Projects Clark Coupe Build
Discussion in 'Traditional Hot Rods' started by etboy97, Dec 21, 2016.
  1. etboy97
    etboy97
    Thanks, I will check it out.
  2. etboy97
    etboy97
    I just realized it has been three months since I posted an update. I finished the body work and put on the last coat of high build primer. I think I ended up block sanding and primering 4 or 5 times.
    It was worth it in the long run and it looks good.
    I upended the body and finished the welding and sealing the bottom of the body and got it painted black.
    Got the inside and firewall painted black.
    I got sidetracked for a few weeks on a new to me late model commuter car I bought at a salvage auction and fixed up. It gave me a chance to practice color sanding and polishing.
    I just today finished up a last light block sand and got the body cleaned up for final paint and got the inside of my gutters pre-painted that the spray gun cant get to. IMG_20191118_175851909.jpg
    I have been thinking about the motor lately and how clean it looked under the valley pan. The trans that had come with the motor had a rebuild tag on is so that got me thinking that maybe the motor had been rebuilt as well so I decided to pull one of the heads off to find .030 over pistons so I hope it will need more of a freshening up then a complete rebuild.
  3. etboy97
    etboy97
    Got the body painted today. Here is a sneak peak.
  4. Mike Colemire
    Mike Colemire
    Great color choice.
    loudbang and Rich B. like this.
  5. Looking good!!
    Congratulations on the progress. Love the color!!
  6. brady1929
    brady1929
    Looks great. What color did you paint it?
  7. etboy97
    etboy97
    I am using TCP Global Acrylic Urethane 1710 Royal Maroon. I wanted to have them mix me up a old Ford maroon but it was about twice the cost for the exact same product as one of their standard colors they had.
    Stogy and loudbang like this.
  8. etboy97
    etboy97
    Got the body outside for a better look. I did end up with a couple runs in the paint.
    IMG_20191122_124307726.jpg IMG_20191122_124256313.jpg IMG_20191122_124327166.jpg
  9. Rich B.
    Rich B.
    from Portage,IN
    That run will sand out, great job, love the color!!
    Rich
    Tim, Stogy and loudbang like this.
  10. brady1929
    brady1929
    Thank you. Looks great.
  11. 51box
    51box
    from MA
    Nice work man, color looks awesome
  12. etboy97
    etboy97
    I got the color sanding and polish done a couple week ago. It a scary thing to start the color sanding for the first time thinking the whole time that I was going to sand through the paint. It was well worth the effort and I am very happy with the way it turned out. IMG_20191214_111116972.jpg
  13. Just beautiful, great job!
  14. loudbang
    Good job not cutting through the paint, it looks GOOD. :)
    1947knuck and brady1929 like this.
  15. Looks great!! Well done!!
  16. etboy97
    etboy97
    15784429664127860501028071805497.jpg Spraying some small parts out amongst the orange trees on a 75 degree January SoCal day.
  17. etboy97
    etboy97
    I want to get started on getting the chassis back together but have been messing with engine parts. I talked to Tim at Hanford Auto about doing my engine. I hope to get it in to him in a couple months when he has an opening. In the mean time I rebuilt my starter and got my tri power Rochester carbs done. I am using the Vintage Speed kit with the secondary bases. IMG_20200111_121907.jpeg IMG_20200116_085251.jpeg
    Sent from my Pixel 3a using The H.A.M.B. mobile app
  18. etboy97
    etboy97
    Got most of my wood in. I had to do a little trimming and shimming for it to fit. I am doing a roll down rear window and had bought a complete kit from Brattons but am finding out most of the holes in the drip pan don't line up with the wood that came in the same kit so will have to modify the drip pan some. IMG_20200208_133550.jpeg IMG_20200207_163517.jpeg
  19. Kevin Ardinger
    Kevin Ardinger
    Great pictures! They will help me immensely with the wood structure for the roof of my car.
  20. etboy97
    etboy97
    There is something magical about finally starting to bolt the shinny stuff together. IMG_20200219_153722.jpg
  21. brady1929
    brady1929
    Looks great.
    lothiandon1940 and loudbang like this.
  22. Really looking good!
  23. I am beyond envious as I have been stalled now for over a year while we move and build a new shop:(.
    Love your build. Keep up the great work.
  24. etboy97
    etboy97
    I would love to have a real shop space but am grateful for the old two car garage out behind the house. I have been working on the car as much as I can as I am anticipating going back to work full time soon so my project pace will drastically slow down.
  25. Michael Moore
    Michael Moore
    Stupid work. Always getting in the way.........
    Awesome work, and can't wait to see the finished project.
  26. etboy97
    etboy97
    I came up with some cheap roller tires/wheels. A compact spare tire assembly at my local LKQ pick a part is only 15 bucks each. The drawback for me is that they are not in my bolt pattern but I figured I could fix that.
    The back ones are 29" tall and out of mid 2000's MB ML series SUVs. The front ones are 25" tall and are out off mid 2000's BMW 5 series. The fronts I hogged out a unilug type slot then welded in large washers on the back side as a new lug seat. I was going to do the same thing to the rear wheels but quickly discovered that they are actually aluminum which I don't have ability to weld.. I was able to hog out a a unilug type slot then bevel a seat for the lugs to set on. These are definitely not for driving around on but should make good skinny rollers.
    Vic Walter, Stogy, brEad and 2 others like this.
  27. op4wd1
    op4wd1
    from IN
    What a great job, awesome metal skills.
    BTW what is the seat out of?
  28. etboy97
    etboy97
    The seat is a Dodge Caravan middle seat. Don't remember what year.
  29. Clarktm
    Clarktm
    Nice job. Thanks for all the pictures.
  30. etboy97
    etboy97
    Got my T5 trans rebuilt. It a combo of parts from three different trans.
    88 V8 Camaro trans with S10 tail shaft housing and Mustang top cover that has a neutral safety switch. I had to relocate the output shaft speedo gear.
    You also have to add a notch to the S10 shift rail for the Mustang neutral safety switch to work.
