Technical 26T Coupe Of My Youth Gets A Re-do! (build)
Discussion in 'Traditional Hot Rods' started by VA HAMB, Dec 6, 2018.
  1. Nice job on the top! Looks great.
    loudbang and VA HAMB like this.
  2. VA HAMB
    VA HAMB
    I fabbed up a trans cover and installed the header panel I covered. Got the wiper motor going and mirroe installed. Also got the dome light wired up and working.
    JUNK ROD, Tim, dwollam and 7 others like this.
  3. VA HAMB
    VA HAMB
    Doubt anyone is interested (except maybe Ronnie! :) ) but I found these yesterday in box. Photos I took in photog class in highschool. (1985) I traced the photos onto paper for a monotone sketch look. I eventually copied this onto the cover of my denim notebook. Which I still have. I'll have to go find that to add to the collection. I'm trying to put all of this together for my son so he'll have the complete history.
    Vic Walter, Tim, dwollam and 14 others like this.
  4. 1low52
    1low52
  5. Stogy
    Stogy
  6. Tall t 26
    Tall t 26
    Nice job. Great build and awesome pics. Thanks for sharing.
  7. 1low52
    1low52
    Vic Walter, Tim, dwollam and 5 others like this.
  8. VA HAMB
    VA HAMB
    Mee too Timmy!! Had it running yesterday! The acelerator pump wasn't working so I have to take carb off and give it going through.
    dwollam, loudbang and Ron Funkhouser like this.
  9. VA HAMB
    VA HAMB
    https://photos.app.goo.gl/vvQ6UxuuCqkFGNJr5
    Well, it started. It ran for a while, although a little rough. We had a flaot that was stck so took the top of the carb off and cleaned out the bowls and jets and fixed the float. When we tried starting it again it ran for about a minute and stopped. Turned out the pump wasn't working so i I'll have to tear it all the way down and give it a good cleaning and maybe a new pump. the old ethenal gas does wonders on this stuff!
    Stogy, dwollam, loudbang and 2 others like this.
  10. VA HAMB
    VA HAMB
    Other than starting it, the only thing I got done was the door trim tops. Didn't really have the $$ for some repops so i took some bent sheetmeatal i had and made some. Better than the step railing that was there before.
    IMG_20200104_170232.jpg IMG_20200104_170248.jpg IMG_20200104_171012.jpg IMG_20200104_172332.jpg IMG_20200104_182507.jpg
    JUNK ROD, Stogy, Tim and 8 others like this.
  11. Thanks for the updates Todd. 2020 is gonna be our best year ever! Yeah those sketches and photos are GREAT. Now all you need to do is get a flat top hair cut! { KOOLEST HOT ROD ! }:)
  12. VA HAMB
    VA HAMB
    Not much to report. I did get it running last week but wouldn't idle. Turns out the little ball under the squirters is missing. Not sure how that happened but new one on the way. Plus I switched manifolds from the last time I got the engine going and this one is leaking water from the rear corner so out it came and back with the old. I did get some more panels done.
    IMG_20200119_131913.jpg IMG_20200119_132034.jpg IMG_20200119_132359.jpg IMG_20200119_132700.jpg IMG_20200119_133657.jpg IMG_20200119_135240.jpg
    JUNK ROD, Stogy, dwollam and 7 others like this.
  13. VA HAMB
    VA HAMB
    Well I have been working on the interior. Not really something I would wish for but with limited funds you do what you gotta do! When I got the car out of storage the first time in 05 I had a bench seat recovered and the doors done. When I redid the car the door panel no longer fit and the old holes from the screws showed so i had to redo them. i did the door panels back the way they were in the 70's i would have done it in black but since the seat was white i stayed with it. Took me forever to find some buttons! (I can't find the original ones)
    JUNK ROD, cactus1, Stogy and 8 others like this.
