Projects My First Custom 53 Mercury M100
Discussion in 'Traditional Customs' started by NSemeniuk, Mar 12, 2020.
  1. NSemeniuk
    NSemeniuk
    Ive never really posted on here before... I tried my hand at turning my truck into a late 50’s style mild custom truck. I’ve had the truck for about 7 years and last year I decided to make a custom grill. My friend was tossing away a rotten 54 Chevy car grill so I took it. That snowballed from there. Here’s what I ended up with. I’ll post a few pics from the build as well. I made lots of mistakes and paint is not perfect but it’s mine, and I made it at home and I’m gonna drive it. [​IMG][​IMG]
  2. NSemeniuk
    NSemeniuk
    I started with a rotten 54 chev grill my buddy was tossing out. I welded it between stock headlight buckets. [​IMG][​IMG][​IMG][​IMG][​IMG]
  3. jimmy six
    jimmy six
    So your planning on having more since this is your first?
    loudbang, kidcampbell71 and NSemeniuk like this.
  4. Peanut 1959
    Peanut 1959
    I saw pics of your ride posted on one of the kustom threads here on the H.A.M.B. and immediately fell in love with it! The use of the Stude taillights is an unexpected treat. I'm curious: Did you used two '54 Chevy grille bars, or is the top bar is from a different source?
    loudbang and NSemeniuk like this.
  5. NSemeniuk
    NSemeniuk
    I wouldn’t mind more cars.... lol
  6. NSemeniuk
    NSemeniuk
    Yes both bars are from the same chev grill.
  7. NSemeniuk
    NSemeniuk
    Then I decided to cut the hood and pull it forward to match the peak of the grill. [​IMG][​IMG][​IMG][​IMG][​IMG]
  8. NSemeniuk
    NSemeniuk
    The truck already had a custom lower valence. I think this truck use to be cool once up a time but was pretty cheesy when I got it. There’s some strange things changed on it. Like the body lines on the front of the fenders fade away. I just didn’t like the look of it it was arched kinda looked like a roll pan on the back of a late model truck. So I just flattened the bottom out. [​IMG][​IMG]
  9. NSemeniuk
    NSemeniuk
    Then I scored some Plymouth bumpers at a flea market. They were rough, corners were rotten through. But I was going to use chrome paint just because of the stuff I was working with. I put the two corners from the Plymouth rear on the front and the center is from a front bumper. I put the Plymouth rear on the back of the truck. I cut the bumper every couple inches to change the shape. Welded in wedges.after I had that shaped the way I wanted it I went to finish welding it and didn’t reclamp it. By the time I was done I realized I was back to the original shape. That was a frustrating night. Got to do it all over again and learned a lesson.. [​IMG][​IMG][​IMG][​IMG]
    Gasser 57, hfh, loudbang and 6 others like this.
  10. NSemeniuk
    NSemeniuk
    Then I needed to figure out how to make some splash pans. [​IMG][​IMG][​IMG]
  11. straykatkustoms
    straykatkustoms
    Wow!! Thank you for posting your build pics. Your truck is one of my favorite kustoms that I have seen this year. Posting build pics are important, because you might influence someone else to start building a kustom. Cut it up, its only metal..
  12. NSemeniuk
    NSemeniuk
    I wanted some license plate frames but I wasn’t sure what to do. I had two Plymouth bumperettes so I decide try something. I thought I could make two frames with two bumperettes if I split them. So I cut one in half and made a box to go between the two halves. I liked how it worked out so I made another one. I sectioned the front one but left the rear one so I could fit lights in.. [​IMG][​IMG][​IMG][​IMG][​IMG]
  13. NSemeniuk
    NSemeniuk
    Wow thanks!!! I’m pretty flattered, I’ve gotten a lot of positive comments so far. I had some good friends that pushed me and guided me in the right direction and taught me a lot. I really had a good time doing this project.
  14. NSemeniuk
    NSemeniuk
    The next big problem I had was turn signals. I was stuck here for a while, my friend Chris nudged me in the right direction. Told me to use my stump and make some pods to go under the buckets. The lenses are just cut out of a cheap led dome light, heated up and shaped to fit. [​IMG][​IMG][​IMG][​IMG]
  15. DIYGUY
    DIYGUY
    from West, TX
    Well now we have a good example of chrome paint!
    Looks great and nice work!
    loudbang, Peanut 1959 and NSemeniuk like this.
  16. NSemeniuk
    NSemeniuk
    For taillights I didn’t know what to do except I knew I did not want to use 50 merc lights. I was at a fleamarket and a friend found an really old magazine and there was a tech article showing that 48/49 studebaker taillights fit ford truck fenders pretty well. So I got my hands on some. The bezels are chrome painted as well. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  17. Cool to see another Canadian Custom truck! Great work.
  18. NSemeniuk
    NSemeniuk
    My tailgate was pretty ugly, must have had some kind panel at one point and had that dry area in middle so I decided to paint it. It was pretty warped and stretched outward. I tried my hand at shrinking with the torch. It worked pretty good. [​IMG][​IMG][​IMG]
  19. NSemeniuk
    NSemeniuk
    Next I had to start learning body work and paint. I really found sanding frustrating. I sanded off and swept up prob 5x more product than should have ever been used. My friend started teaching me how to spray primer in his driveway and I continued on my own at home. Then he came over and we painted in my garage. [​IMG][​IMG][​IMG]749a60fa9dbdf22690366aafe2576617.jpg[/IMG]My paint is not perfect. It has blemishes. But whatever. [​IMG][​IMG][​IMG][​IMG]
  20. NSemeniuk
    NSemeniuk
    Layout my out the scallops was tough. I found that the moved as you walk around the truck. I had to basically just choose the angle where I thought they’d look best and viewed from most often. [​IMG][​IMG]
  21. NSemeniuk
    NSemeniuk
    The tonneau cover is just plywood coated in resin. I cut out the diamond and got it sewn up in gold metal flake vinyl in same style stitch as my seats. And then I covered the rest in black vinyl. [​IMG][​IMG][​IMG]
  22. LM14
    LM14
    from Iowa
    Fantastic work. Can’t wait for more pictures.
    SPark
    loudbang, 54delray and NSemeniuk like this.
  23. DIYGUY
    DIYGUY
    from West, TX
    Really appreciate the in progress pics. Not always apparent in the finished product.
  24. UNCLECHET
    UNCLECHET
    Cool! Nice work!
  25. Peanut 1959
    Peanut 1959
    Damn, brother! You've got an amazing eye for true, old-school kustomizing! I really hope to see you try out some more builds---even if you just sell them to fund the next one!
  26. The truck sure turned out great Nick, I’m so happy that you had fun through to the end. Have a great weekend at Motorama in Toronto this weekend...
  27. NSemeniuk
    NSemeniuk
    Thanks!! I had friends that guided me though and tried to educate me. Spent a lot of time online looking at stuff too.
  28. Squablow
    Squablow
    Even here in salt-coated Wisconsin, I never saw a '49 Plymouth bumper that rotten. My hat's off to you for fixing it. Great save there.
  29. Very cool..great Merc
  30. Gahrajmahal
    Gahrajmahal
    I love the license plate surrounds from the bumperettes. Man, what a great idea!
    what is this chrome paint you speak of and what is the process?
