Technical Dynaflow converter swap.
Discussion in 'The Hokey Ass Message Board' started by Pontmerc, Jan 12, 2020.
  1. Pontmerc
    Pontmerc
    from Finland
    Any dynaflow gurus in here?
    I have a 63 le sabre.
    Busted torrington bearing in converter makes one hell of a mess.Bended vanes and metal shraphnells all over torq converter.
    I do have spare converter but it is different in couple ways.
    First, it has aluminum turbine wheel/housing where original has steel outer race one.
    Turbine snout has two slots for oil pump inner gear in original part.Replacement part has two "tabs" , so it will spin oil pump gear, but not supporting it as original configuration would do.Is that an issue?
  2. If you know what the replacement torque converter is out of you could go backwards and see if it will fit into your transmission.
    I know the dynaflows of the 50’s kept changing almost every year.
    Elcohaulic likes this.
  3. Pontmerc
    Pontmerc
    from Finland
    Well, i dont know.This pile is sitting in garage for over twenty years because of this broken transmission issue.When it came to me, i was told it has crank snout difference and converter pilot should turned in lathe for make it fit, but as i was exploring what would fit and what not, it turns out the new converter fit in crankshaft no problem and the difference is in converter oil pump snout.
    You understand, this thing has been disassembled so long time, that everything important things has been forged.Now i have to put this puzzle back together.
    VANDENPLAS likes this.
  4. Mr48chev
    I'm thinking that that is one of those "the only thing that fits is the exact model" things unless you do a full trans swap using an adapter.
    Adapters are rather spendy but rebuiding the dynaflo and buying a correct converter isn't going to be cheap these days unless you are a Dynaflo expert and don't have to pay the labor.
    https://transmissionadapters.com/collections/buick Is a common go to for adapters.
  5. Pontmerc
    Pontmerc
    from Finland
    Im not a dynaflow expert.However, i do have repair countless old automatics.Cruisomatics, jetaways, powerglides and dynaflows.
    But this thing having mixed replacement parts got me nervous.
    Anyway, i allready ordered master overhaul kit ( not cheap) and dissassembled whole transmission.
    Mostly because seller told that trans got metal particles in it.Well it didnt, but its still good idea to do major overhaul in transmission that has been sitting partially dissassembled for over twenty years, right? Whole thing makes only sense because its convertible and engine is in good shape and kept running couple times over the years, and rest of the car isnt too bad either.
    Im gonna make it runner before next summer.
    VANDENPLAS and leon bee like this.
  6. Pontmerc
    Pontmerc
    from Finland
    Well now i know why this thing has been sitting so long.
    One of flexplate to crankshaft bolts has been loose and hitting against converter.Also bellhousing bolts let loose and other dovel pin broke loose.
    And yesterday when i was cleaning that good sounding 401, i noticed it has about 8 inch long freeze crack on its side.Im on the edge of putting something else powertrain in this thing.
  7. Hnstray
    Hnstray
    from Quincy, IL
    My sympathy for your unexpected mechanical grief. That has to be very disappointing.
    Best wishes on sourcing a replacement power train.
    Ray
  8. Pontmerc
    Pontmerc
    from Finland
  9. Pontmerc
    Pontmerc
    from Finland
    What im doing wrong? Only this pic Will show.others get notification"security error occured, please refresh page and try again."
  10. Hnstray
    Hnstray
    from Quincy, IL
    A ‘64 thru ‘66 401 with either the two speed Super Turbine 300 (ST-300) or, better yet, the three speed Super Turbine 400 (ST-400) would be an easy swap.Both of those use the switch pitch torque converter.
    Buick changed the block to transmission bolt pattern on the larger engines for ‘67 models (‘64 for V6 and 300 V8), but they used the switch pitch converter 400 with new case bolt pattern thru at least ‘67. The new for ‘67 400 and 430 were good engines too and would fit the chassis of your ‘63, but all the bolt on stuff is different from the 401.....