  14. loudbang
    Looks good. When you are driving it you won't even think about them :)
  15. VA HAMB
    VA HAMB
    Originally the rear glass was put in with an RV gasket. I thought this time I would put it in the original way but wasn't sure how to do it. I don't have an original frame to mount it or the money folks are asking for one. The repops are fiberglass so that was out. So I had new glass cut and put the rubber on it and made a rear panel to hold it in place. I kind of over id it with screws so it looks like shit but it works great!
    T Pictures 007.jpg IMG_20200126_170922.jpg IMG_20200131_202058.jpg IMG_20200131_204417.jpg IMG_20200207_191615.jpg
    JUNK ROD, Stogy, AHotRod and 6 others like this.
  16. VA HAMB
    VA HAMB
    I really struggled on how to do the rear corner pieces. I finally saw an upholstery site where they talked about using ABS Sheet to mold shapes so i cut out a piece and heated it and rolled it over my leg and covered it. Worked like a charm!!
    IMG_20200207_141014.jpg IMG_20200207_142159.jpg IMG_20200207_151316.jpg IMG_20200207_152650.jpg IMG_20200207_155509.jpg IMG_20200207_155524.jpg IMG_20200207_191615.jpg
    JUNK ROD, Stogy, dehartcarl and 9 others like this.
  17. VA HAMB
    VA HAMB
    Here is a better view of the back glass installed
  18. Interior looks period perfect!
  19. Mike Colemire
    Mike Colemire
    Car looks awesome. Interior work turned out really good, you are doing a great job. I'm in the same boat as you, I can't afford to have mine done so you are giving me inspiration.
  20. VA HAMB
    VA HAMB
    Thanks for all the nice comments. I did the best I could with what I had. IMG_20200222_171818_390.jpeg IMG_20200221_185834.jpeg IMG_20200221_185916.jpeg IMG_20200221_185024.jpeg IMG_20200221_190554.jpeg
    Sent from my XP8800 using The H.A.M.B. mobile app
  21. jtbender
    jtbender
    from troy, mi
    T's are cool. Everyone should have a T. I finished this 26 three years ago. IMG_0658.JPG
    chryslerfan55, cactus1, Stogy and 8 others like this.
  22. MMM1693
    MMM1693
    Nice job on the interior, great job on the whole car.
    Ron Funkhouser, loudbang and VA HAMB like this.
  23. 1low52
    1low52
    The white steering wheel looks great.
    Instead of a tissue box you're going to need a gl0ve box (literally) lol.
  24. Tim
    Tim
    from KCMO
    Man I haven’t been getting update notifications! Guess I’ve got some catching up to do
  25. Mike Colemire
    Mike Colemire
    You sure nailed the color, couldn't look any better.
  26. coostv
    coostv
    Car looks great! Makes me wish I could fit in one somewhat comfortably, lol.
    Sent from my moto z3 using Tapatalk
  27. Great story, Great build, Great color, Great history, Great Rod, and a Cool owner. Now let the FUN begin !!!!
  28. AHotRod
    AHotRod
    I Love all things that are homemade, that includes your interior, the true meaning of Hot Rod.
    Great job brother!!!
    VA HAMB and loudbang like this.
  29. That is a bad a$$ little hotrod!
    chryslerfan55, VA HAMB and loudbang like this.
  30. VA HAMB
    VA HAMB
    well history was made today! After 4.5 years she finally moved on her own. I had been battling some valve train issues but she’s sounding great now. Just need to do a little more to the brakes.
    7B97EB73-B416-4FCC-B701-A43D3F703635.jpeg 7C2E723B-7848-45B7-BAA1-5BFCB5E12C9D.jpeg 3DCBE183-DDBF-48C2-8C4E-A67FF9086BB5.jpeg 042C5300-60F9-4F5E-B0D7-C6627603DF4C.jpeg 36BC881E-6C4A-4BDF-9F3A-60683EABD3CF.jpeg DEB02ABC-6B46-4CC3-9D74-4C2767EAA976.jpeg 86022175-8090-4E79-BBCE-3EB636BFC798.jpeg 8A91ABE3-840B-4F29-91B7-2B91010F2D04.jpeg
