Projects Lytles Garage 34 5w Fuel Coupe Build Thread
Discussion in 'The Hokey Ass Message Board' started by 51farmtruck, Jan 23, 2018.
  1. loudbang
    Nice improvement. :)
    1947knuck, enloe, brady1929 and 2 others like this.
  2. Marty Strode
    Marty Strode
    Sam, do you think you will be ready buy Toutle ? Maybe we can pit together.
  3. 51farmtruck
    51farmtruck
    Thats asking a lot Marty! :D
    I work way too slow, but stranger things have happened.
    If it works out, we would love to pit by you.
    I saw it's a 2 day deal this year, so that's pretty enticing!
  4. neilswheels
    neilswheels
    from England
    Glad to see this back up, great build, looking forward to updates.
  5. 51farmtruck
    51farmtruck
    Rechopped the door top for the 10th or 20th time. Finally settled on a profile that is cohesive with the driprail.
  6. 51farmtruck
    51farmtruck
    Also got the bear jaw or claw??? latch working on the drivers side. Sure shuts easy compared to the originals I've closed in the past. First time a door has latched shut on this body in a very very long time.
    coupe33, texkbc, Huge and 6 others like this.
  7. 34Larry
    34Larry
    My passenger door looks like your before pic, and I have noticed the same on many of the real Henry 34's. Had/has to be a factory thing.
  8. 51farmtruck
    51farmtruck
    Working on getting the inner door structure chopped and fit to the skin. These doors are pretty light!
  9. loudbang
    Anybody else get this when trying to watch the video :(
  10. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^^ no vid ^^^^^^^^^^^^^
  11. The 39 guy
    The 39 guy
    No the video worked fine for me.
  12. 51farmtruck
    51farmtruck
    Thats a little odd, still works fine for me. Lets try it again.
  13. loudbang
    Works OK for me now. Latch closes GREAT.
    brady1929, 1947knuck and enloe like this.
  14. 392
    392
    Nice job. Should be fun ride.
  15. 51farmtruck
    51farmtruck
    New transmission setup for the coupe! We set the car up with a turbo 400 that was going to be a full manual reverse valve body deal. Now it just got a whole lot cooler.
    Clutch Turbo 400!!!
    What's even better is the entire setup used to be in my dads (lytles garage on here) Blown Hell 33 willys AA/GS car. We got the original fairbanks trans thats rebuilt , Mcleod dual disk clutch and scattershield that's out of the willys. Plus a brand spankin' new updated clutch turbo trans. Now we're going to have to cram a clutch pedal in it somewhere. I can't wait to dump the clutch in this sum bitch!
    IMG_0947.JPG 10413304_1471329163120951_6086262932434165926_n.jpg 84602198_2762066427368762_6703528386582544384_o.jpg Blown%20Hell%201.jpg 290361-1305087353-8e159a329f5815a75a99adadd09f0cb7.jpg
    AHotRod, bchctybob, 29EHV8 and 14 others like this.
  16. brigrat
    brigrat
    from Wa.St.
    I never seen those pic's, Thanks!
    You need to sell me that '57 150 that's stashed away so you could buy yourself a decent set of wheels for this project!
  17. 51farmtruck
    51farmtruck
    Not much progress to report. In a stroke of wisdom, I threw away about 11" of the inner door top structure last year. So I spent some time remaking those pieces. The inner channel had too small of depth to bend it up on the brake, so I had to do that by hand.
    Here is the inner channel portion mocked up in the door. Lot of work for something no person will ever look at.
    Here is the outer-inner portion I made with the top hinge delete mocked up. It will get its final trim once its all welded up.
    I spent about 2 mins on the shrinker stretcher to make the backside of the side window opening. It will come out a lot cleaner than trying to weld up 12 pie cuts.
    bchctybob, 62hotcat, 29EHV8 and 10 others like this.
  18. The 39 guy
    The 39 guy
    I think it is that time spent on things people will never see or notice that make a good build ( car ) a great one that will last. Keep up the good work Sam!
  19. 51farmtruck
    51farmtruck
    "IS THAT SUM BITCH CHOPPED?"
    Getting the profile dialed in
    Starting to look real good.
    Make sure both doors look the same!
    KiWinUS, AHotRod, bchctybob and 14 others like this.
  20. esrbuilders
    esrbuilders
  21. Marty Strode
    Marty Strode
    Great work, and worth the wait !
  22. loudbang
    Like the "Oval" shape to the window frames.
    1947knuck, 51farmtruck and brady1929 like this.
  23. brady1929
    brady1929
    Great job.
    51farmtruck and loudbang like this.
  24. 33Doll
    33Doll
    And here Im whining about a few patch panel, and rust repair! ( of course I don’t really know what I’m doing, and money and tools are limited!)
    Awesome thread!
    Rick
  25. Wait...what 57 F100??????
    loudbang and 51farmtruck like this.
  26. 51farmtruck
    51farmtruck
    57 chevrolet. Don't you have enough f100's? :D
    loudbang and kidcampbell71 like this.
  27. #neverenough
  28. magooz
    magooz
    Hay Sam,
    Just took a look at the build site again after a few months. Got to say how proud of you and Chris. Great work. I called Kudo to tell him and he said he'd already been following it . If you do have it ready for Toodle Kenny and I talked about coming. Been working on our '56 Chev... Just a Street Rod,
    Your friends in Seattle
    Magoo & Kenny
  29. 51farmtruck
    51farmtruck
    Small update on the coupe... ITS NOT DEAD!
    As with any long term project, life and other interests always seem to get in the way.
    I just finished up some upper door tins/upper door jamb jobbies. These babies curve every which way but loose. They look pretty straight forward and simple, but they were made in 2 pieces and follow the arc of the driprail and have a arc that goes linear from front to back.
    I wanted these to close off being able to see inside the car through the door jamb. Plus they strengthen the body up real good.
    enloe, RustyBullet, porkshop and 10 others like this.
