Technical Routing breaklines over rearend
Discussion in 'Traditional Hot Rods' started by flyn schlosser, Mar 29, 2020.
  1. flyn schlosser
    flyn schlosser
    from phelan, ca
    Installed a 9 inch with rear disc brakes on my 32 frame with coilover . How did you guys route the brake lines over the rearend . Just looking for ideas possible pictures. Did u go stainless. I'm using a quick perfomance rearend with gm disk brakes. Any advice is appreciated.
  2. Sketch up what you want first to help yourself. You will need a line going out to the rear and a hose going to a brass block, the lines come out of the brass block. This is in broad strokes. You'll need to mount the hose to a body anchor point and a place to locate the brass block to. Weld-on tabs are available.
  3. BoogittyShoe
    BoogittyShoe
    Credit goes to Chris at Texas Speed and Restoration. IMG_20200329_135757.jpg IMG_20200329_135824.jpg IMG_20200329_135850.jpg
  4. flyn schlosser
    flyn schlosser
    from phelan, ca
  5. flyn schlosser
    flyn schlosser
    from phelan, ca
  6. BoogittyShoe
    BoogittyShoe
    You're welcome. I'm glad you appreciated it as much as I did.
  7. Almostdone
    Almostdone
    I used flex hose to go from the frame to the 9 inch rear end, then hard line across the rear end to the backing plates. I welded a bolt and some tabs on the rear end for mounting the lines. The pictures are during mock up.... lines and hoses not rubbing on things now. Steel lines I bent.
    0823353B-645F-4F5E-80CD-DC54F75B1A05.jpeg 760DF0E4-B0EC-4AB0-AA8A-9C02DFA5CEA4.jpeg BA231474-53EC-43B2-9118-FDE8D2B2941E.jpeg
    26 T Ford RPU likes this.
  8. flyn schlosser
    flyn schlosser
    from phelan, ca
  9. flyn schlosser
    flyn schlosser
    from phelan, ca
    I'm running almost the same set up I really appreciate the pictures it helps. Does the the soft line with the bolt the splits the brake line have a technical name. Thank you
  10. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Left side of the '32
    Right side
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    The hardline on the '31. Way easier with drums rather than calipers.
  12. You have to look because I painted the brake lines black and mounted them on the front side
  13. I put mine on the front side of the axle to give a cleaner look from behind. JW
    Almostdone likes this.
  14. lostone
    lostone
    from kansas
    I've thought about putting them to the front to kind of hide them from the rear view but wondered about gravel, rock damage. Where I live thats a real possibility.
  15. vinny harms
    vinny harms
  16. Bandit Billy
    Bandit Billy
    This is the SS line on the new shop truck that I bent and flared.
    Added gravel guard on the outside.
    dumprat, 40FORDPU and mgtstumpy like this.
  17. LM14
    LM14
    from Iowa
    I don't like the lines on the housing. This is how Pete and Jakes ran the stainless lines on my '32 chassis. Very little shows with the body mounted.
    SPark
  18. Mr48chev
    I don't see a wrong idea in the bunch, nice work gents. Back about 25 years ago I got a car in the shop that the rear brakes didn't work on. Guy had bought it a few days before from someone else and then figured out that it didn't stop good. Got it up on the hoist, started looking and who ever had swapped rear axles had but the U bolts over the brake lines on both sides and cinched them down. It wasn't a hard fix but the customer sure wasn't happy with the guy he had bought the car from.
    town sedan and kidcampbell71 like this.
  19. mgtstumpy
    mgtstumpy
    When routing brake lines be mindful of all clearances, this may not be an issue but merely camera angle. However if rubbing it will eventually wear through leading to failure and loss of rear braking.
  20. Phil P
    Phil P
    I just asked for a rear brake flex line for a 1966 bronco.
    Phil
  21. nobby
    nobby
    I think you have to run a vent bolt, if you use the brass block 3 way union.
    they do them shorter if you use a 68 mustang rear brake flexi
    I think its something to do with the gears whipping the oil into foam.
    the goop doubling is size maybe, then finding its way past the seals.
    town sedan and Desoto291Hemi like this.
  22. flyn schlosser
    flyn schlosser
    from phelan, ca
  23. flyn schlosser
    flyn schlosser
    from phelan, ca
    Thank you
  24. flyn schlosser
    flyn schlosser
    from phelan, ca
    Bandit Billy likes this.
  25. Almostdone
    Almostdone
    Good eye, but those pics were during mock up and the front of the rubber line wasn’t attached. It’s all good now. Thanks.
    I also painted the steel lines with Eastwood Brake Grey paint (growing up in MN), but probably overkill.
  26. Chopp'd49
    Chopp'd49
    Here is my idea on my Quick Performance 9" Housing using Nickel Copper Brake lines, 70's GM hose, Chrysler factory style vent, and some patience..... Lots of patience..... entire Rear.jpg close Rear.jpg
    swade41 likes this.
  27. goldmountain
    goldmountain
    I'm with LM14, ran individual flex lines to the wheel cylinders because I didn't like the look of a hard line across the housing.
  28. deuceman32
    deuceman32
    Because you are using a disc brake rear end, you will want flexible lines directly to the calipers for ease of servicing. LM14's photos are of a 32 chassis with coil overs, and show a very attractive way to achieve this.
  29. Almostdone
    Almostdone
    If that was meant for me... the bolt I used at the Y was one I welded to the rear end for that purpose. The vent is in another location. I’m going to use a vent ‘bolt’ like the last one in your post.
