Projects 1950 Chopped Chevy Sedan Delivery
Discussion in 'Traditional Customs' started by RMONTY, Jan 15, 2016.
  1. Sorry to hear that. Good help is hard to find and a good friend seems to be harder to come by these days. Loosing one that's both is a rough deal for sure. No doubt your shop won't be the same for some time to come. Remember the good times. Seems terribly young to be checking out. I'm sure he enjoyed his time with you.
  2. Dang brother, I’m sorry about the loss of your friend. It messes with your head when death strikes so close.
    Bowtie Coupe and RMONTY like this.
  3. Wow, 44. Sorry about your friend. I second all the previous comments....each day is a gift and it’s good to cherish every moment with those we love and whose company we enjoy.
  4. Condolences to you and his family.
    Nostrebor and RMONTY like this.
  5. Nostrebor
    Nostrebor
    Condolences man.
    Now you have a good reason to finish what he helped you start.
    RMONTY likes this.
  6. RMONTY
    RMONTY
    Gathered up some steel and a couple of casters and started working on the rotisserie today. I need to grab some smaller casters tomorrow and get some wheels under the framework so I can roll the thing around. In this picture, I just have it sitting on some square tubing to elevate it a bit. I will weld some tubing perpendicular on the ends of the base and mount the casters to that. The metal reel spins extremely easy on those blue casters. 20200104_203854.jpg
    Bowtie Coupe and kidcampbell71 like this.
  7. If you wanna borrow the "widow maker" I'll sure loan it to you! Lol, got a new wire brush to go on it :D:rolleyes:
  8. RMONTY
    RMONTY
    My stepbrother is in the stucco and plaster business. He told me at Christmas he was going to buy a dustless blaster setup and told me if I ever had the need for one to give him a shout. Hopefully that will do away with the need for a wire cup. I have several of them around here as well. :rolleyes:
    I hope to have the rotisserie ready to get the car on it by next weekend. I got some bracing welded into the door openings since the inner and outer rockers are non-existent. 20200104_210938.jpg
    Bowtie Coupe likes this.
  9. One of those dustless blasting setups would be awesome. There's one guy around this area that does mobile grit blasting but he must not like me. I asked him about blasting a subframe out of an OT Camaro once and he quoted $350 if i brought it to him. I thought that was high, maybe I'm wrong. Hang in there brother, once you start welding them panels in it'll come together quick
  10. casper50
    casper50
    from alaska
    I removed 4 of the spokes in the reel ends to facilitate access. Still plenty strong.
  11. RMONTY
    RMONTY
    Thanks Casper,
    I was going to message you about that.
    Did you have any issues with figuring out the mounting and balance points? I would assume they would be similar between the 2 cars.
  12. casper50
    casper50
    from alaska
    I just built in lots of adjustment. But I did my 47 coupe first. Balance point was much lower than for the 55 wagon. I had to cut where the body bar welds to the hoop off and raise it 12 inches. The coupe sits about 10" higher than the wagon. I'd guess your sedan delivery would mount close to where I did the wagon mounts.
  13. casper50
    casper50
    from alaska
    17" from outside of hoop to the top of the bar that goes across the hoop and the body hooks on to.
  14. RMONTY
    RMONTY
    Thank you sir! I'll give those measurements a try and fine tune as needed.
  15. casper50
    casper50
    from alaska
  16. RMONTY
    RMONTY
    Got the body totally loose from the frame this evening. I have been trying for weeks to get the steering wheel off so I could pull the column but it just wasn't cooperating. I had to get the sawzall out ( @Lloyd's paint & glass don't be calling mom again!) and cut the steering column off down by the steering box. The box was worn out anyway, and I have an extra from the 4 door car as I bought a 53-54 column way back when from a H.A.M.B.er.(Thanks again @325w!) It has bearings instead of bushings in it, much easier to turn. I'll put the old box on the chassis so I can move it around easier. A couple of pics....one of the gap under the front mounts, and one at the rear of body where it was sitting on the chassis. This is where that pain in the ass 1/8 of a turn bolt resided. You can see the nut from the failed weld attempt laying there.
    I picked up some 3/16" plate to continue the work on the rotisserie. I am going to build a couple of wide sawhorses this weekend and jack the body up off of the frame, slide the sawhorses under the body, and roll the chassis out from under it. I should be able to start getting the rotisserie ends mounted to the car at that point. I swear there must be 30 pounds of red Georgia clay under this car by now. You can't take any bolt out underneath without red sand pouring out and red caked on clay breaking loose and falling on you. I will be glad to get that mess cleaned up under there. The rotisserie will be very helpful with dealing that part.
    brEad, drdave and Bowtie Coupe like this.
  17. Mom!!! Monty's got power tools out again!!!!! You're welcome :D
  18. RMONTY
    RMONTY
    *%@*%&#(% snitch bitch.....snitches get stitches!
  19. Shit Monty! That reminds me, i forgot to call the cats back at glass search!! I'll call them in the morning!
  20. RMONTY
    RMONTY
    No biggy....it's for budgetary purposes only obviously. I appreciate you taking the time.
  21. Buddy I've got the time to help out my brother! If i can get it cheap, you can have it for my cost ;)
    325w likes this.
  22. RMONTY
    RMONTY
    It's a ways from Trenton TX to Owingsville KY. Maybe when the car gets close to needing glass I will take a few days off and trailer it up there and we can put the glass in. I'm always up for a good road trip.
    I will need to reset the glass in the rear door (which I have) as well as the glass in the doors and the windshield. I get something like 32 days PTO from work after I made my 10 year anniversary last October.
    Charliechop and brEad like this.
  23. RMONTY
    RMONTY
    More work on the rotisserie yesterday and today. Ive got the basics done, now I need to get the mounting figured out. I think I will work on getting the body off the frame next. I can then start figuring out how best to mount the body.
    brEad and Bowtie Coupe like this.
  24. casper50
    casper50
    from alaska
    Lucky you. Your hoops are straight. lol Mine were a bit banged up and not straight. Nice.
    RMONTY likes this.
  25. RMONTY
    RMONTY
    I've been working on the project here and there, and have made some progress. Finally rolled it over on the rotisserie today. Thanks again @casper50 for the inspiration! I need to fine tune the adjustments but it should come together nicely!:cool:
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I hear tools moving around.
    Hombre and RMONTY like this.
  27. Cosmo49
    Cosmo49
    Great job!!!
    RMONTY likes this.
  28. RMONTY
    RMONTY
    I cleaned all the tools out before we rolled it over. That's a bunch of dirt dauber clumps, old fasteners and hardware, and maybe some trim. I'll get after it with the shop vac now that everything will end up in a corner at some point.
    chryslerfan55 and Hombre like this.
  29. The37Kid
    The37Kid
    Those trammels spin a bit faster on "Gold Rush".:rolleyes: Look forward to the body repair. Bob
    Hombre likes this.
  30. casper50
    casper50
    from alaska
    It will make life much easier. Can't do without mine. Once you find the wire reel it's a pretty easy cheap build.
