Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. lumpy 63
    lumpy 63
    After work went to talk to surgeon about my upcoming foot operation. He told me my new toe joint is called a Hemi...How messed up is that? A Chevy guy with a Mopar toe!:D
  2. mopacltd
    mopacltd
    I knew you'd finally come to the dark side
    Chavezk21, 61Cruiser and WTF really like this.
  3. lumpy 63
    lumpy 63
    Thats just messed up Charles...:cool:
  4. lumpy 63
    lumpy 63
    Although, since it is my left foot maybe I will be able to shift like Ronnie Sox!
  5. 4speed411
    4speed411
    Working on a couple minibikes...El Burro fat tire and a Bonanza Scout Chopper to take along to some shows
    alanp561 and hammer-time like this.
  6. alanp561
    alanp561
    Borrowed an idea from @Marty Strode and reworked the step for my rear cross member. Thanks, Marty.
    Found out you can never have enough C-clamps.
    Made spring perches for the 8 inch. It came out level and square so I must have done something right.
    Chavezk21, WTF really and LAROKE like this.
  7. LAROKE
    LAROKE
    Slogged away at tearing down my '37
    January 16th 2020 Slogging away at the rusted bed bolts. Was under the weather the last few days. Still spent time out in the shop every day but didn't get as much done. Scramblin' out from under the truck several times with the Aztec quickstep put a kink in my operations.
    Finally got the bed off but it wasn't pretty. Last two carriage bolts turned in their anchorages. Prepared to grind the heads off when I realized they were both in ends of floating crossmembers and I could lift and lay the bedside down on its side, swing the crossmembers under the remaining board and lift the whole thing off as an assembly. Done! Beer of the day is Clipper City Brewing Company's Heavy Seas Winter Storm Imperial ESB.
    61Cruiser, Lil32 and alanp561 like this.
  8. alanp561
    alanp561
    I can't help it. That's a step up, right?:D
    lumpy 63 likes this.
  9. Bought a fresh 351W a few years back to replace the one in my 47. Thought I'd check the valvetrain, you know, when you get that feeling, you should.
    Super clean, looks like, if they ran it, it was short time. However, some of the lifters have marks on the faces, can't really feel with a finger nail, but, don't want to take a chance.
    So, now I get to pick a cam, of my own.
  10. lilmann
    lilmann
    I’ve been cruising all over now that it’s running again....this morning it started a little slower but it’s about 25 degrees outside. I drove to my sons school and when I started it up again it wouldn’t start. My wife jumped me and off I drove to Advanced Auto Parts for a new battery and alternator, both tested poorly. Changed it all out in the parking lot....gauge read 14 volts and off I went. Well before I even made it home it’s back to reading 12 volts and maybe dropping.....damn it what now!
    61Cruiser likes this.
  11. WTF really
    WTF really
  12. jimmy six
    jimmy six
    Needed double banjo fuel fittings for the 3-2s and could not find any for Holleys. I had 3 singles so I made 2 doubles by drilling thru the single side, redrilling to .303” and pressing in a 5/16” steel line with a flare bulb. Soldered after pressing using my bench vice as a press. Photos shows a single and the 2 doubles. Photo also shows the PCV on the rear of the center carb adapter. Everything has been polished since the photo. Thanks to a wheel on my drill press and a green bar. E50A1E8B-7BF7-4956-9181-28A9C65A060D.jpeg 78DB5FD6-022C-41AB-BBB4-C4C01E61E657.jpeg
    RICH B, lumpy 63, LAROKE and 4 others like this.
  13. David Gersic
    David Gersic
    from DeKalb, IL
    If it’s a “one wire” alternator, pull it and take it back. If it’s not, check the feedback wire. If that’s not connected, you may see the voltage fluctuate like that.
    lilmann likes this.
  14. WTF really
    WTF really
    Out with the new in with the old. Lol found a sweet deal on the old mac toolbox. 20200115_174224.jpg 20200116_170058.jpg
  15. LAROKE
    LAROKE
    Prepped for a windshield job on m '37
    January 17th 2020 Cleaned up the aftermath of the battle of the carriage bolts. Drip tray, siphon and paint arrived for the windshield job. The drip tray has a corrugated bottom. That's a bonus. I won't have to fashion stand-offs for the submerged parts. Still waiting on Evapo-Rust. In the mean time I'll be removing parts of the drive train and some other, between the frame rails, items. I was wrong about the running board supports being bolted. They are riveted. I must've been having a senior moment. They are sharp on the ends and I've been collecting bubble wrap to encase them. A person could get a bad gash and I'm just the man for the job.
  16. Marty Strode
    Marty Strode
    Fabbed and installed hidden hood hold downs, on friends 32. It was fresh out of Mitch Kim's shop, getting striped and lettered. It will be in the GNRS next week. IMG_3824.JPG IMG_3825.JPG
    Latigo, lothiandon1940, Lil32 and 5 others like this.
  17. jimmy six
    jimmy six
    Marty...you going to issue some shades so we can look at it? Damn...that's bright.
    lothiandon1940 and 61Cruiser like this.
  18. Marty Strode
    Marty Strode
    Jimmy, It is bright ! Being a Father and Son project, that they are going to race, and friends of mine for nearly 40 years, adds some fun to my work. IMG_3829.JPG
  19. saltflats
    saltflats
    from Missouri
    Just got in from thawing the ice off my wife's daily and put up a canopy over it with hope that when she has to go to work in the morning it won't be a as big of a task. I hate this ice storm.
    Lil32 and lumpy 63 like this.
  20. Began an inframe overhaul on an ISB Cummins. My hair is full of oil.
  21. Paul
    Paul
    Editor
    Not today but yesterday, finally stopped raining long enough to take the roadster out to run errands..
  22. Marty Strode
    Marty Strode
    Nice work there Alan !
    alanp561 likes this.
  23. lilmann
    lilmann
    That’s the plan....take it back and order something from Summit instead of shit auto parts store.
  24. I looked at these photos a few dozen times, thinking if I pulled money out of 2 different accounts it wouldn't seem to be as much...lol
    In reality I have no room for it and I'm not one of those "it's only real if it's steel" kind of guys, but I do think it's a cool looking old hot rod
    Screenshot_20200117-225146_Facebook.jpg Screenshot_20200117-225346_Facebook.jpg Screenshot_20200117-225308_Facebook.jpg Screenshot_20200117-225219_Facebook.jpg 20200117_225649.jpg Screenshot_20200117-225552_Facebook.jpg
  25. lumpy 63
    lumpy 63
    Nice looking coupe , kinda odd with a flathead and a Jag though:rolleyes:
    swade41 likes this.
  26. mopacltd
    mopacltd
    Lumpy63 is not working on something in the garage? That is a first!
  27. Yeah I was thinking why the jag too, it said it was a new chassis, I think he had a flathead on hand and stuck it in there and the rest of the parts were from the original car ?
  28. junkyardjeff
    junkyardjeff
    Had a rolling 3/4 ton truck frame dropped off for my beater truck,its presently a half ton and the frame has holes where the rear bumper and trailer hitch bolts so time to upgrade. Going to look for a nice bed and front fenders so my beater truck will turn into a nice truck,since I have a very nice cab with working a/c and all I can find around here is junk so time to build a truck.
    Truckdoctor Andy and harley jim like this.
  29. Cleaned up my old vise
    Still working on the stand[​IMG][​IMG][​IMG]
    Sent from my SM-A102U using Tapatalk
  30. Wired up my buddy's dash panel; glob of wires on the other end helped me remember why I don't particularly like wire kits.
    alanp561, Farley's34 and Lil32 like this.
