Technical Stewart Warner Tacho Drive.
Discussion in 'Traditional Hot Rods' started by 28rp, Mar 10, 2020.
  1. 28rp
    28rp
    Has any body on here seen one of these before. Its a NOS Stewart Warner Tacho drive kit to suit mounting to a flat head ford generator. It is missing a few parts,mainly the top mounting clamp-which I can probably make- and some sort of connector to link the
    angle drive to the gennie pulley.Any one have one similar or parts? 20200309_113844.jpg 20200309_113928.jpg 20200309_113951.jpg 20200309_114020.jpg 20200309_114042.jpg
    Outback, Deuces, bchctybob and 3 others like this.
  2. 28rp
    28rp
    Nobody has seen one of these or knows any history.? Nada from the FlatSpot on F/B either.!
    Outback likes this.
  3. That’s just cool as beans !!
    I just did a quick goggle search n a bunch of stuff came up for it
    Friggin cool home slice !
    28rp likes this.
  4. There is a thread on here from 2015, Stewart Warner tach column mount. Shows a tach mount using a flathead water pump. Never saw one of these although I have one of there tach drives that mounts under a dist. It also is NOS.
    28rp likes this.
  5. razoo lew
    razoo lew
    from Calgary
    @paintslinger805 runs one that drives of the crank on his. Doesn’t help you but I always thought that it was cool.
    Deuces, bchctybob, 28rp and 1 other person like this.
  6. 28rp
    28rp
    Thanks for the input ,guy,s. I will go look in the Google Technical Journals.
  7. 421-6Speed
    421-6Speed
    This one came off a 41 Ford firetruck.
  8. Picture of one I saved a while back; thought it was interesting.
  9. Drylake
    Drylake
    I have a tach the same as that. They're a nice looking unit! 20181008_133702.jpg
  10. fleetside66
    fleetside66
    Deuces, 28rp, alchemy and 1 other person like this.
  11. fleetside66
    fleetside66
  12. bchctybob
    bchctybob
    The SW angle tach drive is pretty common, lots of v-drive boats had them. Those adaptations are rare and very cool though.
    28rp likes this.
  13. DesertWoodGuy
    DesertWoodGuy
    Yes, I think I have one.
    I’ve been doing some research this weekend and came across this thread. At an Estate Sale on Saturday I picked up a Stewart Warner Truck Tachometer Kit. New Old Stock. It includes the tach (just under 3” w/ beige face), tach cable, and the complete generator mounting kit (plus nuts and bolts).
    For the life of me, I couldn’t determine the date but really I couldn’t believe it... the condition of the tach is utterly amazing. But once I came across this thread, I realized the date on the instructions were correct, 6/45.
    Oh, check this out, I have another kit. ; ) this other one is for a crank mount. But the gauge is 5-1/4”!
    and yes, these will be for sale. Pictures to follow...
  14. DesertWoodGuy
    DesertWoodGuy
    78FBB3D0-9D79-4456-816D-F628164006CF.jpeg 2BF85034-1694-4CA1-A2F4-CAFC04A1828E.jpeg 5BBE5066-6713-4C0D-87EA-52B98B5C287B.jpeg
    Here are pictures of the tach. And of the generator hardware and nuts/bolts.
    Box and documents are available as well.
    I also have pics of the crank setup that includes the 5-1/4” tach.
    Is this really from the 40’s? I couldn’t find anything similar on the net...
    Regards, Matt
    Deuces likes this.
  15. DesertWoodGuy
    DesertWoodGuy
    Here is a pic of the box it came in... 0F036550-8F0B-404A-B1D7-E00F8B1D809B.jpeg
  16. fleetside66
    fleetside66
    Yeah Matt, you sure it the jackpot there. Who would think? It's mesmerizing to me to see that label, since I'm so into gauges. It's funny with the estate sale finds, you rarely find a treasure that you are very into, but you do find treasures that others are into. I'm sure there's someone out there frothing at the mouth over your finds. I hope they find the right person for the right car. The tach date code is July of 1946, by the way.
  17. tubman
    tubman
    Very cool, but it must be for a low performance application. 3500 RPM maximum ain't much. A boat or fire truck (both mentioned above) seem too be appropriate.
