Technical ***April 2020 Banger Meet Thread - Shelter in Shop***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 31, 2020.
  1. winduptoy
    winduptoy
  2. Hank56
    Hank56
    from NC
    07CBD703-166C-487B-9A89-6A0653201716.jpeg Checking in ...took my banger powered T rpu out a handful of times this last weekend...
    Shutter Speed, rwrj, Old Dawg and 3 others like this.
  3. noboD
    noboD
    Let's see the rest of it.
    winduptoy likes this.
  4. Hank56
    Hank56
    from NC
  5. railcarmover
    railcarmover
    We are not 'essential' we are expendable brother..Buttonwillow ain't nothing but a sport model truck stop (just like the rest of this wonderful valley,the worlds largest walmart with a meth problem :) )
    Old Dawg likes this.
  6. noboD
    noboD
    Hank56 Looks pretty basic and a lot of fun. Thanks.
  7. Jet96
    Jet96
    from WY
    The blown banger was a pic I saved who knows when... unfortunately no info
  8. winduptoy
    winduptoy
    Another April Fool.....you got me. Stay Healthy
    Jet96 likes this.
  9. Damn, my kid got me too.........
    It sort of looks like Martinez's from the lakester, prior to rapid crank disassembly.
    winduptoy and Jet96 like this.
  10. V4F
    V4F
    from middle ca.
    rapid crank disassembly............. that sounds really painful
  11. winduptoy
    winduptoy
    It seems like it is number three son Rodney that leaves the scene first or this here flange IMG_20200219_150036945.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    Jet96 likes this.
  12. looks like a "C" crank flange without weld reinforcement.
    Hope it didn't do much more damage
    J
  13. winduptoy
    winduptoy
    You are right on again....only damage was to the crank...the engine just wouldn't hook to the drivetrain...the engine was still running after it broke is the story I got
  14. Glad to hear it is only the crank, should be fairly easy to fix
    Had one just shake the flywheel loose, no wire, backed off and disengaged the clutch
    As you can imagine just tore up the flywheel and crank flange.
  15. Dustyp489
    Dustyp489
    Just wanted to check in. Like the blown banger
    Skip
  16. Yup! Just about every time I broke a "Banger" crank, the engine ran on! Due to the incumbent harmonic of a four cylinder inline ( particularly a long stroke, three main) crank; that crank WILL weaken. Virtually all breaks will occur at or near the rear main (including the flange). I first tried a Harmonic Damper on the nose of the crank (a Scat). Worked for awhile longer than others; but it broke. About 15 years ago I put to use a Crower 5 main crank. I understand that it had been ground out of a solid forging. Putting five mains in a Model B block is "No Mean Feat"; but with a talented machinist it can be done. I kept a Harmonic Damper on my new crank (just in case)! For those of you that run your Model A/B at 2500 rpm (no greater than 3000); I don't think you should worry much. However, a Harmonic Damper WOULD help. I've heard studies showing that twisting harmonics develop on our engine's cranks (depending on the particular piece of steel) between 3000 and 4000 rpm. The cranks I'd broken all seemed to come apart when I'd run the engine well above the 4000 mark; and had been coming down though the 3000 to 4000 rpm range!
    Jet96, rwrj and winduptoy like this.
  17. ghalperin
    ghalperin
    I installed an exhaust cutout and used Model A brake linkage and a cut down Model A brake cross shaft to make a floor mounted operation lever..
    Shutter Speed, dudley32, burl and 6 others like this.
  18. denis4x4
    denis4x4
    from Colorado
    Avatar was 20 years old, so I updated it with photos that show the Moon discs with Dzus fasteners. Still need to iron out some bugs and install a new quick disconnect steering wheel hub 9BB587CF-D8DD-4038-833E-67F1AFB9E7FE.jpeg 4C814102-4827-403B-81BB-E161427423B6.jpeg
  19. winduptoy
    winduptoy
    Yep, the handiest tool box I have ever bought. Picked it up at auction and it was a PAPE unit, Forestry out of Washington state. Was used pretty hard....looks like you keep yours much nicer IMG_20191216_110547099.jpeg
    Old Dawg and Jet96 like this.
  20. V4F
    V4F
    from middle ca.
  21. railcarmover
    railcarmover
    That's what I like about rail,no off roading,no mud..dont get me wrong,I worked the woods some its makes for a nice view from the office..but yeah,they are like a pocket on a shirt..handy as hell..
    Old Dawg and winduptoy like this.
  22. V4F
    V4F
    from middle ca.
    im noticing lack of radiator support rods (fire wall to radiator)
  23. Hank56
    Hank56
    from NC
    Yes no radiator supports yet...I’m not happy with the 30/31 radiator... the radiator is 2 1/2 inches higher than the cowl...it’s the only thing I don’t like about my rpu...I used a 30/31 chassis because it’s what I had at the time...I’ve got a running 28/29 chassis now I’m gonna put the body on that chassis in the next week or so...the shorter radiator should line up a little better with my T cowl....I’ll get supports and figure out a hood when I get it swapped...I took it for a spin through town yesterday and I will again this afternoon....it’s 75 and sunny here in NC today....
  24. V4F
    V4F
    from middle ca.
    just a comment . you can have the '31 radiator cut down . and you can cut the shell to fit
    its all in your taste , but sure you will do good
    my family is from N.C. ............ rainy & cool here in CA.
  25. railcarmover
    railcarmover
    Shame you aint closer,id swap you a good 28/29 for that 30/31..got a slug of them..
    Hank56 and winduptoy like this.
  26. fur biscuit
    fur biscuit
    77B4EE58-015E-469A-9420-FC04D75EF7F4.JPG Well, guess I missed my date with Bob. But better late than never? So, who wants to here a bad joke with a worse punch line? Sepsis. Sorta had a reason to be laid up. Then I dropped my radiator and bent in significantly. Sad. What to do? Reboot! 93” WB , 7” engine set back. Drop is mocked up, need to make some plating and gussets.
  27. winduptoy
    winduptoy
    @fur biscuit was wondering where you were. Sorry to hear you had sepsis nasty stuff.Glad you are improved...the attachment is locked...
    Maybe that is intentional making for a mystery...
  28. fur biscuit
    fur biscuit
    Funny phone stuff. Think I fixed it. When the doctor starts in with the...well we can chop this, he wasn’t talking about a Duece roof.
    Jet96 and winduptoy like this.
