Projects 1960 Pontiac Catalina Stick Car!
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Mar 3, 2020.
  1. BSL409
    BSL409
    Very cool Congrats!!
    31hotrodguy likes this.
  2. engine number 37M.....'62 & 63, 389, 2 bbl, 283 hp, automatic.
  3. mgtstumpy
    mgtstumpy
    stillrunners likes this.
  4. 31hotrodguy
    31hotrodguy
    Took the rear seat out of the 63 star chief and surprisingly it fits okay.... at least we’ll enough until a stock one falls from the sky along with a front seat![​IMG][​IMG]
  5. 31hotrodguy
    31hotrodguy
    Had had high hopes to pull the engines out of the two cars but the rain slowed us down. However; the 63 engine is actually Pontiac blue underneath the dust and grime. [​IMG][​IMG][​IMG]
  6. 31hotrodguy
    31hotrodguy
    scotty t likes this.
  7. s55mercury66
    s55mercury66
    from SW Wyoming
    Well, if a man is wearing a dress, then it becomes a man's dress.
  8. egads
    egads
    Just FYI, That right side fender mirror is pretty hard to find in decent shape. As a pair they could help fund your project.
  9. 31hotrodguy
    31hotrodguy
    Thank you for the tip. I’ll be nice to it when it comes off. We’ve been pretty gentle taking stuff apart even with the stuff that was crunched.
  10. 31hotrodguy
    31hotrodguy
    I got my adapter from Butler yesterday so hopefully now I can mock up the 63 engine with the later bellhousing. [​IMG]
  11. earlyride
    earlyride
    from california
    chryslerfan55 and 31hotrodguy like this.
  12. earlyride
    earlyride
    from california
    Great tip on that CLR thing, could have used that on a couple of cars that came my way
  13. 31hotrodguy
    31hotrodguy
    Engines disconnected. Ready to be pulled. Hope I never forget pictures like these. [​IMG][​IMG]
  14. Bullit68
    Bullit68
    from Verona, PA
    This was the stamping on front passenger side of engine block on my car, and the VIN. 494F931B-8B5A-4856-AA6E-B18F7A2B5413.jpeg DB2E7C93-5C2F-47DB-BD4B-A2C8014F9C40.jpeg
  15. 31hotrodguy
    31hotrodguy
    I didn’t realize they stamped the vin into the engine! Cool
    1947knuck, mgtstumpy and Bullit68 like this.
  16. rowdyauto
    rowdyauto
    Just saw this post, I have a lot of 60 Pontiac Catalina parts if interested. I probably have enough trim to do a complete car plus other parts.
  17. 31hotrodguy
    31hotrodguy
    Thank you! I’ll touch base soon!
    1947knuck and chryslerfan55 like this.
  18. 31hotrodguy
    31hotrodguy
    Boys did good pulling the engine out of the 63. Not one broken part. I was impressed! [​IMG]
    Obviously dad helped they did the dirty work.
    j-jock, MO54Frank, scotty t and 10 others like this.
  19. 31hotrodguy
    31hotrodguy
  20. 31hotrodguy
    31hotrodguy
    The 63 block bellhousing bolts are 7/16 and the scatter shield looks like 3/8’s. Pontiac used different bolts on the later engines??????
  21. 31hotrodguy
    31hotrodguy
  22. My 57 engine uses 7/16ths bolts.
  23. 31hotrodguy
    31hotrodguy
  24. 31hotrodguy
    31hotrodguy
    Not a whole lot of progress this past week as I am having to rebuild my kitchen due to water damage. But I did get the 59 engine and trans unbolted. Hopefully I’ll get it pulled this weekend.
    The kids and I have been polishing the original paint for fun. It amazes me what can been done to original paint. Can’t do that with clear coat! [​IMG][​IMG][​IMG]
  25. sliceddeuce
    sliceddeuce
  26. 31hotrodguy
    31hotrodguy
  27. 31hotrodguy
    31hotrodguy
    We were able to get the 59 engine out of the Catalina before it started raining. One of boys[​IMG][​IMG][​IMG][​IMG][​IMG] made the comment “this is exciting dad, we’ve never taken the engine out of a car with the front fenders on.” Lol I’ve had them take plenty of cars apart. I guess it was good practice for doing it to a “nicer” car.
  28. 31hotrodguy
    31hotrodguy
    So the little 3 spd is only 16 inches long from the front of the case to the end of the tail housing which is about 5 inches shorter than a regular T10. I believe 60 was the first year for the 4 spd? Or did they have a different cross member/trans mount with an obviously shorter drive shaft for the T10?????? Does anybody know????[​IMG]
    1947knuck, chryslerfan55 and loudbang like this.
  29. stuart in mn
    stuart in mn
    1960 was the first year a four speed was offered in Pontiacs. I believe it was a mid-year, special order thing; it wasn't a regular production option until 1961.
    I don't know about 1960, but in 1961 they came with long or short tail shafts, depending on whether they were installed in a Catalina/Ventura or a longer wheelbase Star Chief/Bonneville.
  30. That's a Muncie 318 trans. Identical to the 318 used in Chevrolets. They started using the short tailhousing and rear mount in 1958. I notice your scattershield is drilled for both GM and Ford Transmissions. A full syncro ford three speed from behind a FE would be plenty strong for your car. Some GM actually came frome the factory with a ford Warner three speed trans.
