Projects My '32 5 Window Project - Done and Cruising!!!
Discussion in 'The Hokey Ass Message Board' started by LM14, Apr 14, 2018.
  1. Looking good. Sorry about the paint shop issues. I know exactly how you feel.
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
  2. Dash is looking good! Thanks for sharing the details on the tank build, too.
  3. loudbang
    Too bad they are hindering your progress on the Coupe. At least the gauges look great.
    brady1929 and 1947knuck like this.
  4. alchemy
    alchemy
    Maybe the paint will get done when the upholstery is finished. Then you can bolt them on and not have them laying around getting dirty and scratched.
    brady1929 and loudbang like this.
  5. raven
    raven
    Wow, those gauges look great. What kind are they?
    r
  6. LM14
    LM14
    from Iowa
    Call this morning from the chrome shop. Dash surround was done so I ran down to Quincy to pick it up. They did a great job on it.
    I had welded 2 holes shut (probably an old tach mount) and spliced a piece in the lower section to make it straight across. I had metal worked it and they took it a step further and copper filled a couple pin holes to perfection. Put it together and stuck it in to check the fit. Couldn’t be happier with it.
    No news on the ‘32 upholstery. Hoping it’s done this week.
    SPark
    B00920FC-F9E5-457E-85E4-790C39743DF5.jpeg 39593C96-70B8-4E6D-8BA6-CF11B02D783B.jpeg 767C21D7-334B-4CB2-8CF3-760B1BBCF4AD.jpeg 4CFD4D4F-2087-449A-9FD2-8028035D9389.jpeg 14127103-A7D3-4332-8049-CA38A920250A.jpeg ACD0B8D1-F380-47CD-B040-468E47E47614.jpeg 4ECA3F61-7AE6-4702-979F-304021B4D60F.jpeg 6FBDB1F1-2DE7-40BA-BCD4-E72BBAA62C8A.jpeg A5317A69-7F6B-47A8-B0F9-0A2247CDA388.jpeg 48777AE2-D5CE-4F08-81A9-C200CB1F6EA2.jpeg D63B68AF-B5F8-4670-BA7B-6DAA4C892E60.jpeg
    Petejoe, Stogy, brEad and 9 others like this.
  7. LM14
    LM14
    from Iowa
    No news on the ‘32. Though they would be done this week. Getting anxious.
    Been working on the unibody some. Kind of slow lately. Got the right door all stripped out so it’s a bare shell. Started on the left side today. Restoring parts as they come out. Crazy that some look brand new and the piece right next to it is rusted.
    Got the center seat/arm rest widened and made a new mounting base for it. Have all the mounting holes drilled. It’s ready to go to upholstery.
    Also started routing brake lines and figuring where to put clamps and mounts.
    Supposed to get an infusion tomorrow. Kind of torn on if it’s a good idea or not. Might skip this one until the virus crap slows down a bit. Think spending a half a day sitting around a hospital is a bad idea right now.
    SPark
    D7A85553-434C-4124-BC0C-A9BDA45AA1FC.jpeg 2DF37651-3B3A-4C36-A678-964E7B1E1E62.jpeg 96E38AD8-E9AB-474B-BF08-6226D423A828.jpeg CF4E7B33-EF11-4359-893E-DBD050A884A4.jpeg 05AA1FA5-A882-432E-8351-6629E971571D.jpeg F8AE783A-0C89-463A-8D40-0A59FA0BCCB5.jpeg 5DC86569-DB88-4278-A1F6-5A8B9E6599B5.jpeg 30FC3D7F-D842-491D-BDFF-791F6142FEAC.jpeg C7588247-5CD3-429D-8C63-966351DAAE37.jpeg 70A22D11-02FD-4299-B5EC-072E21661E2C.jpeg
    Petejoe, Stogy, Nicholas Coe and 5 others like this.
  8. LM14
    LM14
    from Iowa
    Decided to skip my infusion appointment today. Will see what the world looks like in 3 weeks. There are much sicker people up there than me and with shortages of basic PPE and the restrictions in place up there we decided to back out this time. I also think I’m safer in my garage than at a hospital right now. Things will get better.
    That said, I got a lot of little things done on the unibody today. Restored the brake pedal.
