Ok in trying to put the front of the car back to looking orignal they did a job on fitting the radiator for the 302 when they swapped it, I'm trying to put the original stuff that holds the radiator, the first pic I'm guessing goes on the top, how many different pieces hold the original rad in? The U that cradles the rad, 2 corner pieces and the top that I have pictured? Sent from my SM-G955U using The H.A.M.B. mobile app
This is the only good picture I have. This is a 1953 Mercury. I imagine it is similar to your customline. I don’t believe I have the piece in your first picture?? It all bolts to the inner fender and the u shaped bracket sat on a rubber shim/ bushing with a spring and nut under the radiator support. Hope this helps. By the way I didn’t have a shroud??
Thank you so I think I figured it out, the v8s and i6 were set up differently mine was a i6 factory that didnt have the top piece Sent from my SM-G955U using The H.A.M.B. mobile app
