Technical ***March 2020 Banger Meet Thread***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 29, 2020.
  1. winduptoy
    winduptoy
    Crazy.... but good catch. You need to keep it under 6000 rpm
    Jet96 likes this.
  2. winduptoy
    winduptoy
    Yours is a good looker too....I had one heck of a time coming up with wheels 16 x 5" on the back and 16 x 4.5" on the front. I need to loose the spare tire and step plates on the running board. It does run good and the tires really helped the handling
  3. V4F
    V4F
    from middle ca.
    i chased one of those , turned out one rod was hitting the dipper tray . took it out & thru it away as i am pressurized . silly how things work ............ steve
  4. V4F
    V4F
    from middle ca.
    windup ............ thanks
    6" on front & 7" on rear
  5. Steves46
    Steves46
    from Florida
    Looking at relocating my horn and wanting to get some ideas from those who have done so. Thanks.
  6. V4F
    V4F
    from middle ca.
    i have small after market horn under hood
  7. Crazydaddyo
    Crazydaddyo
    Remove it completely. You will go faster.
    Jet96 and barrnone50 like this.
  8. Steves46
    Steves46
    from Florida
    Thanks. Forgot to mention I am not using a hood. I will raise it up and look underneath for a possible location.
  9. railcarmover
    railcarmover
    Unfortunately railcarmover mechanics are too..
  10. railcarmover
    railcarmover
    Swapped on the red head last night,waiting for it to warm up a bit to test drive..the womenfolk think Im crazy for swapping out the polished head,I tried to explain the need for speed trumps style.
    Dannerr, Jet96, Old Dawg and 2 others like this.
  11. rwrj
    rwrj
    from SW Ga
    @Steves46, I mounted mine inside the frame rail, angled slightly downwards to shed water and such. Works so far.
    winduptoy and Dustyp489 like this.
  12. Been too cooped up the last couple weeks with rain and all
    I made an essential attitude adjustment run this morning, all better now..........
    Dannerr, wheeldog57, Jet96 and 6 others like this.
  13. Steves46
    Steves46
    from Florida
    Thanks!
  14. V4F
    V4F
    from middle ca.
    looks good !
  15. V4F
    V4F
    from middle ca.
    that figures !!
  16. Can someone educate me? My machinist is saying he needs to make fixture for boring the main caps on my B motor and setting it up for inserts. What does something like this look like. He has one for an A but not for a B.
  17. I can believe him, especially if the bar he has was made for cutting Babbitt originally. It is probably only 1" diameter.
    I made two bars, one each for "A" and "B"
    The "A" bar is 1 1/2" dia and the "B" is 1 3/4" dia.
    My first question is which bearing inserts are you attempting? If the chev rod bearings, 2.125 od, you may end up moving the crank up into the block and away from the cam. The std bore in block is right about 2.125 dia and it may not clean up fully. I have never had to do that with the 2.146 bearing.
    John
    Old Dawg likes this.
  18. walls
    walls
    Got a Clings adapter kit for cheap(ish) and bought a lightened flywheel/V8 pressure plate from Snyders.
    I’ve had one before in a car I sold, but I wasn’t the one to install.
    Any advice?
    I also picked up recently a V8 trans with a 28 tooth gear set. Hope that’s the right one for the little old banger motor.
    Stay safe out there/work on your car✌️
    Dannerr, John Heckman, Jet96 and 2 others like this.
  19. poshdbs
    poshdbs
    Easy if you've got the whole kit. All bolts up.
  20. winduptoy
    winduptoy
    It's on the work bench
    Sent from my XT1585 using The H.A.M.B. mobile app
  21. winduptoy
    winduptoy
    So are Refrigeration Mechanics/Fitters....at least we can all have a employment where ever we roam...hell I was in Laughlin NV once with my wife. We were eating at a buffet...imagine that, and the soft serve ice cream machine was broken.
    She complained to the gal that was gathering the plates and volunteered me to fix it for them....
    Jet96 and waxhead like this.
  22. winduptoy
    winduptoy
    Looks like that could be good therapy. Gas is below $2.00 here
  23. walls
    walls
    Hope so. Looks like it will.
    How about the pressure plate? I’m assuming it’s bolt on since it’s just rebuilt by Snyders, but does anyone have a method to double check the finger adjustment?
    I’d hate to install, then find out there’s a problem.
  24. railcarmover
    railcarmover
    Ill fix anything cept the crack of dawn and broken hearts...but this here deal is a sham
  25. I will have to look up the invoice to see what they were. I know I got them from Rich Fallucca.
  26. denis4x4
    denis4x4
    from Colorado
    The chrome on the horn adds at least 5 HP 4D2B8AF2-F080-439B-8537-F6D552EBCB6B.jpeg
    Dannerr, Jet96 and winduptoy like this.
  27. winduptoy
    winduptoy
    Rebuilding Model T coils...I know, I know, Ford Barn material two more to go of eight IMG_20200322_085243676.jpeg IMG_20200322_085233930.jpeg
    Jet96, guitarguy, fourd and 1 other person like this.
  28. Much easier than "T" coils........
  29. V4F
    V4F
    from middle ca.
    those coils are really fugly inside ! good luck .
    john , will "T"s adapt to that type ?
    ive heard that , but never could get one to live . had several (used) , give up ......
  30. hardtimesainit
    hardtimesainit
    Hey Walls,
    Couple things. First, as said, see if you can purchase the several iron pieces that make install easy. First one I ever did , I made these pieces. Dumb move as I've no torching/welding kills...and it took forever grinding.
    Since you already purchased the V8 39 trans, now is the time to make placement hole in its bell housing area for front 'yoke' ball attachment piece. I used grade 8 bolt/nylock nut fastener.
    Finally, I see that you used a disc without the springs being captured . It may take a while, but these springs can/will eventually work loose (fatigue) and rattle/noise/fall out at worst. Regarding PP, make sure that each 'finger/arm' has a secure fastener arrangement where is pivots, like a cotter pin to ensure that the pin does not back out with use.
    Jet96 and poshdbs like this.