    Gutted the left door.
    Bead blasted a bunch of engine spacers and brackets. Blasted the water pump pulley. Then etch primed those parts.
    Finished the modifications to the power steering pump mounting bracket and got it in etch primer, too.
    Finally I got the engine ready to pull.
    Slow but fairly productive day.
    SPark
    2020-30a.jpg 2020-30b.jpg 2020-30c.jpg 2020-30d.jpg 2020-30e.jpg 2020-30f.jpg 2020-30g.jpg 2020-30h.jpg 2020-30i.jpg 2020-30l.jpg 2020-30j.jpg 2020-30k.jpg 2020-30m.jpg 2020-30n.jpg
  9. We backed off treatments for my mom for that reason & to hopefully boost her immunity. Stay healthy, lot of us praying for you and sending you positive energy.
    Randall, Stogy, Nicholas Coe and 3 others like this.
  10. LM14
    LM14
    from Iowa
    Still no '32 update. Patiently waiting. Staying at home anyway.
    Painted some unibody parts. Created a bracket for the proportioning valve and plug welded it to the firewall. Not much but it's progress.
    SPark
  11. Looking good on progress. Take care of yourself Steve.
    Phil
  12. loudbang and chryslerfan55 like this.
  13. LM14
    LM14
    from Iowa
    Very short day today. A few more parts painted. Blower motor firewall cover and front fender/firewall mounting brackets are done.
    Also quit putting it off and pulled the engine and transmission this evening. Split them and got the engine mounted on the new engine stand. Too big of a wimp anymore to rotate it by hand, this stand has a crank to make it rotate. Getting lazy.
    Been soaking the emergency brake assembly every day with PB Blaster and tapping on it with a little hammer. It was rusted solid. After 3 days it broke loose last night and after flushing it today with more PB it works like a new one. Cable looks new, all the rust was in the interior piece that bolted to the dash and inside of the firewall.
    Next up is filling the remaining holes in the firewall. Also need to pull the engine apart to order rings and bearings.
    Tomorrow I'm contacting upholstery and paint to try to get the '32 off dead center. Really want it back home and get it together, weather is getting nice here, will need to do the little details and start driving it!
    SPark
    2020-32a.jpg 2020-32b.jpg 2020-32c.jpg 2020-32d.jpg 2020-32e.jpg 2020-32f.jpg 2020-32g.jpg 2020-32h.jpg 2020-32i.jpg 2020-32j.jpg 2020-32k.jpg 2020-32l.jpg
  14. Still loving this two for one build thread! Stay safe & healthy!
    Randall and loudbang like this.
  15. LM14
    LM14
    from Iowa
    ‘32 updates! Upholstery should be done Wednesday or Thursday. Just a few details to finish up on and it will be done. Paint should be done a week after that. Said things had slowed down a bit and he would get it back in the rotation so it got done.
    On the unibody I got all the remaining holes filled in the firewall today. Filled 42 holes in total. Also worked the pinch weld at the firewall/cowl junction. Poor thing had been abused in the past. Took a lot longer to fix it than I ever dreamed it would.
    Time to strip the front suspension and steering back off and finish welding the front crossmember and motor mounts to finish that up.
    SPark
    F99C9B74-8D52-4AFF-AE39-8576752D3E0C.jpeg 62233CA7-C3C7-4768-8C94-50787EE69B51.jpeg 4CCCC982-9B01-46EB-AADF-4684289E1D92.jpeg 68A945C3-8A85-4EE8-92A4-042D7556158F.jpeg 1B483225-87F2-4E9B-85DF-9D072B1C6B02.jpeg 7AFD3D34-BB4B-4E56-A691-17A582FE53CA.jpeg 2DDDCA51-2AA8-47CD-8EC5-70EFDE9CA4A1.jpeg B1FD0450-5C7A-448F-80D3-3A9F37EBC973.jpeg CD989A2B-6F87-4D24-8703-A2DD08540967.jpeg
  16. Looking forward to the remaining assembly on the '32. Then see it on the road!
    Phil
  17. sliceddeuce
    sliceddeuce
  18. Ford blue blood
    Ford blue blood
    Always found it much easier to make new holes then to fill unused holes after the paint is on! I just weld them all up and make new holes if needed! I try to make the firewall penetration free on everything I build. Makes routing and such a pain but I like it smooth and shiny.
