Hot Rods Mystery Hot Rod Flathead engine
Discussion in 'The Hokey Ass Message Board' started by hotrodlane, Feb 15, 2020.
  1. hotrodlane
    hotrodlane
    I bought this old flathead from a buddy of mine to use as yard art. But after looking at how well and how large the porting on it was done. I am very curious as what all may be inside it. It is obviously stuck. But I was just going to put it in a old FED chassis that I have laying out back as yard art. Now I am thinking about cleaning all the dirt out of it and soaking it. Chances of getting the heads off without breaking them are slim as I have been down this road before.
    kidcampbell71 and catdad49 like this.
  2. Slopok
    Slopok
    Looks to be '49 and up.
  3. rusty valley
    rusty valley
    somebody put a lot of work into that thing, it must have broke something or they would not have left it out to die.
    hotrodlane likes this.
  4. To bad someone thought so little of it.
    hotrodlane and kidcampbell71 like this.
  5. Cool yard art for sure. It would be fun to clean it up and find more details, but I agree likely something broke in bottom end. But even broken, fun to try some archeological investigation.
    Sent from dumb operator on a smart phone
  6. 51504bat
    51504bat
    The 1/2 bell housing and starter plate are worth something.
    warbird1, Never2low and hotrodlane like this.
  7. catdad49
    catdad49
    Too bad that you can't soak the whole thing. Definitely had some porting done, I wonder what else?!
  8. hotrodlane
    hotrodlane
    My plan is to clean out what dirt I can and then I am gonna pull the pan and if the crank and rods looks decent. I will soak it. If not I will stop and just caulk it up to my original plan and it will be yard art.
    catdad49 likes this.
  9. Andy
    Andy
    I would have scraped the crud out it in the first two minutes. I want to see the valve guides and lifters. Radius lifters? Angled valve guides?
    The head bolts should be easier than studs.
  10. Ziggster
    Ziggster
    Damn. Let us know what it looks like from the bottom end. I was just at a guys place today to pick up some parts and he had three block for sale amongst other stuff. He said they all just had the standard cracks at the head bolts. People hoarding all kinds of stuff. He said there was a local in his 70s who had 350 cars on his property, but of course wouldn't sell any of it.
  11. hotrodlane
    hotrodlane
    I dug some of the crap out of the valley, And yes it looks like it has Radius lifters and Angled valve guides. I think I am gonna shock hit the head bolts with a piece of Brass and see if and how they come out.
    warbird1 likes this.
  12. 51504bat
    51504bat
    50/50 mix of ATF and acetone, patience and maybe a bit of luck!
  13. dwollam
    dwollam
    Stick the whole thing in a big tub of feed molasses mixed with water and it will take the rust off. Soak for a few days, rinse off and if clean enough, spray with wd40 or similar to keep from flash rusting.
    Dave
  14. there was one like it fer sale about a year ago up in Frisco, Tx..........had an aluminum intake just sitting on it........
    kidcampbell71 likes this.
  15. hotrodlane
    hotrodlane
    Thanks for the advice, but I have had trouble in the past with the Molasses damaging aluminum.
  16. dwollam
    dwollam
    I'm trying to remember if I ever put any aluminum in the molasses....
    Hadn't heard that.
    Dave
  17. scotts52
    scotts52
    Maybe electrolysis? Probably going to need some heat on those head bolts
  18. alanp561
    alanp561
    55 gallon drum and diesel.
    Algoma56 and blowby like this.
  19. B Ramsey
    B Ramsey
    i would try Evaporust. its amazing.
  20. Andy
    Andy
    I would try the head bolts first. The heads will not like any kind of acid. Ditto the pistons and timing gear. You also have an aluminum front cover that would come of easily.
  21. raven
    raven
    Citric acid maybe?
    You have a digger frame and you’re not using it?
    r
  22. Jalopy Joker
    Jalopy Joker
    hope that it works out OK for you - pic is a piece of "indoor yard art", with fried internals, 20200210_104625.jpg that is at a Hot Rod shop - display only
    VANDENPLAS likes this.
  23. Molasses will turn aluminum into a gray goo. The aluminum will ruin the molasses. They hate each other. I think I'd soak the head bolts with 50-50 acetone/trans fluid for a few weeks and then hammer on the tops of the bolts while soaking. I'd use an impact gun to remove the bolts and work my way around each head with a putty knife and a hammer, being careful and squirting my atf mix where I worked with the putty knife.
  24. v8flat44
    v8flat44
    Joker, i dig the dual ign. Fun to time it....if it ran.......Holy plug wires Batman !!!
  25. As said above, clean all the crud out of it, then keep soaking with ATF/acetone or diesel blend. Take a while, but it won't do any more damage than what's already there.
