Customs Source for ribbed exhaust tubing-ribbed lake pipes
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 5, 2020.
  1. High5
    High5
    I still have a set of original full length ribbed laker's. They're made out of 1-3/4" OD tubing. The depth of each rib looks to be around 1/32". Here's a photo:
  2. HAHA Stuff like this always reminds me of my days working at the music store and having hot moms come in and ask for a Big Muff for their kid. Few added the Pi part. :eek::D
  3. Inked Monkey
    Inked Monkey
    Correct me if I'm wrong, but isn't the process of rippling the pipe called Swagging or something like that? Looks like a HAMB member needs to just start making them again. There seems to be a market. I know I'd take some for the belly burners on my RPU.
    54delray, Roothawg and kidcampbell71 like this.
  4. I thought about these when I read the thread title
    Okie Pete, Moedog07, alanp561 and 2 others like this.
  5. Roothawg
    Roothawg
    Close, but no cigar....
    anthony myrick likes this.
  6. :) ... hahahaha !!!
  7. So the phrase “ribbed for her pleasure” applies
    SS327 likes this.
  8. atomickustom
    atomickustom
    I read this whole thread just to find out why someone posted a photo of a fuzz box.
    Roothawg likes this.
  9. 392
    392
    Personally I think it looks cheap and goofy. Kinda like a flex radiator hose.
    rusty valley likes this.
  10. Bandit Billy
    Bandit Billy
    Yes you did. I went out and put the caliper on them for you guys.
    Pipes are 1.75" diameter. (why is there always metal shavings on my tools?)
    The ribs are .6255 inches apart (seriously, if the shavings aren't all over my tools they are stuck in my palms).
    Thanks for the pipes Mark! The truck is for my wife and she likes the ribs!
    54delray, Okie Pete, SS327 and 8 others like this.
  11. FASI
    FASI
    Here is a pair I had made and plated. UNBELIEVEABLY expensive. Plating was $1400. Fab work just as bad. IMG_0598.JPG
    54delray, drdave, Okie Pete and 7 others like this.
  12. Roothawg
    Roothawg
    Bump. Back from the dead.
    54delray and Moriarity like this.
  13. Didn't @Moriarity go and replicate some in another thread? SOMEBODY did as far as I can remember? @Tuck ? or maybe @Paul
    54delray likes this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I dinked around on my lathe and had some limited mostly unrepeatable success .... but I think @Tuck was working on a die to form them????
  15. If @Tuck does, I am up to order some! The GMC needs em!
  16. Kustom Faction
    Kustom Faction
    Watching this very closely!
  17. Roothawg
    Roothawg
    I talked with @Tuck about a year ago and he said he was working on a die. Haven't heard anything since.
    Sancho, 54delray and Tman like this.
  18. Harv
    Harv
    from Sydney
    I assume that the ribs shown in the link attached below (a set of piping bellows) are too deep for the look? They are deep like the ones in Post 4 of this thread, not shallow like the ones in Post 2.
    If they suit the look, you could cut the bellows ends off and weld midway in a length of normal exhaust pipe. If not, maybe a bellows manufacturer can make a profile to suit.
    https://www.triadbellows.com/exhaust-bellows-or-flex-hoses-what-is-the-difference/
    Cheers,
    Harv
    Max Gearhead likes this.
  19. Roothawg
    Roothawg
    I looked at expansion bellows, but they are usually pretty short.
    Okie Pete and Tman like this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    and they are way too coarse......
    Okie Pete, Tman and Roothawg like this.
  21. Sancho and 54delray like this.
  22. Roothawg
    Roothawg
    True.
  23. metlmunchr
    metlmunchr
    If you were going to try doing this with a pipe cutter, I think you'd have more success using a 4 wheel cutter like a Ridgid 42A rather than a standard cutter that has a single cutting wheel and a pair of cylindrical rolls. With a 4 wheel cutter, the only contact with the tubing is at the wheels so you don't get pressure from the rolls that will tend to flatten either side of the groove you're trying to roll into the pipe. Also, a standard single wheel cutter tends to push thin wall tubing into an oval shape as the cutter travels around the pipe. A 4 wheel cutter is going to provide more balanced pressure around the pipe, so it should roll the groove in with less distortion of the tube.
    I've got a Ridgid 300 pipe machine at my business shop. I'm sorta tied up for the next week and a half finishing up some stuff, but after that I'll experiment a bit with some exhaust tubing and see what sort of luck I have with rolling the ripples into it.
  24. Roothawg
    Roothawg
    If you get it figured out, I'll be your first customer.
  25. We could do it with a ..........................wait, never mind. Call me this week. We cane make coin ;)
    Sancho likes this.
  26. Blue One
    Blue One
    from Alberta
    Sounds like an interesting project for an attempt at hydro forming.
    Build a die with the appropriate ripple profile into the inside and clamp a piece of straight tubing into it.
    Pressurized with high pressure water and the tubing conforms to the die.
    SS327, razoo lew and Tman like this.
  27. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    yes sir, We are close to a working set of test dies- real ones will follow and then I’ll start selling the ribbed pipe.
    Sancho, kadillackid, 54delray and 4 others like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    any teaser pictures???
  29. Roothawg
    Roothawg
    I have 2 cars that need them. No pressure, just know that I can't finish them until you make the pipe available....;)
    Sancho, 54delray and Tuck like this.
  30. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I’ll post some soon-
    Can I post a pic of my mini louvers to distract you? DEA729F6-C8EB-4657-9DEF-7D9023813B9C.jpeg 9D615525-B0E4-4B1E-8185-5E1FF49D8D9E.jpeg