    LM14 and loudbang like this.
  19. LM14
    LM14
    from Iowa
    Cleaning the shop tomorrow, putting all the unibody stuff back in the truck (and on the shelves around it) so I don't lose things. Clean the work bench and move the Mustang in beside the unibody.
    Got the call today that the '32 upholstery is done! Headed down Saturday morning to pick it up (raining here tonight and tomorrow but not Saturday). Anxious to get it home. Hope it was worth the wait!!! Time to put it all together, sort a few issues out, finish up the wiring, a little carb work and wait for the grille shell and hood to come out of paint next week (hopefully).
    Did get the unibody gas pedal and emergency brake lever/cable all restored and buttoned up today. Tomorrow they go in their little zip lock bags until it's time to put them back in the truck. Even fixed the roughed up mounting screws for the brake lever to dash mount. Also created new rubber firewall to inner fender mounts. Think the originals were past serviceable at this point.
    Made some really good progress on the unibody these past 2 months. Big window cab section in, seats mounted, center seat/arm rest created and mounted, steering finished up, motor mounts in, smoothed the dash and firewall, created a new dash insert, doors adjusted, door gaps corrected, cab and doors stripped, built a gas tank, started on brake lines, several small sub-assemblies restored and ready to go in, engine and tranny on stands and ready to rebuild and fixed a lot of smaller issues I had been putting off. Time wasn't wasted waiting on the '32 to return. Was nice accomplishing something on the old project again, need to get back on it after the '32 is done and get it drivable this summer.
    SPark
    2020-33a.jpg 2020-33b.jpg 2020-33c.jpg 2020-33d.jpg 2020-33e.jpg 2020-33f.jpg 2020-33g.jpg 2020-33h.jpg 2020-33i.jpg 2020-33j.jpg 2020-34a.jpg 2020-34b.jpg 2020-34c.jpg 2020-34d.jpg 2020-34e.jpg 2020-34f.jpg 2020-34g.jpg 2020-33l.jpg 2020-33m.jpg 2020-33n.jpg 2020-34h.jpg 2020-34i.jpg 2020-33p.jpg 2020-33q.jpg 2020-33r.jpg
  20. Very nice work on the Unibody. I really like the chrome & engine-turned dash insert.
    Is that JB Weld on the back of the brake handle?? Brilliant!
  21. Great progress on the unibody. But I'm really looking forward to seeing the couple interior!
    Phil
  22. DenverFlash
    DenverFlash
    Nice work Steve! Can't wait to see the 32's interior. Still waiting for my ‘32 coupe body; no rush right now though - I can't travel 2000 miles till this virus crap gets better. So I've just been cleaning my shop, building a gantry frame (to lift the body), and doing extensive research to purchase a new TIG welder, so I have been pretty productive while isolated at home. Please keep the updates coming! You've got two really neat projects going.
  23. LM14
    LM14
    from Iowa
    It's got upholstery! Very happy with the work they did. Quick trip an hour and a half south to pick it up this morning. Got it home and took a few quick pics as we unloaded it. Will take better pics when all the little details are back together. Enjoy!
    Dianne said she gave me the interior for my Birthday so guess I'll take that. Best Birthday present ever!
    SPark
    interior6.jpg interior7.jpg interior8.jpg interior9.jpg interior10.jpg interior11.jpg interior12.jpg interior13.jpg interior14.jpg interior15.jpg interior16.jpg interior17.jpg interior18.jpg interior19.jpg
  24. DenverFlash
    DenverFlash
    Wow! Looking awesome - thanks for posting.
  25. loudbang likes this.
  26. loudbang
    Good stuff, bet that takes a load off your mind. :)
    LM14 likes this.
  27. Ford blue blood
    Ford blue blood
    Very, very nice! Now, how to get the rest out of "paint jail".......
  28. WOW!!!
    That's "bitchin'"!!!
  29. raven
    raven
    You be cruising in style!
    r
  30. Stogy
    Stogy
    :rolleyes:...Clean Machine...this open road milestone is inching ever closer...Happy Birthday @LM14
