Hot Rods 1933/34 Ford owners! Door after your help!
Discussion in 'The Hokey Ass Message Board' started by cheepsk8, Mar 6, 2020.
  1. cheepsk8
    cheepsk8
    from west ky
    I need a little help on my door jamb. The PO put bear claw latches on this car many moons ago and finished out the jambs. It is a 34/5 window coupe and I am going back with the original latches. I also have my striker plates from Macs auto parts. Here is my problem. He evidently cut out the factory dip that housed the striker plate to install a device to hold the bear claw post. I need a photo from someone showing the original area in the jamb housing the striker plate, and an approximate measurement of the overall depth and length of the concave dip that the striker plate fits in. Thanks in advance. I can't find pictures anywhere on the web.
    kidcampbell71 likes this.
  2. 31aford
    31aford
    from az
    The indentation is a 1/2" in from the inside of the door. It is 2 3/8" tall on th bottom of the indentation 2 3/4" at top of indentation the indentation tapers in from the outside to bottom of the indentation. The indentation is 1/4" deep 20200306_172215.jpg 20200306_172134.jpg 20200306_172119.jpg
  3. BJR
    BJR
    What was wrong with the Bear Claw latches. They should be better/safer then the original ones IF installed correctly.
  4. oldiron 440
    oldiron 440
    Dumb question,
    What's wrong with the Bearclaws?
    The factory latches aren't worth a shit. Hit something and they come open.
  5. cheepsk8
    cheepsk8
    from west ky
    @31aford thanks, but what you are showing me is exactly what my door looks like after I reinstalled the original latches. Now on the body jamb there must be an indention to hold the dove tail striker plate that corresponds with the striker latch. Can you post a photo of your jamb?
    To answer the bear claw latch question, I never could figure a good way to mount original door handles on the car. The guy street rodded the heck out of this car with hidden hinges / door poppers and other 80s crap that looked like a total mess. I have got the body back like I want it finally, and this is my last hurdle.
  6. 31aford
    31aford
    from az
    The upper one is for the door latch and the bottom is for the dovetail. Which area do you need 20200306_195125.jpg
  7. cheepsk8
    cheepsk8
    from west ky
    Top one. That is exactly what i need. If u can tell me how far up from the top of the dove tail indention the indention for the striker plate starts and the length of that indention, i can build that back. Thank you so much.
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Nice save......
  9. catdad49
    catdad49
    Looks like a hot rod to me!
  10. 31aford
    31aford
    from az
    Here is all the measurements. The pocket is tapered on all three sides. The top and inside are less of a taper than the bottom. Vertical measurement at the bottom is 1.5". Horizontal is 2" at the bottom from the inside of door jamb. The taper for the horizontal start at 1/4" from the inside of a pillar. The taper for the bottom starts 3/4" from top of dovetail upper indentation. The distance between the top and bottom taper is 2 1/4" IMG_20200307_061959087.jpg IMG_20200307_062013934.jpg IMG_20200307_062233135.jpg IMG_20200307_062128739.jpg
  11. cheepsk8
    cheepsk8
    from west ky
    Thank you sir. This is one of the reasons I love the HAMB. If you ever need anything, let me know.
    Joe
    39WILLZ and kidcampbell71 like this.
  12. 31aford
    31aford
    from az
    If you need anything else I can take more measurements.
  13. cheepsk8
    cheepsk8
    from west ky
    Well , here's to the HAMB. I am pretty excited after about 7 1/2 years, I have a door that opens and closes factory without all the street rod 20200315_123642.jpg 34 door closed.jpg 20200315_123632.jpg hidden hinges, among other crap like the poorly installed bear claw latches. I am not nearly done, it is all tacked in and ready to finish, but it is functional and even if I did do it, I think it looks pretty darn good. I will turn the car around and tackle the passenger side next, heck, I may get this thing done before too long. Thanks @31aford for your help as well as @ss34coupe for the help on the door latches a while back, I will send you a couple of pics when I get the pocket dressed up. Without your help, I would have done pulled what's left of my hair out.
    hemihotrod66 and dudley32 like this.
  14. 31aford
    31aford
    from az
    Good job. I am glad to be of some help with the measurements.
  15. dudley32
    dudley32
    I just put the originals back in mine...they weren't easy to find...any pics of the whole car?
  16. cheepsk8
    cheepsk8
    from west ky
    Yeah, it is an old picture, I have posted it a few times. This old car has been started and stopped on so many times, but this year, I have really picked back up on it. Not having a reference car locally really hurts on these types of jobs. I will get there though..... 2014-09-30_17.17.40.jpg
  17. ss34coupe
    ss34coupe
    The coupe is coming along. Looking good!
  18. 33Doll
    33Doll
    Definitely put Safety latches in when you’re done!
    Or you’ll be doing this!
  19. cheepsk8
    cheepsk8
    from west ky
    It's in the plan, (safety latches) that is. I had to scavenge for 2 years to come up with enough hinges to get both doors presentable. I certainly do not want to go through the work involved in that again. Or worse, an open door at highway speeds is not my idea of fun.
  20. cheepsk8
    cheepsk8
    from west ky
    Passenger door roughed in. Learned a lot on the other side and this one took a lot less time. 20200317_154459.jpg
    ss34coupe, 33Doll and 53 ford like this.