    Ray
  11. Pontmerc
    Pontmerc
    from Finland
  12. Pontmerc
    Pontmerc
    from Finland
  13. Pontmerc
    Pontmerc
    from Finland
    IMG_20200115_164304.jpg be patient.i just learn how to put pictures in here.not gonna give up now.gonna weld that crack, machined that ruined dovel hole and put this fine combo on one piece again.
    Hnstray likes this.
  14. Pontmerc
    Pontmerc
    from Finland
    15790995773653093057029256354806.jpg this might Even be 425....
    Hnstray likes this.
  15. Pontmerc
    Pontmerc
    from Finland
    15790997099434744645450019174839.jpg atleast i have plenty of room and Time to Make engine Bay cosmetic restoration on proper way.2k acryl paint, new brake lines etc.
    Baumi and Hnstray like this.
  16. Pontmerc
    Pontmerc
    from Finland
    1579799928940557513543834321698.jpg 15797999869415874175255480650031.jpg so far, so good.i think i cover that weld seam with epoxy, just to Be sure its not gonna leak.
  17. Pontmerc
    Pontmerc
    from Finland
  18. ROADSTER1927
    ROADSTER1927
    Nice work , I like it! Gary:)
  19. Pontmerc
    Pontmerc
    from Finland
    I think buick block is good quality casting.I bought high nickel cast iron welding rods.
    Weld about 7/16 and hammer.Then cool with compressed air.No rush.Block has to stay cool all the time.
  20. Try Fasco Transmission in New Jersey. They have extensive knowledge of early transmissions.
  21. Pontmerc
    Pontmerc
    from Finland
    I found somebody who is cabable doing necessary machinework.to mount snout from ole converter to new one.so transmission issue is sorted out, hopely.
    Some progress with engine Bay too: 15799505479311712390183746661979.jpg 15799505924991572693597374328365.jpg
  22. Hnstray
    Hnstray
    from Quincy, IL
    @Pontmerc
    That looks GREAT! Nice job........
    Ray
  23. Pontmerc
    Pontmerc
    from Finland
    Thank you.
    Hnstray likes this.
  24. Pontmerc
    Pontmerc
    from Finland
    1580324673544944641580753324062.jpg 15803247507238759971691713317501.jpg 15803248344053489384021309533946.jpg Not much, but now it has fully functional brakes.waiting for The converter and Set of new freeze plugs.just Been cleaning and painting all that small stuff.good ol nailhead is about turn key condition.
    Hnstray likes this.
  25. Pontmerc
    Pontmerc
    from Finland
    15804895438602163818156899473042.jpg Not exactly dynaflow related, but whatt The heck.dont know how to change thread title.
    Just wire brushed and painted floor section.no need to weld anything.rare thing in convertible type car.
    bchctybob likes this.
  26. ROADSTER1927
    ROADSTER1927
    Progress looks Great! Gary:)
  27. Pontmerc
    Pontmerc
    from Finland
    15805678063397262700765378915446.jpg New plugs in place.lukily i decide to put starter in this situation and not when engine is in a car.i have to grind carefully that epoxy resin to make it fit.tight place. 15805680102832614424438245299501.jpg
    don colaps likes this.
  28. Pontmerc
    Pontmerc
    from Finland
    IMG-20200221-WA0012.jpeg IMG-20200221-WA0010.jpeg IMG-20200221-WA0008.jpeg IMG-20200221-WA0006.jpeg 15822996279796493266055576548994.jpg Tomorrow ill start her Back to Life.
    don colaps and bchctybob like this.
  29. Pontmerc
    Pontmerc
    from Finland
    15823863490272759487564052185336.jpg 15823863861441578719221123782189.jpg Got her running yesterday (night).
    Today, put it More together.add oil in transmission as the converter filled up.finally got decent Idle, and correct oil level in transmission.then the scary part, put shifter in drive position.
    She engaged forward drive instantly.then move selector in reverse and low position.my god, it works like a charm.
    I just allow My self a few cold bewerages.
    Life is good.
  30. ROADSTER1927
    ROADSTER1927
