Technical Suggestions? Got the driver’s side out, but passenger side axle stuck fast.
Discussion in 'Traditional Hot Rods' started by Shutt, Feb 16, 2020.
  1. Shutt
    Shutt
  2. A good slide hammer type axle puller should knock it loose.
    3340, scotty t and lothiandon1940 like this.
  3. Rather than a “steady” pull, I have seen mechanics use a brake drum on backwards on the studs and try to get the same effect as a SLIDING hammer by throwing the brake drum or chain with a heavy object to the outside of the loose held lug nuts to “pop” the axle loose and then free from its stuck position. I have seen this work out a few times.Good luck!
    3340 likes this.
  4. Mopar Tony
    Mopar Tony
    It may sound crazy but a chain through a wheel/tire with the chain bolted to the axle has worked for me. Roll the tire and it yanks it like a slide hammer would.
  5. be careful you don't pull the car off the stands with that come-along!
    swade41, alanp561, bundybiker and 5 others like this.
  6. With the axle retaining T bolts out you should be able to put a punch through from the back side.Line up on the back of the axle flange,and tap it with a hammer.Go from side to side,and see if it will walk the bearing out of the housing.
  7. b-body-bob
    b-body-bob
    I had one stuck tight as a drum with the housing off the car.
    I ended up trying a slide hammer, banging the end of the axle through the other side (a jack handle wass long enough), and prying back and forth with a screwdriver, until I could get a nut between the housing end and the bearing retainer. Then I threaded a bolt through that nut and against the housing end, and tightened up until the axle finally came out.
    lothiandon1940 likes this.
  8. studebakerjoe
    studebakerjoe
    At the risk of stating the obvious I can't quite tell if thats a stock 55-57 rear there. I assume you already pulled the rear cover and removed the c clips from the ends of the axles if its a non stock rear.
  9. no C-clips
    lothiandon1940 and chevy57dude like this.
  10. studebakerjoe
    studebakerjoe
    tb33, I edited my post I was thinking it might've been replaced by a 10 or 12 bolt but I realized I misworded my post.
    tb33anda3rd likes this.
  11. Hombre
    Hombre
    Some good suggestions here, that come-along and a steady pull most times will just not work. It's going to take some shock value to break it loose...
    Sporty45 and Jibs like this.
  12. Shutt
    Shutt
    a little penetrating oil, some strategic tapping and more slide hammer broke it loose today during the Daytona rain delay. Hooah.
  13. larry k
    larry k
    Bent housing on that side ???????? Check it for straight !
  14. manyolcars
    manyolcars
    I used my backhoe to pull out an axle shaft stuck in a 1959 axle housing
  15. Boneyard51
    Boneyard51
    In my arsenal of tools are several sizes of slide hammers. Slide hammers come in sizes , just like wrenches. How effective a slide hammer is, is determined by the relation of the hammer’s size to the size of what you need to remove. A lot of the impact of a small , dent puller, slide hammer would be absorbed by the mass of the axle. The largest slide hammer I ever made was four+ft long out of 1 inch rod stock and had a differential out of a two ton truck for a slide! I assure you that would have removed that axle in one hit! Lol
    Bones
    deathrowdave and s55mercury66 like this.
  16. DDDenny
    About 1971 I swapped the 3.08's in my 57 Chevy with 4.11's, I borrowed my friends' axle slide puller, a real H.D. homemade unit, completely broke the head off of it.
    I'm guessing it had never been pulled apart before.
  17. BamaMav
    BamaMav
    from Berry, AL
    Had to get a end out of a floating axle 1 ton rear that had broke off in the spider gear. Took out the other axle, took a piece of 3/4" steel water pipe,ran it through that side and drove the broken piece out.
    flatford39 likes this.
  18. I have a 4 foot section of drive shaft tube full of sand that I have used a time or 2. I replace the original slide on my largest slide hammer with it. Only once has it taken 2 hits to get an axle out.
    Glad you got it out Shutt. :)
    Boneyard51 likes this.
  19. jimvette59
    jimvette59
    I have use 1/2 " bolts as a jack between the axle and backing plate.
  20. RmK57
    RmK57
    That might work if you had a spool or a Detroit locker. Cross shaft would be in the way in a regular differential.
    deathrowdave likes this.
  21. BamaMav
    BamaMav
    from Berry, AL
    Got a point there. I don't know how that Ford truck rear was set up, it was in a fork lift, but there wasn't a cross pin. I don't think it had a spool, because when one drive wheel would come off the ground, it would spin.
    Maybe floating axle diffs are different? I dunno....
  22. deathrowdave
    deathrowdave
    from NKy
    All the floaters I have worked on had cross pinned 4 spider gears . But that is not the question , the shock way is your answer to removing the stuck axle . The biggest slide hammer you can get your hands on as suggested a I bet in two slams it flying across the floor . Just be careful it’s easy to be in a terrible pin point with a slide hammer .
