Projects Hillbilly Model T speedster (attempt #2)
Discussion in 'Traditional Hot Rods' started by hillbilly4008, Dec 6, 2019.
  1. Have you heard that this year will be the last Jalopy Showdown? The showdown is the only car show I have been going to the last couple of years, that sucks.
  2. hillbilly4008
    hillbilly4008
    from Rome NY
    That does suck! I've never been, I'll have to make it a point to go this year. 5.5 hours away...
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    Making slow progress on the tail.
    Lil'Alb, The37Kid and Shadow Creek like this.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    ....This just in....peach pits and all...
    20200312_112345.jpg 20200312_112449.jpg 20200312_112455.jpg 20200312_112505.jpg
    This was on ePay as a Fordson tractor unit. The pics looked like they would work in my car. I grabbed it mainly for the box.
    Now not knowing jack about these T buzz boxes, can someone tell me what (if anything) i can use?
  5. The37Kid
    The37Kid
    That is Model T, later style that had the switch on the dash. Bob
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    All holes line up perfectly with what's left of my original fire wall. Except, either one post is missing. Or optional?
  7. GZ
    GZ
    from Detroit
    Looks like one post is missing. That missing post is for the "Battery" connection. You'll need that! It uses the same tubes/studs as the other 9. Looks like you have plenty of spares.
    From memory, on the inside, this "Battery" posts has a wire soldered to the back of it which runs underneath the lower wood piece and gets soldered to the copper contact strip that runs across the bottom wood piece in the coil box. It will be the same as the "Magneto" post which is horizontally across from it.
    When the box is installed in your car, the wire from the "Battery" will connect to this missing post and a larger wire (like the spark plug to coil box wires) will connect the opposite post to the magneto post which is on top of the transmission cover.
    Hopefully this all makes sense!
    The37Kid and hillbilly4008 like this.
  8. hillbilly4008
    hillbilly4008
    from Rome NY
    19x3...should take a 400-19 tire....now how do i make this work... 20200313_104838.jpeg 20200313_104844.jpeg
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    Shadow Creek likes this.
  9. The37Kid
    The37Kid
    Are you annealing the aluminum to form the tail section? Bob
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    Only when i feel it needs it. Im using 3003 alloy, doesnt need to be annealed unless it work hardens.
    I need to get different lower anvils for the harbor freight english wheel. It isnt letting me get the roundness i want at the very back.
    I do have a planishing hammer, may be able to use that to get there. I was going to test a piece today. I've made a bunch of scraps to test on.
    The37Kid likes this.
  11. hillbilly4008
    hillbilly4008
    from Rome NY
    Cant do much but stare at it till i get another set of hands here. Well stare, and doodle...
    Blackbob and rwrj like this.
  12. hillbilly4008
    hillbilly4008
    from Rome NY
    Getting some where. Gas welding is not yet my bag. I'm capable of hammering rivets though
    Still need to make the underside of the boat tail, then i figure I'll make a nose piece and pop her on.
    ClarkH, guitarguy, rwrj and 1 other person like this.
  13. Beautiful Iron
    Beautiful Iron
    from Upstate NY
  14. hillbilly4008
    hillbilly4008
    from Rome NY
    Life slowed down a bit because of all this nonsense going on. So im finally able to spend some time in this now. I rolled it into the center of the shop. Parts on the way. Hoping to get shit done... 20200430_171659.jpeg 20200430_171707.jpeg 20200430_171724.jpeg 20200430_171733.jpeg 20200430_171800.jpeg
  15. rwrj
    rwrj
    from SW Ga
    Still looks good. That sure is a nice shop.
    hillbilly4008 likes this.
  16. Forget about any ventilators............
    .......send bandages right away ! :eek: :eek: :rolleyes:
  17. hillbilly4008
    hillbilly4008
    from Rome NY
    20200501_105001.jpg 20200501_110137.jpg 20200501_110356.jpg 20200501_112552.jpg I love it when there is a present waiting for me at the for in the morning!
    Shadow Creek, GuyW and simplestone like this.
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    Love the honeycomb radiator.
