Technical 1937 flathead lost bolt..help!
Discussion in 'Traditional Hot Rods' started by Goodguy65, Feb 26, 2020.
  1. There are Magnetic and non magnetic stainless, I'll keep on trying to help by recommending, I don't read whole threads, they're usually kind of wordy and don't say enough that helps.
  2. Rckt98
    Rckt98
    You seriously thought that after 28 posts on this thread you were the first to suggest a magnet?
    Give me strength.
  3. Get off the island you're getting the fever.
  4. BJR
    BJR
    Can't we all just get along?:D
  5. Jack E/NJ
    Jack E/NJ
    from NJ
    alchemy>>>Through a casting oil drainback hole and hung up on top of the cam? >>>
    We seem to be coming back to this possibility here and on the barn. Get out the coat hanger again and start jambing it in and around the drainbacks to see if might drop down. Jack E/NJ
  6. alchemy
    alchemy
    Turn the car upside down and shake it.
  7. X-cpe
    X-cpe
    Just button it back up and fire it up. It'll take about thirty seconds to find it. LOL
    Rickybop, LOU WELLS and Goodguy65 like this.
  8. bonzo-1
    bonzo-1
  9. Why don’t you look on Amazon at one of
    those cameras small enough to look down drains. I picked one up for about $20 and it has been a lifesaver. It’s called an “endoscope”.
    LOU WELLS likes this.
  10. Rckt98
    Rckt98
    Have you found it yet?
  11. BoogittyShoe
    BoogittyShoe
    I think he left after "Turn the car upside down and shake it."
    I like these mysteries but not when they leave us cliff-hanging.
  12. I lost a bolt working on my engine , couldn't find it finally gave up looking . About a week later I grabbed for my overhead trouble light there stuck on the magnet on head of lamp was the missing bolt !
  13. Goodguy65
    Goodguy65
    sorry for the delay in the update..had to build a target to throw tools at...no bolt to be found so.....
    I am pulling the motor..the front end has been disassembled, rad out and motor stripped.
    turns out the back 2 plugs on the pan rail in the block are leaking..thinking about adding a couple goodies while its upside down..
    any suggestions as to what would be good for a 37 flattie? I will likely put new water pumps in as a start.
  14. chicken
    chicken
    from Kansas
    Well ,a blower would be kinda' cool....
    Terry
  15. The intake is easy to take off - try that first and see if you have a better shot at finding it. If no luck, you are on your way to pulling the motor anyway so no harm or time lost ...
    lothiandon1940 likes this.
  16. Bandit Billy
    Bandit Billy
    Conversations on the HAMB are a lot like mine and Mrs. Bandit. We don't pay attention to each other either :cool:
  17. Oops - I blew it ...... sorry bout that ......
  18. Goodguy65
    Goodguy65
    This is what I started with before the tear down looking for 1 bolt. :cool:
    And this is where I am at now :mad:
    Just waiting on my engine stand adaptor from Kurt Stumpf...
  19. nochop
    nochop
    from norcal
    Vacuum cleaner, I wouldn’t use compressed air as it might jam it. Try adapting a small tube or hose, you my get lucky
  20. Goodguy65
    Goodguy65
    yep, tried that as well..made a nice adaptor for the shop vac..no luck.
  21. nochop
    nochop
    from norcal
    Damn
  22. BJR
    BJR
    Isn't that what they shove up your ass when you get a colonoscopy?
  23. Goodguy65
    Goodguy65
    BJR you are correct...I tried running out of the hospital with it still in there but they caught me at the front door..."I just wanted to borrow it" I said...they walked me back in for more cookies and apple juice. so close!
  24. Bandit Billy
    Bandit Billy
    You were just being thorough! :cool:
  25. whtbaron
    whtbaron
    from manitoba
    Kids got me one of those colonoscopy style cameras for xmas one year... LED light on the end and everything... have to say it's been a bit of a disappointment when it comes to actually seeing whats going on inside a motor. I've had good luck wrapping fresh duct tape around a light wire backwards for nabbing non-magnetics. Hate to tell you this, but I lost a 1" wrench once while changing a combine engine... no, that's not a typo... it was a great big 1" wrench. That was 30 yrs ago and I've worked in that shed ever since... never ever saw that wrench again. Probably went down the road when we sold the combine.
    LOU WELLS and nochop like this.
  26. Petejoe
    Petejoe
    from Zoar, Ohio
    With the intake off you can take advantage by installing a PCV setup.
    I’d save racing goodies for a larger engine. 21 bolt racing stuff is rare and expensive.
  27. guy1unico
    guy1unico
    This happened to me and thru God's intervention I found the nut i(in my case) on a little shelf inside the the block below the oil breather at back of intake...I was trying to put in a fuel pump rod...look hard with a flashlight before disassembling anymore.
    If it has traveled beyond the point you might be able to turn the crank with your wrench s;lowly and the bolt may fall out.
  28. Ubermich
    Ubermich
    Have you had someone else look for it? I don't know how many times I've spent hours searching for something only to have my wife walk in and say "you mean this thing?"
    Atwater Mike, X-cpe, Rickybop and 2 others like this.
  29. Bandit Billy
    Bandit Billy
    Well it sure wasn't a vacuum cleaner. That's a Dysonoscopy.
    BJR, belair and LOU WELLS like this.
  30. LOU WELLS
    LOU WELLS
    from IDAHO
    Refreshing To Know That One Lost Fastener 73475233_3336293036445113_6171512591513288704_n.jpg Can Generate So Much Advice And Humor...Well Done..
