Technical HELP ME IDENTIFY THIS REAR END-THANKS
Discussion in 'The Hokey Ass Message Board' started by bullrunmotor, Mar 25, 2020.
  1. bullrunmotor
    bullrunmotor
    from East Coast
    I'm working on old 59-60 build that started out as a 55 Crown Vic. I'm pretty sure the 10 bolt rear in it is not Fomoco. It has a bolt pattern like a Dana 25/30 series. I found a casting number 18419 on the housing. I'm enclosing photos of the unit and what the brakes look like. I'd like to identify a year range-probably Mopar if I determine that's what I got-to get some brake hardware etc. Would you all agree it is not a Ford rear end? Thanks for any help
  2. Bandit Billy
    Bandit Billy
    Rats, thought this was another Hurst Girl thread. Oh well. Movin-on bump
  3. Budget36
    Budget36
    I think it does make his butt look big.
    To the top!
    Lloyd's paint & glass likes this.
  4. squirrel
    Scrape the crap off the center housing, look for a cast number like 40 or 44 or 44-1 or something. Either on the top/front behind the pinion yoke, or on the bottom web below where the axle tubes go into the center casting.
    It's probably a Dana/Spicer, and that number will be the model.
    What's the wheel bolt pattern?
    chryslerfan55 and dana barlow like this.
  5. W6RAT
    W6RAT
    from Coos Bay
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Looks to be a Dana 41,Ford used them in 1949-56 F-1 Ford Trucks and 1952-54 Ford station wagons the 1955-56 Ford wagons went to the Dana 44. Look for this code. 1-oops.jpg
  7. bullrunmotor
    bullrunmotor
    from East Coast
    Here is casting number I mentioned-I Found 18419 stamped in housing-can one assume the '41' refers to Dana 41
  8. squirrel
    you're looking for a 2 digit number. Keep hunting.
    lothiandon1940 likes this.
  9. Make your pictures full size so we don't have to keep clicking on those tiny thumb-nails!
  10. 5window
    5window
    Thought we'd take it up a notch. Education while self-isolating. This is a the rear end of a Thompson's Gazelle. Not sure if it's named after Mickey. :)
  11. It's an old, greasy rear axle, 5 lug, probably worn out, and hard to get parts for. And if it was desirable, would've been obvious ;)
  12. jimmy six
    jimmy six
    Looks like a stock Ford to me. The 55 pumpkin style had a tendency to howl a bit . Maybe the original owner got a dealer to replace it under warranty and the put in a wagon to shut him up. Looks like it’s been there a long time.
  13. bullrunmotor
    bullrunmotor
    from East Coast
    Thanks to all that helped me out. found the Dana 44 markings on it. It appears to be of 55-56 Ford era and brakes are 1.75 in. -Sedan variety not wagon. I'm on my way to a brake job with proper parts.
  14. porschedude996tt
    porschedude996tt
    Looks like the rear end of 1967 Jeep J3000 pickup truck. That would be a Dana 44.
  15. modagger
    modagger
    :DThanks for the chuckle 5Window
