my shop.
  20. mohead1
    mohead1
    Ok, did a great job on that. I dont have a slip roll so im gonna have to come up w a solution...thanks man
    Bigmo
    loudbang and Baron like this.
  21. alchemy
    alchemy
    A slip roll? Otherwise known as a workbench, some lengths of angle iron, a few C clamps, and maybe a welding gas bottle.
  22. Baron
    Baron
    I bent this using a vise on my work bench, then used a brake to bend the flanges. Made it out of cardboard first, then transferred it to the sheet metal. Gas welded it together, bead blasted the weld,scuffed it with some 180 , and a skim of bondo to hide the weld. Trans tunnel 1 x.jpg
  23. mohead1
    mohead1
    Lol, looks smooth...everytime i try that it comes out wrinkled looking. I have an old argon bottle i will try and use as a helper get it rolled over. After i sectioned the body, i need a taller tunnel to give bellhousing clearance.
  24. Baron
    Baron
    Mounted the battery box and kill switch this past Friday. Picked out the material for the seat, and hope to have that upholstered in the next few weeks. Battery box 1.jpg Battery box 3.jpg Battery box behind seat 1.jpg
  25. loudbang
    You getting any of that arctic storm going your way?
    Baron likes this.
  26. Baron
    Baron
    We had snow flurries yesterday, but melted as soon as it hit the ground. Nice and sunny this morning, but rain came in this afternoon. Better weather will be coming soon. All car events have been canceled her in New England. Hopefully things will get somewhat back to normal before the summer's over.
  27. #19
    #19
    very kool traditional DIXIE
  28. Baron
    Baron
    Finished the fuel line/filter and vent hose yesterday. Nice when your able to start it up with the key for the first time.
  29. wheeltramp brian
    wheeltramp brian
    Sounds like a hotrod should,congrats!
  30. Baron
    Baron
