Putting a 500 Cadillac/ TH400 into a 1949 hudson Super with a Fatman Fab frontend and despite what seems like a difficult instal, the brake pedal and MCplacement is turning out to be the most difficult. The lower left side of the engine needs to fit the steering column, brake pedal, MC, and exhaust. Has anyone been in this situation and found a brake pedal/MC/and 7"booster setup that is compact enough to fit in tight space? The under dash 90˚ setup won't fit with stock heater/fan in way. I can't find a setup that will mount anywhere except on the inside of the left frame member Does anyone have a suggestion or solution that worked for them and doesn't leave the booster and cylinder out on the firewall? Thanks
Can you leave off the booster, and run a smaller bore m/c, and still stop ok? that would be my approach, I think. I didn't have too much trouble with the stock brake system in the 51 Hornet I had, but it had a rather anemic engine, compared to the Caddy mill you're swapping in.
A 3/4 or 7/8” MC and multi piston front calipers an at least 11” rear drums with 7/8”or 15/16” wheel cylinder will stop like power if your pedal ratio is 5 to 1 or more. Wilwood has 4 or 6 piston calipers.
It will have disks in front/drums back, and it weighs 3800lbs. Just thought that would require power brakes....?
I built a Coe 40 Ford years back, and mounted the booster inside the firewall (dash side) and master cylinder on the outside (engine side). Homemade swing pedal assy. Would that work for You?
Well, you could always switch to mechanical drums.... j/k! With that step down, is there any room underneith to squeeze it in under the floor? https://www.summitracing.com/parts/...MIkNvTteuE5wIVEdvACh1q_gBOEAQYASABEgLNR_D_BwE Also, like other have said, manual discs aren't that bad if you have the right pedal ratio, MC bore, and your legs are healthy.
I had similar issues with my 46 Olds with my underdash brake assembly due to AC unit. I moved entire assembly to the left and modified with an extended 1" solid bar machined with 3/4DD end and delton bushings for pendulum pedal to position correctly. I used a 3/4DD coupling to connect and fabricated a short fulcrum to maintain OEM geometry and machinded end for circlip to secure and prevent lateral movement. Problem solved, my engineer is more than happy as many RHD conversions used a similar crossover rod whilst maintaining LHD brake assemblies. Sent from my SM-G973F using The H.A.M.B. mobile app
Not sure if this helps but I had a 1989 Dodge Colt made my Mitsubishi that had its brake booster and master cylinder on the passenger side with linkage for the brake pedal on the driver's side. You could make something like that. Sent from my SM-T350 using The H.A.M.B. mobile app
They did that because it was a RHD car to start with, and they decided to export a few without wanting to redesign the whole car. Interesting idea.
You can get remote power boosters, you mount the master cylinder on the pedal like normal, then plumb the hydraulic line to the remote booster, then out to the callipers, great space savers, google VH44 brake booster Sent from my iPhone using H.A.M.B.
Would a hydroboost system fit under the floor? It should be smaller diameter than a vacuum booster, but you would have to deal with the lines from the power steering pump.
Some Alpha Romeos, Mercedes Benz and others have that factory crossover bar, saves re-engineering components if you have some spare under dash space available. This is my under-dash brake set up, the assembly was pushed over to the left for clearance, this placed the OEM brake pedal to the left of column, too dangerous in an emergency. The crossover bar moved the brake pedal 6" to the right and on the righthand of column, a lot easier and safer to access. Out of sight, out of mind. I've a hidden remote reservoir for MC with a stout steel frame (Secured side to side and firewall) that supports everything; brakes and AC. Remove the bolts and the frame with everything attached just drops out if necessary, or just service individual parts in situ. OEM brake pedal pivot was moved from circled area to lined area for required clearance, all OEM geometry was maintained. OEM brake pedal boss was drilled out with holesaw allowing pedal to be fully welded to new solid stock. Small flange on top of pedal arm is OEM fulcrum that will be cut off when complete.
Hudson offered power brakes in 1954. Maybe if you could get the pedal and bracket from one of those the pedal part might be near to a bolt-on. They're kind of rare. Also, I ran a Bendix Hydrovac booster on my '51 Hornet and it was almost too good. Very powerful. I put it on the left fender liner where it made seeing the timing marks on the flywheel almost impossible.
On my 49 Hudson i used a hydroboost setup under the floor. heaps of room for it. Even air out still has room. Some details about it are on my 49 build thread... really need to update that >< /lazy
